Old 07-24-2002, 04:39 PM   #1
tonytiger
Member#: 3844
1993 Legacy 1.8
Default Will all pulleys fit any EJ?
The subject pretty much says it.
At my whereabouts it's almost impossible to find any parts for Subies. The parts which could be found are for 2.0 turbos.
Maybe, just maybe, it could be possible to acquire pulley that would fit 2.0 - that is why I ask.
Thank you.
tony
tonytiger is offline   Reply With Quote
Old 07-25-2002, 04:38 PM   #2
Section 8
Member#: 821
Most of the crank pulleys are the same. The 3 pulley N1 sets are different as far as the water pump pulley (I think number of splines)
I would email some of the venders selling them on this board and see if the pulleys for the turbo and your engine are the same, and which particular pulley is different and why, and go from there.
Did you just want a crank pulley or a whole set?
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 07-25-2002, 05:50 PM   #3
RaceCarRiot
Member#: 6542
1997 Ver IV
crank and alternator pulleys are the same...the older cars like the 1.8's have ONE less spline on the power steering pump gear that the pulley attatches to, so it won't fit. i was the first one to find this out the hard way.
RaceCarRiot is offline   Reply With Quote
Old 07-25-2002, 06:02 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
If the older cars have one less spline, then you could use the crank pulley and the belt would just have an extra space.
need help. will all this stuff fit? maxipad Interior & Exterior Modification 4 12-09-2007 03:48 AM
Will 17x9 ET48 fit on all 4 corners?? Wrekaro Member's Car Gallery 52 04-24-2005 07:02 PM
Will 17x9 ET48 fit on all 4 corners?? Wrekaro Tire & Wheel 7 04-20-2005 04:42 PM
will wrx pulleys fit an rs james_gt Normally Aspirated Powertrain 4 10-08-2002 12:59 PM
Will an Unorthodox Pulley fit on a 2.2L? Lone Wolf 75 Normally Aspirated Powertrain 13 11-14-2000 12:16 AM
