Old 06-20-2011, 09:45 PM   #1
urdnotWRX
Member#: 267348
2009 WRX
Default High Altitude and ideal AP Octane Map
I've done some research on this and have found differing results. I live at about 6000' and normally run a Cobb base 93 Octane map on my AP, while running 91 octane premium with those small octane boost bottles (for 15 gal) from the gas station to boost my octane to I'm assuming > 93. First, what's an estimated octane boost that I should expect from those bottles (they don't give any indication on the bottle)? Second, am I okay to run 91 from the pump on a 93 map at this altitude? Is there a rule of thumb conversion?
Thanks!
urdnotWRX is offline   Reply With Quote
Old 06-21-2011, 04:46 AM   #2
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Do some logs and check to see if you have any knock.
What brand of octane boost is it? You should get a map made for your car specifically rather then trying to eek more power by running a 93 octane map on a 91 octane car.
project_skyline is offline   Reply With Quote
Old 06-21-2011, 07:33 AM   #3
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
Thanks!
Hell, at your altitude you could run 89 octane and probably not notice it lol. In all seriousness though, I'm not sure all 91 octane is actually 91 octane. I think cali 91 is really 87 with a 91 sticker on the pump
fastblueufo is offline   Reply With Quote
Old 06-22-2011, 02:02 PM   #4
Cobb Tuning
Member#: 4803
I would recommend running the 91 octane mapping if you only have 91 octane fuel available. We haven't done any testing with off the shelf octane boosters, but typically they will not add any significant octane points to your tank of gas.
- Ian
Old 06-24-2011, 12:17 PM   #5
sc00ter
Member#: 117767
2015 WRX
CWP
Don't waste your time on those octane boosters. Since 91 octane is readily available here in CO while 93 is not, just be safe and run the 91 octane tune.
If you really want your car to run well with good power numbers, save the money you are spending on octane booster and use it to get a protune from Harvey (TheBoostCreep) instead.
sc00ter is offline   Reply With Quote
Old 06-25-2011, 09:09 PM   #6
urdnotWRX
Member#: 267348
2009 WRX
Thanks everyone,
I'm setting up something with them now.. I'm thinking of doing full exhaust + tune once I find a low and quiet setup I like, instead of spending the money on a stock tune and a few months down the road doing mods. That's mainly why i've been using the octane boost and holding off on the tune.
AP Stage2 93 octane map and Husky 94 gas... thejean Western Canada 13 04-04-2006 09:46 PM
utec maps for high altitude jdubb12 Engine Management & Tuning 6 06-10-2003 05:09 PM
High altitude UTEC maps? Ski Man Engine Management & Tuning 5 05-23-2003 09:35 AM
UTEC: 91 Octane, Altitude and Maps superg Engine Management & Tuning 3 10-25-2002 03:44 PM
Lower octane at high altitude? Eric Gagnon Normally Aspirated Powertrain 2 11-29-2000 12:51 AM
