Old 06-17-2011, 10:56 AM   #1
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Default Anyone have experience with Stack clusters? Other similar options?
I was looking closely at purchasing an ST8100, and was wondering if anyone has used one, or if you could recommend something similar? If you have used one, can you comment on the quality or ease of visibility at night?
I'm building a race/street car that currently has no cluster, and I've got a mismatched pile of various gauges (different sizes/face colors) that I've been looking to simplify. These two factors taken together make the price much easier to swallow. (My alternative would be autometer tach/speedo, and Defi boost/oil P/oil T/water T/fuel P The only function the stack cluster lacks is boost, which can be added, but I'd honestly rather have a standard analog boost gauge elsewhere on the dash anyway.
The one I'm looking at is: http://www.stackltd.com/st8100.html
CKxx is offline   Reply With Quote
Old 06-17-2011, 11:09 AM   #2
mug23
Member#: 97841
2005 STI Race Ready
OBP/Orange
Why not look at the AIM Sport's MXL data acquisition display system? They event have a plug-n-play for STI's and the prices are very within reach for us working class people. You can even acquire suspension data with additional sensors as well which is very nice. It's also compatible many aftermarket ECU's. This is the unit I'm going to look into.
The Stack unit is very nice and has been around for a while now but the unit looks very outdated too.
mug23 is offline   Reply With Quote
Old 06-17-2011, 11:18 AM   #3
nickrice20
Member#: 95153
2016 BMW F48 X1
Mineral White
I did not realize they had a plug and play for the stock STI ECU. I am sick of having to scan around the dashboard on straights to make sure all readings look normal this maybe something I look into as well.
Thanks
nickrice20 is offline   Reply With Quote
Old 06-17-2011, 11:35 AM   #4
mug23
Member#: 97841
2005 STI Race Ready
OBP/Orange
Thanks
Here's the link for it:
http://www.aim-sportline.com/pages/c...np_impreza.htm
Old 06-17-2011, 11:51 AM   #5
CKxx
Member#: 33458
93 RX7+09 Forester
Wow, very interesting. This isn't actually going into a Subaru (sold it, but I still come here because I trust the judgment/opinions of this forum over all others), but the car will have an AEM EMS, which is also one of the ECUs the MXL Strada interfaces with. This is particularly interesting because additional sensors can readily be added to the AEM EMS very cheaply (GM sensors). I need to research if the MXL would be able to display those values.
The only "con" I see is that the tach is digital. I would need to see one in person before I would be ready to give up an analog tach.
Old 06-17-2011, 12:34 PM   #6
nickrice20
Member#: 95153
2016 BMW F48 X1
Mineral White
Originally Posted by mug23 View Post
I appreciate it this will be on my list of purchases. It looks like just plugging into the OBDII port takes care of water temp & boost. I would have to buy three more sensors for oil temp, oil pressure, and EGT. Another question looking at the website I don't see a sensor for EGT. I know on my cart that was one of the things I monitored on my Mychron 3 so I imagine it is available just not listed.
Do you really use the tachometer in your car currently?
I know for me I can judge really well just by sound where I need to shift. Also the green, yellow, and then red display that you have preset for something like this really catches your eye.
Old 06-17-2011, 12:46 PM   #7
CKxx
Member#: 33458
93 RX7+09 Forester
You make a good point. I probably think I use it a whole lot more than I actually use it. My buddy used to have an S2k that I drove a lot and I never liked the tach. I guess that is what's stuck in my mind.
Has anyone used an MXL at night? My car is mostly used on the street and I was wondering if the blue glow gets offensive after a while?
Old 06-17-2011, 02:49 PM   #8
mug23
Member#: 97841
2005 STI Race Ready
OBP/Orange
I use this display in my race car so tach is not an issue with me as I would with my corner of my eye see the LED warning light as it comes closer to the redline. That's what I look for without having to take my eyes of the road.
Again, this unit is mainly design for racing and I have no clue about being used on the streets.
Old 07-28-2011, 12:26 AM   #9
CKxx
Member#: 33458
93 RX7+09 Forester
I thought I would give this one last "bump." I'd like to order the Stack cluster in the next month or so.
