Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 07-24-2002, 11:19 PM   #1
cvcsmkr
Member#: 10465
91 Syclone
Only 1 color
Default Where does the brakcet for intake go??
i have been searching for the past hour and cant find anything.
does anybody know where do you connect the bracket to to hold up the new intake?
a picture would be helpful
cvcsmkr is offline   Reply With Quote
Old 07-24-2002, 11:20 PM   #2
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
What intake do you have? It'll help us to help you.
Keiho is offline   Reply With Quote
Old 07-25-2002, 12:29 PM   #3
cvcsmkr
Member#: 10465
91 Syclone
Only 1 color
i am not sure its a tube style, like any of the ones for the post-1999 impreza's. except i have a maf adapter for the filter.
it has a bolt welded to the bottom before it makes the 90 degree turn. and has a bracket that is about 6-8" long, each end is bent. one of the ends is about a 20 degree the other is about a 45 degree.
thanks
i am looking for pics but i cant find any
Old 07-25-2002, 01:21 PM   #4
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Still not sure what intake you have...
But that bracket probably attaches to this other "bracket" like thing on the passenger side strut tower wall, or it could attach to the stock brace on the motor for the stock intake system. There should be this tower looking thing on the left side of the motor.
Old 07-25-2002, 01:41 PM   #5
cvcsmkr
Member#: 10465
91 Syclone
Only 1 color
do you mean this bracket if so.
it will nott attach to that bracket.
what do you mean as far as bracket on passeneger side tower wall. thanks...chad
Installing mechanical boost gauge. Where does the little restrictor pill go? lennyTR Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-05-2008 07:54 PM
Where does the 2.5RS Nameplate go? formula91 Interior & Exterior Modification 2 10-02-2006 01:57 PM
Cant tell from the picture in the manual. where does the engine ground go? MrSaabaru Subaru Conversions 3 08-15-2005 10:43 AM
where does the missing unichip wire go? WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-02-2002 12:59 AM
where does the filter for the ganzflow go? Blindeye_03 Normally Aspirated Powertrain 4 04-04-2001 10:42 PM
