Old 06-18-2011, 08:11 PM   #1
PoZeR
Member#: 114202
2006 FXT E85
LEZWAGN
Default 2006 Forester E85 / Mustang Dyno
Ambient Temp: 80 F
Elevation: 863ft Above Sea Level
Weather:hot
2006 Subaru Forester
Tuner: me
Dyno Info:Mustang Dyno
Peak HP at RPM: 336 WHP@~5800PM
Peak Torque at RPM: 352 WTQ@~4500RPM
Target Boost: 20PSi at 4K bleeding down to 16.7psi by redline
Ran in 4th gear
Target AFR: 7.5:1 (E85)
Fuel: E85-
Engine/Power Modifications:
257 Block
OEM 2007 Crank
OEM Rods
Mahle 8.1:1 forged pistons
ARP studs
11mm oil pump
Deatsch 1300 CC Injectors flow chart says 1380cc
Walbro 255
P&L Motorsports big maf housing
2003 JDM Legacy RS25 PHASEII heads, Brings compression up to 9.5:1
07 Sti cams with sensor notch extended.
SBR GT-11
Synapse 40mm EWG
GM EBC
SPT 3" cat back
Invidia 3" catless V2 D
STI TMIC
OEM BOV
Koyo STi Radiator
Samco hose kit
165deg thermostat
Flex-a-lite #420 fan
Driveline Modifications:
Stock Forester 5 speed missing 3rd
This is totally untuned on stock AVCS and Ignition map.
PoZeR is offline   Reply With Quote
Old 06-18-2011, 08:52 PM   #2
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
Good stuff.
What are the specs on that Slow boy? Not familiar with those turbos. With proper tuning you should be picking up gobs of power.
VladiWrX is offline   Reply With Quote
Old 06-19-2011, 09:07 AM   #3
PoZeR
Member#: 114202
2006 FXT E85
LEZWAGN
SBR-GT11 is a stock location BB turbo and uses that Garret GT30R-11 cartridge.
Compressor side:
• 52 trim
• 2.17 inducer
• 3.00 exducer
• 50 lb/min compressor wheel
Exhaust side:
• 2.11 exducer
• 2.22 major
I will have the trans installed in about 3 weeks then I can get it tuned correctly the goal is 22psi daily nothing to overboard I want the turbo to last awhile.
Just under 17psi at redline I was impressed with the numbers.
Old 06-21-2011, 09:49 AM   #4
rexblake
Member#: 178426
2010 S4
Gray
Those are great numbers! Especially with an STI tmic! Nicely done, I bet it's very fun on the street.
rexblake is offline   Reply With Quote
Old 06-21-2011, 04:47 PM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
i'll tune it
Old 06-21-2011, 05:03 PM   #6
Hardrvin
Member#: 63647
05 FXT
12.5 @ 109
So you converted to top feed?
Hardrvin is offline   Reply With Quote
Old 06-22-2011, 08:26 PM   #7
PoZeR
Member#: 114202
2006 FXT E85
LEZWAGN
Top feed came on my 06..
Thanks for all the reply's.
"Phatron" I wish man I have seen your tunes. !!!!!
Here is the build thread if anyone is interested.
http://fast16v.com/fxt/
Old 06-29-2011, 03:04 PM   #8
Onyx10
Member#: 138797
'06 STI
Get Junior to wake up that beast!!!
Onyx10 is offline   Reply With Quote
Old 06-29-2011, 03:51 PM   #9
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Bring that thing down to P&L I will tune it for ya!! I love fast XT's!!! I have a pretty nice CGM 30r down here now
Junior2JZ is offline   Reply With Quote
2006 STi - AMS HTA86 Turbo Kit, AMS Longblock, 618 whp MUSTANG DYNO AMS Proven Power Bragging 38 04-23-2011 10:20 PM
PHATRON/SVT_WRX TUNED MUSTANG Dyno Results: 308WHP/323WTQ E85 SVT_WRX Proven Power Bragging 41 01-21-2011 01:00 AM
E85 dyno charts, post em up! E85 army dynos wrxkyle Proven Power Bragging 2 11-15-2010 08:47 AM
Dailydevil dynoes does decent on Mustang dyno. reddevil Proven Power Bragging 7 09-25-2009 08:40 PM
Latest dyno results: 145hp, 144ft-lb on Mustang dyno Patrick Olsen Normally Aspirated Powertrain 39 08-27-2008 03:19 AM
