Old 06-19-2011, 12:37 PM   #1
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
Question Timing Belt Replaced & now it won't start...
So yesterday i tackled the water pump and timing belt job. I had picked up the gates timing belt kit and a tomei guide. Taking everything off went rather smooth other than the radiator spraying fluid EVERYWHERE, and when i started taking off idlers and what not i realized that they were indeed pretty worn, would just spin really easy. The tensioner was leaking and there was slight play in the belt buuuut all in all, in good shape. Anyway, I was working with my brother-in-law (chris) and his cousin who had just done this job on chris' car in the past six months (INCREDIBLY SUCCESSFUL TOO), BUT before i realized i was supposed to line everything up (TDC), i was told to take off the tensioner and that was it, this was how the cam pulleys n crank sat when i pulled it off:
this was what the tensioner looked like:
sooo yeah, i freaked, but took pictures so we could put all back the exact same way, buuuuuuut they said that they lined up all the pulleys the way the book said and so we did that, we tried to follow the book in correct rotation as well as marking placement. In the end, all of the markings were spot on, we put on the belt and all the the teeth were spot on, lines on the belt matched up and everything. We turned the engine over until all the belt lines came back around and the whole time, all the markings lined up just right...We figured it was all good baby, buuuuut, we were mistaken
put everything back together and this is how shes acting:
i know the video is crazy short and i can take a longer one if need be, buuut thats the just. We can't figure out b/c just this morning, before we took it all apart, it fired right up, ran perfect, and now....this.
They keep saying that you dont hear any knocking or anything so its not the timing, but i can't grasp what else it could be when all we did was mess with the timing components
I have been so mad at myself b/c i am that guy that follows the diy or book to a T while doing a job for the first time but this time...i didn't, i allowed somebody else to guide me and now my car wont start
My dad and I checked for fuel and spark last night and its getting both, at least in the front passenger plug (dunno which cylinder that is).
I did post this locally in the maic and i dont know if there are rules against me posting this here too but the only person who responded locally said my valves were bent and obviously that would be crushing n i hope not, so before i begin tearing it apart i would love some other ideas for troubleshooting
Thanks,
Tyler
God&Sme is offline   Reply With Quote
Old 06-19-2011, 02:25 PM   #2
02redwagone
Member#: 87067
02 Old but tasty
SRP
As I understand it you line up the crank first so things don't bash into one another. I used this great guide with optimal success:
Try turning the crank to line up the crank marks, then redo all else to their proper positions.
The bottom line is that it is your timing since that is the variable in it running or not. You need to redo it properly and pray. Dont listen to anyone not on that video.
02redwagone is offline   Reply With Quote
Old 06-19-2011, 06:58 PM   #3
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
Thank you, I needed to hear that. Going to keep praying and take it apart tomorrow. =D
Old 06-20-2011, 02:28 AM   #4
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
Wow, so watching that video I immediately realized what I did wrong. I set the crank upside down. I used that N letter as the timing mark n not the line on the other side. As soon as I saw him line it up I knew.
What I don't know is the damage that i could have or did cause. I plan on taking it apart in the AM but don't know if it is already broke or not...any idea?
Old 06-20-2011, 06:46 AM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
timing is wrong period.
you'll be lucky if you did not bend any valves.
Old 06-20-2011, 09:23 AM   #6
rkramer
Member#: 118209
2015 WRX Limitec
What I don't know is the damage that i could have or has caused. I plan on taking it apart in the AM but don't know if it is already broke or not...any idea?
So it sounds like you are 180 degrees out. If thats the case, you should be fine, no damage. You just ended up with your exhaust pretending to be an intake, and the actual exhaust trying to go out your air filter...
Old 06-20-2011, 12:35 PM   #7
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
i love your optimism!!!! I just switched em and am in the process of putting it back together right now. prayers being lifted
Old 06-20-2011, 08:27 PM   #8
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
close her down, shes all fixed. Just turned the crank to the right position, aligned all my cams and she runs perfectly again =D
I had left the turbo res. cap off b/c to get the air out
Old 06-20-2011, 08:47 PM   #9
farmboss
Member#: 252324
04 STi
JBP
Sweet man
farmboss is offline   Reply With Quote
Old 06-21-2011, 11:23 AM   #10
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
Purring like a kitten. Nice recovery.
