Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 06-17-2011, 01:19 AM   #1
07STi TX
Member#: 266749
07 sti
satan's white pearl
Default how do my logs look?
07STi TX is offline   Reply With Quote
Old 06-17-2011, 11:59 AM   #2
sc00ter
Member#: 117767
2015 WRX
CWP
You should get some logs with knock correction and knock learning as well.
sc00ter is offline   Reply With Quote
Old 06-17-2011, 02:24 PM   #3
07STi TX
Member#: 266749
07 sti
satan's white pearl
will do
Old 06-17-2011, 02:32 PM   #4
07STi TX
Member#: 266749
07 sti
satan's white pearl
added a new log. I have some knock but its only 1.4 is that bad or am I good?
Old 06-18-2011, 10:05 AM   #5
Cobb Tuning
Member#: 4803
That is a learned correction ("fine knock learning"), so it doesn't mean you knocking every time you see a negative value in the logs. It means that the ECU learned a correction in the past based on a perceived knock event and then applies that correction to a wider load/RPM range around that event. As you drive and load and RPM changes you'll pass through different cells of the fine knock learning table and the current learned correction is applied (as well as potentially learned).
That said, this is a minor correction in a low load cell. That is, occasional small corrections, especially those at low load, are nothing to be concerned about it.
Do my logs look ok? LegacyGt05 South West Impreza Club Forum -- SWIC 14 04-27-2007 06:31 PM
do my logs look ok? jordanscotty Engine Management & Tuning 9 11-22-2005 11:06 AM
how do my logs look? new map WRXout Engine Management & Tuning 26 03-22-2005 11:52 AM
how do my numbers look? black Proven Power Bragging 10 03-26-2004 06:07 PM
How do my plugs look? Quick WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-18-2003 07:49 PM
