Old 07-24-2002, 08:34 PM   #1
jacobhorn
Member#: 5122
1998 Legacy GT LTD
'02 HD Softail Deuce
Arrow Will WRX Seats Fit my GT?
jacobhorn is offline   Reply With Quote
Old 07-24-2002, 10:57 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Yes. For the Open Track Challenge we swapped the better seats from my co-driver's WRX into my car. The only difference is that for some reason the Legacy uses 3 bolts on the inner seat rail - one at the front, one at the rear, and one about 3 or 4" forward of the rear bolt. I'm not sure what the purpose of that third bolt is, as neither the GC8s nor the GDAs use that 3rd hole. As a result, you end up with an empty spot (there's no carpet there).
Oh, and the WRX seats sit noticeably higher than the Legacy seats. I think the WRX seats in their lowest position might be higher than the Legacy seats in their highest position. Normally I sit bolt upright (as upright as the seat will go), but in order to fit with my helmet on I had to recline the WRX seat one or two clicks.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 07-24-2002, 11:58 PM   #3
jacobhorn
Member#: 5122
1998 Legacy GT LTD
Arrow
Thanks Pat! Did remove the Legacy seat and brackets, and then install the WRX seat and brackets?
Do I need the WRX seat brackets?
Jacob
Old 07-25-2002, 12:05 AM   #4
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Jacob,
The inner rails cannot be removed from the seat. So yeah you need the rails and everything.
I was goin to get some for my legacy......but the guy didn't have the brackets.
Legacy777 is offline   Reply With Quote
Old 07-25-2002, 12:06 AM   #5
Prez&SUS
Member#: 18575
Just unbolt the seats from the floor, in the Legacy there should be a bolt at each corner (where the bracket meets the floor) exept in the center rear, where like Pat said, there are two bolts.
Five bolts total per Seat, and if you have power seats dont forget to un plug them, and the drivers seat belt has a plug too.
(the extra bolt is probably for a sturdier seat belt mounting, although i dont know why the impreza doesnt have it.)
Prez&SUS is offline   Reply With Quote
Old 07-25-2002, 12:23 AM   #6
jacobhorn
Member#: 5122
1998 Legacy GT LTD
Arrow
Great, thanks. I think I'll buy the WRX seat.
I only hope it's not too tall for my 6'2" body
Thanks for the feedback.
Anyone have pics of WRX seats in their legacy GT?
JH
Old 07-25-2002, 11:06 AM   #7
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
jacobhorn - I believe Charle has a set of those seats he just recently re-upolhstered into the GT cloth.
GTBGUY is offline   Reply With Quote
Old 07-26-2002, 11:01 AM   #8
cfwdfw
Member#: 5046
'97 Legacy gt 5 spd
Deep Saphire Blue Sedan
Hi Jacob,
Yes I do have two wrx seats ... and they do bolt in as Pat noted ... and I've had both mine in .... and Pat is correct they are noticeably higher ... and I think you might find it a real tight fit under the steering wheel ...
I'm gone this weekend ... but if you want to give it a try before you buy ... let me know ...
If you do get the seat ... you and I will need to find the female set of belt brackets off of a 96-98 subaru seat (dealer says they are generic for those years) ... to hook up to our current seat belts ...
I will be calling aarons auto today to see what I can come up with ... Pat ... how'd you deal with this? probably have a 5 point harness?
and if you want pictures ... when I reinstall them ... I'll post pictures ..
oh ... and one of the extra bolt holes on the right rear for the drivers seat ... for securing the stock amp for the gt's ...
Charlie
cfwdfw is offline   Reply With Quote
Old 07-26-2002, 11:45 AM   #9
jacobhorn
Member#: 5122
1998 Legacy GT LTD
Arrow
Thanks for the info Charlie! I decided that my 6'2" body would not work well with higher seats in my Legacyk, especially with a helmet on. I am going to go with an aftermarket seat, even though it is much more expensive than the two WRX seats. Thanks for the offer to try them out, that would have been a great help. I hope everything is going well for you and your son, and that your (safely) testing your new-found track skills on the road!
Jacob
Old 07-26-2002, 12:30 PM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Charlie,
We swapped the female receptacles on the seats. They aren't an exact fit - the two different seats use somewhat different methods of "locking" the receptacle in position, but it wasn't any big deal.
Pat
Old 07-27-2002, 01:16 AM   #11
cfwdfw
Member#: 5046
'97 Legacy gt 5 spd
Thanks Pat ...
I'll take a close look at the female ends tomorrow ... I take it they dissassemble from the mounting arm that bolts to the seat ... I know I can switch over the entire arm ... and those are slightly different as well ...
my goal was to be able to swap out the seats without having to swap the female ends between the legacy and wrx seats ...
Jacob ..
you bet we're applying our polished driving skills ... and I worked on mine some more at the evolution school this week too...
Charlie
will wrx braces fit my 2.5i??? welli04886 Newbies & FAQs 3 03-30-2008 01:15 AM
will wrx seats fit 92 legacy sedan? spdracr00 Legacy Forum 3 08-30-2006 11:11 AM
Will WRX pedals fit my '97 Impreza? tobin73 Interior & Exterior Modification 3 12-16-2003 01:06 PM
Will WRX seats fit into a 99 RS? canned meat Interior & Exterior Modification 1 05-05-2002 12:25 AM
Will WRX seats fit right into my L? annointed Interior & Exterior Modification 2 08-05-2001 12:51 PM
