Old 07-24-2002, 08:49 PM   #1
Jay Goldstein
Member#: 1851
Default MAF replacement and resetting ECU
A new MAF sensor was installed in my '99 2.5RS four days ago. Since then, I've noticed that the car doesn't seem to accelerate as smoothly as it did before. As far as I know, the ECU was not reset after the MAF was replaced.
Should the ECU be reset when a new MAF sensor is installed? If the answer is "yes" then I would like to do it myself. I understand that all that is needed to reset the ECU is to disconnect the negative battery terminal, wait for 30 minutes, reconnect the terminal, then drive the car normally. Is this correct?
Jay
Jay Goldstein is offline   Reply With Quote
Old 07-24-2002, 10:05 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I'd reset it.
This is the way I've always done it
NOTE: Do this on a "cold" engine. Leave it sit overnight and do it in the morning.
1. Disconnect the negative battery terminal cable for 45-60 minutes.
2. Reconnect the negative battery terminal cable.
3. Turn off all your accessories.
4. Start the car, but DO NOT touch the throttle at all.
5. Let the car idle for 10-15 minutes, or until the car is at normal operating temperature. Again, do not touch the throttle.
6. Turn the ignition key to the "OFF" position. That's it
Legacy777 is offline   Reply With Quote
Removing bov and resetting ecu, do I need a new tune? sirmasterdeck Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 11-28-2009 04:00 PM
Tune and reset ECU JuggernautTCW Engine Management & Tuning 5 03-02-2008 09:55 PM
Replaced TMIC, do I need to reset ECU? Superorb Commercial ECU Reflashes 10 05-07-2007 10:39 PM
Knock and Resetting ECU Psipwrd UTEC 7 08-10-2006 03:47 PM
ecuTEK reflash and resetting ecu? axion7606 Newbies & FAQs 6 01-19-2004 05:03 PM