WRXSD is offline   Reply With Quote
Old 06-21-2011, 07:30 PM   #11
bugeyein you up
Member#: 285448
2009 WRX
Dark Grey Metallic
beware of the skipping teeth and such. pain in the a**!
always make sure its tdc!!!
bugeyein you up is offline   Reply With Quote
Old 06-21-2011, 10:28 PM   #12
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
Originally Posted by farmboss View Post
Sweet man
YOU KNOW IT!
O.M.Gee golly, haaaa, i know right!
yeah, the tdc lesson was learned indefinitely! I picked up the tomei timing guide n made sure i had 1mm in b/t all the other timing guides sooooo we shouldn't see any skipping of the teeth
Old 08-09-2011, 01:06 AM   #13
Scoobie200
Member#: 290892
97 Impreza L
Hey I just replace the timing belt, water pump, crank seal on my 97 impreza 2.2. Everything align with the mark on the cam. Go turn the car when everything was finish an it wont turn on only spin go check the timing belt and they out of align again which make sense bc the car is spinning and not turning on. First time doing the timing belt on a subie didn't feel like paying $400 for it. I miss my car is being 3 week. I want to drive her already lol. Any help would be much appreciated thanks
Scoobie200 is offline   Reply With Quote
Old 09-01-2011, 02:04 PM   #14
NewShockerGuy
Member#: 40736
2005 WRX STI
What does TDC mean when refering to the above posts? I am getting ready to replace my timing belt next month.
Thanks,
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 09-01-2011, 02:11 PM   #15
wcjuggalo
Member#: 167772
03 wrx
white
top dead center, in reference to the #1 cylinder.
wcjuggalo is offline   Reply With Quote
Old 09-01-2011, 02:13 PM   #16
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
tdc= top dead center
jerbull88 is offline   Reply With Quote
Old 09-01-2011, 05:17 PM   #17
fastwrx25
Member#: 126441
03 bugeye
dbl post
fastwrx25 is offline   Reply With Quote
Old 09-01-2011, 05:17 PM   #18
fastwrx25
Member#: 126441
03 bugeye
follow meatys youtube timing belt videos step by step, don't over think the process. everything is in the video, down to torque specs.
watch the video a cpl times so you understand what is going on, then go for it.
I just did mine last week, was nervous about messing up but its actually very easy and straight foward.
Old 09-09-2011, 12:13 PM   #19
Boheefus
Member#: 259280
Timing belts/chains can be the easiest job in the world...They can also leave you scratching your head and throwing ratchets because you weren't paying attention Being 180deg. out is the most common, though I have seen quite a few shade tree mechanics really screw things up. The key is to read the manual (pics/vids/whatever) or have someone, that has successfully done it before, show you how.
Boheefus is offline   Reply With Quote
Old 09-09-2011, 01:10 PM   #20
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
Key words "someone who has done it before"
Even then, I personally would much rather do it all myself. I made the mistake of letting someone who "successfully did it.before" help n the end result was 180 out. Had I taken my time, did it myself, that would not of happened. But ya meaty diy n video are perfect, everything u need =D
Old 09-09-2011, 11:49 PM   #21
nightwalker
Member#: 157012
btw, if that's oil leaking out from the tensioner in the top pic, I highly recommend you replace it.
nightwalker is offline   Reply With Quote
Old 09-10-2011, 12:42 AM   #22
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
I imagine u are referring to my pic, n if so, in the original post I said I used the gates timing kit which includes a new tensioner. But ya the other tensioner still had good tension but was clearly getting worse.
Old 09-10-2011, 03:00 AM   #23
nightwalker
Member#: 157012
Good to go
Old 02-02-2013, 10:13 AM   #24
kirbykirb
Member#: 183596
2005 WRX/9-2x
Obsedian Black Pearl
Oh god, what a scary thread. I'm happy for you, OP that you didn't destory the engine
I cringed. :C If there was a horror story about automotive quandry, this would be a chapter w/ a good ending.
kirbykirb is offline   Reply With Quote
Car died while driving, and now it won't start. NEED HELP KpT KiM Newbies & FAQs 27 08-03-2010 07:09 PM
Help, brought 05 STI back to stock, now it won't start imprzya Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 36 05-09-2008 02:39 PM
Ran fuel dry, now it won't start? 02 2.5RS Spitulski Normally Aspirated Powertrain 30 10-22-2007 01:02 PM
Replaced water pump and now it won't start K Rock Impreza Normally Aspirated Powertrain 28 11-27-2004 09:35 PM
my car got broken into...now it won't start hoostw Bay Area Impreza Club Forum -- BAIC 2 08-09-2004 02:20 AM
