Old 06-21-2011, 11:17 PM   #1
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Default Simple Green Engine Bay Cleanup (Non-Subaru Content)
I "detailed" my engine bay tonight. Basically just followed what thousands of other people have done and posted online:
  • Started with a cool/slightly warm engine (should be able to touch it)
  • Low pressure rinse to moisten everything (garden hose on an extremely low setting)
  • Sprayed on Simple Green liberally (I did not dilute it at all)
  • Let sit for a few minutes
  • Lightly scrubbed with a long bristle, soft brush (general scrub only, not necessary on a relatively clean engine bay)
  • Rinsed off with water (garden hose, again on low setting)
  • Wiped dry with a towel
I did not cover anything. I tried to avoid spraying water directly onto electricals and the cone filter, but everything got wet to a point, and no problems were encountered. According to the time stamp on my photos, the entire process (including taking photos) took 16 minutes. Very quick and easy, and I am happy with the results.
I did my WRX first, but I did not take any photos. It wasn't that dirty to begin with, so the change wasn't that drastic (but it really did come out looking like new afterwards). I did my wife's 07 Civic next. It has never had the engine bay cleaned. Not perfect after, but still looking very god. Before/after photos below:
I did not put any finisher on the plastics to keep them shiny. I did take the photos when they were still moist, so I'm sure they'll look a lot more dull once they're completely dry, but I'm not really concerned with that. Looks nearly as good as new and the engine bay has only had one cleaning in 4 years!
xluben is offline   Reply With Quote
Old 06-22-2011, 01:40 PM   #2
seekndestroy19
Member#: 209358
06 Sti
nice. im so tempted to do this next wash but dont want corrosion or water getting inside electrical connectors
seekndestroy19 is offline   Reply With Quote
Old 06-22-2011, 01:58 PM   #3
The Duke
Member#: 264877
You drive your car in the rain...
The Duke is offline   Reply With Quote
Old 06-22-2011, 02:10 PM   #4
besthaticouldo
Member#: 279660
wow. those are pretty stunning results. looks great.
besthaticouldo is offline   Reply With Quote
Old 06-22-2011, 02:26 PM   #5
NcKidd
Member#: 133267
2004 psm WRX
+1, will be doing.
NcKidd is offline   Reply With Quote
Old 06-22-2011, 02:28 PM   #6
rmj
Member#: 276611
2011 STi 5-Door
Plasma Blue Pearl
I also should look into this! Nice work!
rmj is offline   Reply With Quote
Old 06-22-2011, 04:13 PM   #7
seekndestroy19
Member#: 209358
06 Sti
thanks i never thought of that....i was referring to spraying water straight on the motor
Old 06-22-2011, 04:36 PM   #8
STiwestMA
Member#: 191070
05 WRX STi
wow man, thats awesome! it made such a noticeable change
STiwestMA is offline   Reply With Quote
Old 06-22-2011, 04:50 PM   #9
silver03bugeye
Member#: 225570
03 wrx
79 trans am 462stroker
doesnt simple green eat aluminum? Ive heard that somewhere just cant remember if it was bs. I think there was something on the bottle says "not for use on aluminum"? just wondering
silver03bugeye is offline   Reply With Quote
Old 06-22-2011, 05:09 PM   #10
SatinWhitePearl
Member#: 170780
2007 STi
Satin White Pearl
You're correct, Simple Green does "dull" aluminum. It's not a problem though, just use some metal polish and you're good again.
I've been using Simple Green, automotive blend, to clean engine bays for a long time.
I also use it to clean wheels, wheel wells, undercarriage, etc. and it works flawlessly.
SatinWhitePearl is offline   Reply With Quote
Old 06-27-2011, 07:48 AM   #11
Boug
Member#: 265360
Wow! I agree as Simple Green is the Army's solution to cleaning nearly everything.
Boug is offline   Reply With Quote
Old 06-27-2011, 08:36 AM   #12
TheNewThatGuy
Member#: 148041
2000 Rally Impreza
Blue and Gold, baby
Simple Green is corrosive. If it's not on the bottle, I know I've seen it in an MSDS in my shop. No lie. Also, it's a terrible cleaner. At everything.
TheNewThatGuy is offline   Reply With Quote
Old 06-27-2011, 11:41 AM   #13
SatinWhitePearl
Member#: 170780
2007 STi
Satin White Pearl
Any more optimistic recommendations?
Old 06-28-2011, 12:44 AM   #14
Member#: 255573
I have used Eagle 1 A2Z wheel and tire cleaner with very good results but I've never tried simple green I'll probably look into it my outbacks engine bay looks terrible
pete@bms is offline   Reply With Quote
Old 06-28-2011, 12:57 AM   #15
topguneagle1
Member#: 115620
2000 Impreza coupe
FALCON 9
so is water if you let it sit on something long enough.
i've been using simple green in the family machine shop for ten years now and none of our machines or equipment show signs of any corrosion after using simple green.
i've also used it on my engine bay as well, many many times, and have loved the results.
if you can't get dry some of the tighter spots i recommend using a compressor and blowing the water from the crevices.
topguneagle1 is offline   Reply With Quote
Old 06-28-2011, 09:44 AM   #16
TheNewThatGuy
Member#: 148041
2000 Rally Impreza
Blue and Gold, baby
Agreed. Not saying it's extremely corrosive. Just saying it is. I can't use to clean the aircraft wheels I work on. Plus every time I've used it, in various applications, I've never been impressed. None of my "optimistic recommendations" would be off the shelf consumer products. : /
Old 06-29-2011, 09:23 AM   #17
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Well, I drive this car in the rain:
That's a 22x18 hole in the hood. Even in a good downpour, it doesn't seem to care.
LetItSnow is offline   Reply With Quote
Old 07-02-2011, 12:23 PM   #18
Gazeebo
Member#: 232698
2002 WRX Wagon
lol nice... I think if it mattered terribly all the OBS's and cars with fake hoodscoops would have stopped running long ago. and there's a reason the engine bay is set up for proper drainage.
Gazeebo is offline   Reply With Quote
candy green engine bay 06WRX_DARKGREY Newbies & FAQs 12 01-29-2011 06:51 PM
Double Trouble (non-Subaru content) fasterthanrayswrx Member's Car Gallery 70 01-21-2008 02:50 PM
New STi: Dirty engine bay vs Simple Green junk240sx North West Impreza Club Forum -- NWIC 10 02-24-2007 12:16 AM
Ice racing (Non-Subaru content) corey_dyck Motorsports 2 02-13-2007 09:55 AM
Simple Green engine cleaner...where? how much? LttLDGN Interior & Exterior Modification 4 10-11-2001 09:04 AM
