Old 07-24-2002, 04:09 PM   #1
The_Triton
Member#: 18647
Default Need help with parts for screen mod
Hey all,
I don't want to spend $70 for someone to send me $10 in materials for grill screens on the WRX.
I've done the scoop screen and now I'm looking into the others.
I have an idea on creating a grill screen for the WRX OEM grill. I need to find out what type of a rubber edging I can use to go around the mesh. I'm thinking of making a grill screen that has an opening for the grill badge. But, I don't know what I can put around the edges of the screen to make it look clean and not scratch the paint.
I will also be using this technique for the bottom screen as well.
I've seen kits from companies that have a rubber edging around the mesh. Anyone know what that is or where to get it??? How does it look when it is bent around corners???
Thanx in advance for any suggestions.
The_Triton is offline   Reply With Quote
Old 07-24-2002, 04:11 PM   #2
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
You could try black silicone or using a very fine moulding strip.
Old 07-25-2002, 09:21 AM   #3
The_Triton
Member#: 18647
Would the moulding strip bend properly around the corners??? I want to make a screen that will mold around the top part of the bottom radiator area. I've seen screens that fit behind and would prefer to have the screen more visible.
Old 07-25-2002, 09:49 AM   #4
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
The moulding stip needs to be "creatively cut" to get it to bend properly. Look for threads on modifying the orange bumper vents. I know several guys have used moulding around the opening.
Hope this helps.
Need help with parts for 5 speed swap Ioku Subaru Conversions 2 01-26-2009 11:05 PM
need help with 05 RS grounding mod... aznguyjac Normally Aspirated Powertrain 29 01-09-2006 01:00 AM
Need Help with 04-05 GRILL MOD, NJ redeemedsoul Tri-State Area Forum 4 11-24-2005 01:45 PM
Need Help With Next Phase of Mods jetguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-31-2003 01:53 PM
Need Help with Part Numbers and Getting Parts... Xscreamer Normally Aspirated Powertrain 1 02-26-2001 10:48 AM
