Old 06-18-2011, 05:18 PM   #1
jonnies
Member#: 84430
2006 wrx
Default 4 points harness safe?
Hey guys i have searched a bit here after i bought a pair of takata 4 point harness...... and i just might have discoverd i actually downgrade from oem belt right?(sub marine in case of accident)
i have a wrx 06 heavly mod great pair of bride stradias but no cage. its my weekend car and track car.
so is it safe to use the takata 4 point or am i better with the oem belt?is there any solution or better just sell it?
thanks
jonnies is offline   Reply With Quote
Old 06-18-2011, 05:37 PM   #2
chongl
Member#: 187694
2009 GTX3076 WRX
520whp on E85
4 point I would trust would be Scroth ASM....it's legal for street use if you use the release that has "Press" on it in case of emergency.
chongl is offline   Reply With Quote
Old 06-18-2011, 06:29 PM   #3
Carter
Member#: 156708
2004 Mini Cooper S
Invader 125 Shifter Kart
This. I run Schroth Rallye 3 ASM in my rallycross beater, and they are wonderful for street and racing.
Carter is offline   Reply With Quote
Old 06-18-2011, 08:03 PM   #4
lude4life13
Member#: 255027
2003 WRX
I wouldn't trust it. Takata 4 points are more for show. you can add the sub strap if thats availabe, or get another harness. You should definitely go get a roll bar too if you plan to have a harness. Also, make sure you disconnect your airbag when you are using your harness, as they are not made to work together and can actually harm you.
lude4life13 is offline   Reply With Quote
Old 06-18-2011, 10:43 PM   #5
jonnies
Member#: 84430
2006 wrx
yeah i bought the takata on impulse (and they look goood!!!)
but i guess i will use the oem belts wont risk submarine in case of accident
thanks guys
Old 06-19-2011, 12:58 PM   #6
c9ollie
Member#: 251861
2002 STI Wagon
thanks guys
I actually work at Takata and I test seatbelts and airbags. The submarining issue can be resolved with the addition of a 5th or 6th anti submarine strap. The issue that arrise with a full harness is the massive neck deflection that occurs in an impact. Most retractors today are an energy management type that pays out the belt in a controll manner to guide you into the airbag. When you are fully strapped in your body isn't allowed to move much. In an impact your torso stays still but your neck snaps forward. If you are going to run a harness I recommend a HANS device and a helmet. Those are impractical for street use. You could always keep both belts in the car. 3point for street and 4/5/6 point, HANS, and helmet for track.
c9ollie is offline   Reply With Quote
Old 06-19-2011, 08:55 PM   #7
growling_boxer
Member#: 165744
2000 LGT
2007 STi
not sure who you track with, but NASA recently changed their rules. originally, they had decided to ban all 4-point harnesses over this winter (it used to be any DOT-approved 4-point was allowed). as of the beginning of May, they loosened the regulations back up a little allow certain 4-point harnesses, but it is very limited. so, you might want to check with whoever you are doing your track days with before installing any 4-point.
growling_boxer is offline   Reply With Quote
Old 06-19-2011, 10:46 PM   #8
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
so 4 points work best when they are 5 or 6 points
rjrutzky is offline   Reply With Quote
Old 06-20-2011, 09:51 AM   #9
c9ollie
Member#: 251861
2002 STI Wagon
Yeah pretty much. The 4 point harness uses the same cam lock buckle as the 5 and 6 point harnesses. The 5th and 6th antisubmarine conversion straps can be bought from Takata for $57 and 107$ respectably. The cam lock buckle can accommodate the extra straps.
Old 06-20-2011, 01:08 PM   #10
Web Foot STi
Member#: 39086
2004 STi
Boy, Those are expensive crotch straps: http://www.pegasusautoracing.com/gro...upID=HARNLLSUB
I am NOT saying that you should mix and match harness parts between manufactures though. Even if they sorta fit. They are a system.
I have a 6 point and a harness bar for the track/Auto-X/Hillclimb. (With a 6 point the anti-submarine strap can bolt to the front seat belt mounting points with longer 10.9 fasteners. For a 5 point you have to punch a bolt hole in the floor pan.)
The OEM belts are still serviceable per SCCA Solo II Stock rules.
Web Foot STi is offline   Reply With Quote
Old 06-21-2011, 07:54 AM   #11
c9ollie
Member#: 251861
2002 STI Wagon
Yeah they are! I dont even get an employee discount.
Old 06-21-2011, 08:23 AM   #12
delongedoug
Member#: 124113
and beyond!
Aren't the substraps supposed to come ~20* back from vertical? Not forwards.
EDIT: perfect picture
Long story short, I wouldn't run a 4 point for anything but autoX.
delongedoug is offline   Reply With Quote
Old 06-22-2011, 12:33 AM   #13
Web Foot STi
Member#: 39086
2004 STi
It's not the vertical. "6-Point Anti-Submarine Belt should be anchored at an angle of 20 degrees behind the Chest Line as measured from the intersection of the Chest Line and the lap belt buckle. Mounts should be approximately 8 to 12 inches apart (approximately located under each hip and as close to the body as possible). Two routing holes in the seat or a special seat mount may be required." http://simpsonraceproducts.com/safet...ing-positions/ .
With my short legs the forward drivers seat mounting points are in about the right place, but running Stock one cannot modify, or change drivers the seat. The straps have to run around the seat squab. The crotch strap keeps the lap belt down on the pelvis when the shoulder harnesses are cinched so things start out in the right spot. One does the best that they can and hopes that Subaru did right by the design of the seat pan. If only Subaru had put a belt pass thru like they did in the seat back.
wtt: sabelt trw 5 point camlock harness for sabelt, sparco, or momo 4 point harness chompleh TXIC Private Classifieds 21 09-20-2008 03:50 PM
Harness Bar 225$ , Sparco 4 point harness 50$ treicoaie Interior/Dressup/Audio & Security 8 11-28-2007 04:46 PM
Harness bar 225, Sparco 4 point harness 50$ treicoaie SCIC Private Classifieds 1 11-02-2007 10:04 PM
FS: M1 harness bar and SPARCO 4 point harness SPIDEYWrX Interior/Dressup/Audio & Security 7 02-03-2007 12:14 PM
Schroth 4 point harness for harness bar MastroWRX Interior/Dressup/Audio & Security 2 06-15-2004 08:52 AM
