Old 06-20-2011, 11:11 PM   #1
yellowspec
Member#: 177473
03 wrx spec r1
yellow
Default cobb ap dyno not working
I have a 03 wrx with vf39 and supporting mods. I have a clark turner tune runs awesome. I went to try the dyno and wouldn't work. My thing is I have a 93 jdm wrx 5 speed trans and rear diff. In 5th gear it tells me I'm in 4th. So I figured it was because it reads different anyone shead some light on this ?
yellowspec is offline   Reply With Quote
Old 06-21-2011, 01:14 PM   #2
Cobb Tuning
Member#: 4803
As long as the transmission is fully integrated with the wiring harness and you have a working vehicle speed sensor there should not be an issue. Can you describe what is happening in detail? Are you completing the test? The AP will tell you when it is finished measuring power if you back out of the pull before the test completes it will not finish.
Old 06-21-2011, 07:19 PM   #3
yellowspec
Member#: 177473
03 wrx spec r1
yellow
It won't even start I try. 3rd gear pull and won't start. Everything is hooked up and working
Old 06-21-2011, 07:27 PM   #4
Cobb Tuning
Member#: 4803
The dyno function relies on the ECU detecting an accurate gear position, which is not always possible after a gearing or tire height change. Fortunately our software has the table definitions for adjusting the gear determination tables, as the ECU does it by comparing engine speed and vehicle speed when the neutral position switch indicates the vehicle is in gear. If you were to send Clark specific logs of your car in 1st, 2nd, 3rd, 4th and 5th that each include RPM and vehicle speed, he can use those to back-calculate the revs/mile and then the adjust the table as necessary :-D
Best regards-
Lance
Cobb AP V2 not Synching with AP Manager SUBYDOODIE AccessPort 8 09-10-2011 03:37 AM
Cobb AP V2 not working sb04wrx AccessPort 2 06-12-2011 01:04 PM
Cobb AP dyno compairison boost4life AccessPort 6 01-21-2011 12:00 AM
Cobb AP V2 not working properly SAM490 AccessPort 4 07-30-2008 07:23 PM
Help: Cobb AP will not work with my car silvsteve AccessPort 3 02-04-2007 05:23 PM
