Old 06-15-2011, 10:21 PM   #1
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
Default WRX09: AP log, please review
Greetings everyone,
I was going to post this on COBB forum but the site is down and I figured it will have more exposure here. WRX 09 Stage 1 + SF.
Please review my logs, 1st one is a 3rd gear pull, second is 2nd and 3rd. They look ok to me but I am no expert. There's some fine knock learning at lower rpm but I'm assuming this does happen at times. I also noticed that I don't have the AF ratio, just the other default one chosen by COBB. Hopefully my log is still useful without the actual AFR. AFRs look ok when I monitor them in the car: steady 11.1 under load.thanks!
https://spreadsheets.google.com/spre...IzYkE&hl=en_US
https://spreadsheets.google.com/spre...Q1NXc&hl=en_US
moonrider_99 is offline   Reply With Quote
Old 06-16-2011, 12:38 PM   #2
Cobb Tuning
Member#: 4803
Logs look good. You are not overboosting and knock situation is fine. There's some learned correction ("fine") at lower load, but that is nothing to be concerned about in this case (low load, single event).
Bill
Old 06-16-2011, 12:59 PM   #3
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
looks fine pretty conservative timing, But its an OTS map so cant complain
renosubby is offline   Reply With Quote
Old 06-16-2011, 03:56 PM   #4
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
Bill
Thank you for reviewing my log. I do enjoy my stage 1 + SF a lot. So how de we know the fine correction was a "single event"? Should I do more logs?
Old 06-16-2011, 05:09 PM   #5
Cobb Tuning
Member#: 4803
Well, the "worst" correction in the logs is -1.05. The decrement for the fine knock learning is generally 1.4 and the increment is .35. So, when you see -1.05, it was a single knock event (-1.4) with a subsequent (at some point) positive correction (-1.05). For fine knock learning, you want to look for repeatable multiple corrections for a given cell (the fine knock learning table is made up of distinct load/RPM cells). For example, for this car, -4.2 would indicate 3 knock corrections were learned in that cell.
In your logs, you have correction in more than one cell, but, as stated above, the "worst" correction is based on a single knock event.
Bill
Old 06-16-2011, 06:09 PM   #6
sc00ter
Member#: 117767
2015 WRX
CWP
OP, just fyi when i was running the COBB OTS stage 1 map I had slight knock learn just like your logs show with no adverse effects. The Stage 2 OTS map had similar knock learn.
Once I got protuned with the AP all knock is now completely gone.
However, until reading your logs I was unaware of two things:
1) At stage 1 your boost levels are what mine are at stage 2.
2) According to those logs you have a 7k RPM redline. Lucky bastard!
sc00ter is offline   Reply With Quote
Old 06-17-2011, 09:57 PM   #7
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
Thanks for the input, I actually dont care that much about the redline, I rarely shift above 6k. But I do agree that 16 psi is a nice feeling. :-)
Old 02-08-2012, 10:20 PM   #8
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
I'm bumping this up, I did two more logs in colder temperature, I see a small knock under load- should I be concerned?
3rd gear pulls, around 45F temperature, logged this week. Seems to be running okay- besides the small occasional fine knock correction.
https://docs.google.com/spreadsheet/...lI1QWdMX0NQeUE
https://docs.google.com/spreadsheet/...1E4VGZ0R2lkSnc
Thanks!
Old 02-09-2012, 12:16 AM   #9
snoopy_sti
Member#: 164942
2015 Porsche Cayman
Its fine knock learn and has decremented down in the second log so it probably pulled some timing at one point, its not hearing knock, so its adding the timing back in again. I would not be concerned.
snoopy_sti is offline   Reply With Quote
Ap Log for 2011 WRX - Stage 1, 93 - CYLINDER KNOCK - PLEASE HELP.......... thegarius AccessPort 3 04-09-2011 08:03 PM
Ap log review for noob thegarius Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-04-2011 12:05 PM
Please review my logs RichWRX04 Open Source Reflashes 6 10-26-2008 09:32 PM
Can someone please review my logs? dlh1999 Commercial ECU Reflashes 0 06-24-2007 05:46 PM
Untuned UTEC log - please review BadTrip Engine Management & Tuning 2 12-06-2004 02:48 PM
