Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 07-24-2002, 02:23 PM   #1
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Default BIG water tank for water injection
Anybody have any solutions on this? Sponaugle has water injection on his car, and I'll be putting it on my car within the next week or two. The stock winshield wiper tank is too small - you can empty it pretty quickly.
I've looked at the STi water tank that fits in the trunk, and while its big enough, I don't really like the idea of paying $300 for a tank.
Any suggestions?
DarthChicken is offline   Reply With Quote
Old 07-24-2002, 02:32 PM   #2
WAlude
Member#: 17361
20 Urabus
XRW
Why not make a container for the trunk?
Could be a ghetto milk jug or two...
Or maybe a stainless steel tank of some sort, like a giant oil catch can for the water spray?
I would think what it is would have to be in the trunk, there is really no room for large amounts of anything under the hood.
WAlude is offline   Reply With Quote
Old 07-24-2002, 02:35 PM   #3
STEALTH-WRX
Member#: 7822
Multi layer snot green
you should definately use the mrt water boot tank. www.spimotorsports.com has them for sale. they hold like 10 times the water of your windshield washer tank and it looks cool. heres a picture of it. spi sells it for $179.99! this is what i am going to use.
STEALTH-WRX is offline   Reply With Quote
Old 07-24-2002, 02:50 PM   #4
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Interesting - do you know what the capacity is? And what's with the wiring, is there a pump inside, or is that some sort of water level monitor? I definitely want to do that as well, so I know to stay off high boost when the water runs out (to avoid ruining the pump and/or knocking my engine to oblivion).
Old 07-24-2002, 02:54 PM   #5
Sordid Philosopher
Member#: 16854
2003 WRX Sedan
I'm thinking about this too, but I was thinking of installing a large plastic tank in my trunk (5 gallons).
Sordid Philosopher is offline   Reply With Quote
Old 07-24-2002, 02:55 PM   #6
Sordid Philosopher
Member#: 16854
2003 WRX Sedan
Where did you get the water injection from?
Old 07-24-2002, 03:11 PM   #7
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
I bought mine from 3SX performance - Aquamist system for $439
I don't mind putting a 5 gallon tank in my trunk, actually I'm pretty sure thats what I'll have to do. but I want to find something that looks halfway decent - bungy cording a 5 gallon gas can isn't what I had in mind, and I want to be able to hook up a LED to warn me of low water level.
Old 07-24-2002, 04:15 PM   #8
DJWRX
Member#: 10340
I just bought a stainless 5 gallon tank for $15 off ebay. The guy keeps calling it a keg. It holds pressure to 130 psi (I plan on pressuring it to ~15 psi). I'll have to do some work to it, ie drill and tap for new fittings, put in a level sensor, and a bottom feed.
$29 shipped is cheap compared to most of the stainless tanks I've sourced. It'll take some work, but I've got more time than money right now, and I get a good amount of satisfaction doing things myself.
Tim
ps, if you want to search ebay for the tanks, don't look in ebaymotors, just the normal ebay, I saw numerous very feasible tank options there.
DJWRX is offline   Reply With Quote
Old 07-24-2002, 05:01 PM   #9
DJWRX
Member#: 10340
Old 07-24-2002, 09:37 PM   #10
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
Has anyone ever thought about using the water that condenses from your air conditioning? Put a small tank (with an overflow), and have the AC drain line go to it.
A nearly endless suppy of water in theory.
dbrier is offline   Reply With Quote
Old 07-24-2002, 09:40 PM   #11
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
I dont' think you understand the amount of water this uses - the 1 gallon washer resevoir isn't near big enough to do any sort of spirited driving for more than a few minutes. I could easily see draining 1 gallon in 20 minutes on the track.
Old 07-24-2002, 11:45 PM   #12
WrxSPD
Member#: 12886
Go to any PRO shops and you will have a large selection of stainless or Alumin containers to chose from. Circle track racer build their own car so they uses all kinds of tanks to hold fluid with.
WrxSPD is offline   Reply With Quote
Old 07-25-2002, 03:02 AM   #13
tifosi77
Guest
Member#: 14110
2002 2002 WRX
Swirly Black
The MRT one is 12 litres I believe and the welds are very nice and clean, if you need any help with install I can forward a good email with picks that someone sent me.
tifosi77 is offline   Reply With Quote
Old 07-25-2002, 03:34 AM   #14
WRXBob
Member#: 12455
02 WRX
I made an aluminum bracket in the trunk and put in a 5 gallons plastic gas tank with a water line quick disconnect. The water line is then route to the front of the car where the pumb is. It cost about $20 and I can use the gas can in emergency.
WRXBob is offline   Reply With Quote
Old 07-25-2002, 04:58 AM   #15
tymbrwolff
Member#: 18108
2002 Impreza WRX
Platinum
A 5 gallon Cornelius Keg that you could buy from a beer making supply place would probally work well for what you want it for, though im not sure how you could wire something up to tell you how much water you have left in it, though if you have any electronics knowledge you could probally figure something out. They also have dip tubes that go all the way to the bottom of em so if you cut it off around the middle and pointed it down it wouldnt still be full and cause you to run dry. And if you decide you dont want it in the car anyome just take it out and put some beer in it Just do a search for beer making supplies and you'll get hundreds of hits, and if you cant find any drop me a line and ill tell ya where i got my kegs from.
Scott
tymbrwolff is offline   Reply With Quote
Looking for something that can fix a leaking gasket for a hot water tank. Cjchaps Off-Topic 17 01-11-2010 10:37 AM
For Sale: NEW APS Piping in RED for DR 725 FMIC w/couplers and water tank syoung0298 Engine/Power/Exhaust 10 11-17-2008 08:53 AM
sti water tank for meth neversummer489 Water/Methanol Injection, Nitrous & Intercooler Cooling 3 11-02-2008 08:49 PM
Where to get the clogged jet/water flow indicator sensor for water injection cheap? garie Water/Methanol Injection, Nitrous & Intercooler Cooling 5 06-07-2005 05:55 PM
I need a water can for water injection, any ideas? AntiochCali Water/Methanol Injection, Nitrous & Intercooler Cooling 3 06-02-2003 10:57 AM