Old 07-28-2011, 04:04 AM   #10
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
There are a couple good suggestions in this thread:
http://www.norotors.com/index.php?topic=3970
Don't hang out on that forum too long. They're a bad influence on your RX7.
eastcoastbumps is offline   Reply With Quote
Old 09-26-2011, 12:05 PM   #11
CKxx
Member#: 33458
93 RX7+09 Forester
...funny you say that.
OK, I've gone an changed my mind. I've been trying to read/learn more about the AIM MXL Strada. Has anyone here used on reading from an AEM ECU?
EDIT: I'm skeptical of the whole process via AEM because I once had an AEM Serial Datastream gauge and using it was a total PITA. I believe this MXL uses the same method of connecting/disconnecting.
Old 09-26-2011, 02:23 PM   #12
jdmimpreza
Member#: 10644
2001 impreza
Blue Ridge Pearl
I use it in our race car here at work for data and telemetry. Serial port connection data stream into the AIM MXL is good clear and never fails. You will have to install a separate sensor for oil P but other than that it works fine.
jdmimpreza is offline   Reply With Quote
Old 09-26-2011, 04:47 PM   #13
CKxx
Member#: 33458
93 RX7+09 Forester
Just to be clear, you do use it connected to an AEM EMS?
Old 09-26-2011, 06:44 PM   #14
jdmimpreza
Member#: 10644
2001 impreza
Blue Ridge Pearl
Yes on the AEM EMS port. Just make sure you know how to set the channels on the AIM to output the data you are looking for.
Old 12-21-2011, 02:35 PM   #15
CKxx
Member#: 33458
93 RX7+09 Forester
One final bump...
I'm probably going to pick up the MXL in the coming few weeks.
Old 12-21-2011, 06:14 PM   #16
misterwaterfallin
Member#: 101091
Go for the MXL. The shift lights are all you need for a tach. I had one in my SM and loved it. They're also pretty easy to work with and come with some decent software
misterwaterfallin is offline   Reply With Quote
Old 12-27-2011, 11:17 AM   #17
CKxx
Member#: 33458
93 RX7+09 Forester
The only aspect I am concerned about is tweaking/logging with the laptop, while still needing a dash. When using RS232, can't you only have one or the other (dash or laptop) attached to the ECU?
EDIT: Also, how does the fuel reading work on the MXL? On the STACK unit, you can program it to interpret your factory level sensor.
Old 12-27-2011, 04:46 PM   #18
UP2MTNS
Member#: 112405
2004 WRX Rally Car
Silver, Black, and Decals
One final bump...
I'm looking at getting one soon too for my rally car, please update this thread with results/issues/etc, OK? (I've been told it will plug-n-play with my LinkG3)
and ditto on the fuel gauge connection....would like this to replace everything on my dash + gauges.
UP2MTNS is offline   Reply With Quote
Old 12-27-2011, 11:34 PM   #19
CKxx
Member#: 33458
93 RX7+09 Forester
I actually found a local race shop/stocking dealer of both AiM products and STACK. I spoke with a gentleman on the phone today about the two (Strada vs. 8100) and will be going to check out both this Friday (if my workload cooperates). He said they have at least the ST8100 installed in a car currently at the shop, so I may be able to check that out.
Old 03-16-2012, 02:15 PM   #20
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
found his F/S ad so...
5lipstream is offline   Reply With Quote
Old 03-30-2012, 01:31 AM   #21
CKxx
Member#: 33458
93 RX7+09 Forester
que?
I went ahead and ordered an MXL Strada and an AEM EMS v2. I snap a pic when it shows up.
Anyone have experience with "Bill Me Later" option? fuzzycuffs Off-Topic 16 04-09-2007 07:34 PM
Anyone have experiance with AudioBahn? Turk Car Audio, Video & Security 5 04-17-2001 08:32 AM
Cusco Rear Lower Arm Bar ...anyone have experience with this? kevinsUBARU Technical Forum Archive 6 09-16-2000 10:15 PM
Anyone have experience with Hercules tires? kevinsUBARU Technical Forum Archive 1 09-16-2000 12:09 AM
Anyone have experience with Yokohama AO32R road race tires JDM5LugHatch Technical Forum Archive 10 06-13-2000 07:41 AM
