Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 06-22-2011, 01:09 AM   #1
jackthisnot
Member#: 223243
Default Seibon CF trunk "clear coat" turned to CRAP!!!
my Seibon CF Trunk........
i am not happy! how can i pay $600-700 for something and then only two years latter this. not worth it at all! if anyone is looking at Seibon my advice is to keep looking! factor in that you will have to shell out around $300 on top of the price of the trunk to get the clear coat redone with one that will not turn into crap after only two summers. and yes i waxed my car every month and wash it once a week with good quality stuff and this still happen! thought Seibon was a quality product but i guess i was wrong!
jackthisnot is offline   Reply With Quote
Old 06-22-2011, 10:53 AM   #2
jackthisnot
Member#: 223243
so other then getting the trunk re-clear coated is there any way to fix this?
Old 06-22-2011, 10:02 PM   #3
Ghost Friend
Member#: 88982
Possibly. The issue is likely oxidation of the resin. See post #4
http://www.autogeekonline.net/forum/...iber-hood.html
You can try and buff out the oxidation. Without typing a book on the correct way to do this, I recommend doing lots of reading at the link posted above or finding someone local who knows what they are doing to help you out. This is not something you can do by hand by buying some rubbing compound.
Once corrected, you'll need to wax frequently with a quality wax or sealant to avoid it happening again.
Ghost Friend is offline   Reply With Quote
Old 06-23-2011, 03:46 AM   #4
PeteJM
Member#: 244836
2015 WRX STi
Ghost Friend is on the right track.
PeteJM is offline   Reply With Quote
Old 06-23-2011, 03:58 PM   #5
jackthisnot
Member#: 223243
thanks a ton man!!!! i iwll be doing some reading it looks like
thing is, in my mind this should not happen with a quality part..... live and learn i guess......
Old 06-24-2011, 12:06 AM   #6
RoOoLeR
Member#: 204183
2005 STI
Same thing happened to mine.. I took it to my buddies paint garage and sprayed it OBP looks perfect. u cant/wont ever keep resin/clear coat looking perfect.
RoOoLeR is offline   Reply With Quote
Old 06-25-2011, 02:19 PM   #7
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Do you ever wax it at all?
I'm curious if getting a carbon fiber hood is even worth it, figuring I don't want results like this especially if one still takes care of it.
Smoke is offline   Reply With Quote
Old 06-25-2011, 03:42 PM   #8
Back Road Runner
Member#: 60082
2004 Forester STI
Why do they sell these products in the first place? I know they can make it better because I have better. I have a CF hood I've had for a couple years, bought it used even. I barely wash my car, barely wax my car, and the clear coat is perfect still. Apparently somebody can do it right, although I haven't the faintest clue what company made the hood, not Seibon, not VIS, something from China with no naming anywhere.
As far as worth, it goes two ways.
1) For older cars that still had steel everything, carbon fiber is the only way to lighten theses parts.
2) For newer cars with aluminum hoods, carbon fiber really isn't any lighter. I mean it can be, but the difference is small, especially comparing the difference from steel to aluminum and steel to CF. You're ending up near the same either way. The main gain with CF on the newer cars is more so an issue of durability. Aluminum on these newer cars is very thin and very easy to tend. By very easy I mean very, very, ridiculously easy. Carbon fiber can provide a similar weight option that gives you durability.
Old 06-25-2011, 04:12 PM   #9
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
CF parts dont come with clear coat... but that happens because the resin doesn't have UV blockers, it is common knowledge that the resin oxidizes and that you should clear coat or tint (50% paint/50%clear) any wet CF that will see alot of sunlight its YOUR fault for not doing more research, just saying. luckily your trunk is salvageable with a little elbow grease you should be able to remove the oxidation and you can purchase resin online or even take it to a body shop to be clear coated
also to get something that size cleared would be about 100 bucks not 300 and you can buy UV blocking resin for 25-50 bucks online that's an even cheaper option, ALSO EVERYONE IVE TALKED TO HAS TOLD ME THAT YOU SHOULD NOT WAX CF parts or it will oxidize like yours did
YOU COULD ALSO RATTLE CAN CLEAR IT with clear from a parts store, that would cost about 30 bucks ($10 per can) another cheap and easy option, maybe if you did a satin clear it could have a DRY CF look?
Rexxyou is offline   Reply With Quote
Old 06-25-2011, 06:23 PM   #10
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Yep... most CF parts don't come clear-coated.
XanRules is offline   Reply With Quote
Old 06-25-2011, 07:33 PM   #11
Back Road Runner
Member#: 60082
2004 Forester STI
I would expect companies to do it just because end consumers typically don't even think about such steps. If it's a bolt on piece for consumer use, it should be designed for such.
Old 06-25-2011, 09:24 PM   #12
Strobe Media
Member#: 241600
2004 WRX STi
like a million whp
yeah but then you'd have people bitching it's "too expensive" when it's an extra $100
Strobe Media is offline   Reply With Quote
Old 06-25-2011, 09:27 PM   #13
Strobe Media
Member#: 241600
2004 WRX STi
like a million whp
quick question though, don't mean to thread jack, but I got a CF trunk yesterday that has 4 holes in it from an S202 wing, and some little spider cracks around them...I'd like to take it to a shop and see what they can do but just curious if they can even fix stuff like that before I take it there. The cracks around the holes aren't deep, seem like just in the top layer of "clear" i guess you'd say.
Old 06-26-2011, 09:47 PM   #14
Dave_zok
Member#: 225034
2006 STI
Most of that will come out with a fine polish. But this kind of hazing is mostly caused by you not taking care of the product. You need to keep a few good coats of wax or sealant on any CF product at all times. Just like paint you can get UV damage but CF shows it much quicker as Seibon uses a mid grade UF protectant clear coat.
Dave_zok is offline   Reply With Quote
Old 06-28-2011, 01:17 PM   #15
BenGSX
Member#: 210061
Sooo that's supposed to be a Seibon trunk.. That trunk definitely looks like it does not have a clear coat on it.. And Seibon claims everything they produce is clear coated... Someone is lying...
http://www.seiboncarbon.com/faq/
All of our products are made using one-piece carbon sheet, so you do not see broken lines and patterns. All of our products use clear coat finish. Clear coats are shiny and durable, and they give you the nice "wet" look as opposed to a duller look from gel coats. All of our carbon sheets are built into the mold, so they do not break and split like the ones where carbon is only wrapped around the skeleton.
BenGSX is offline   Reply With Quote
Old 06-29-2011, 03:23 PM   #16
Dave_zok
Member#: 225034
2006 STI
Yes they all have a clear coat on them.
Old 06-29-2011, 03:43 PM   #17
YourMother'sLover
Member#: 76565
CLXX Stricta Parata
Neci!
WORDS OF WISDOM:
Any time you plan on purchasing something CF, always expect to pay extra to have a UV protectant clear coat applied. This holds true for 99% of any CF supplier.
As someone pointed out above, most companies do not apply a UV clear coat to their CF products and most of them do not use UV proctant resin in their products either. This has been covered since the 90s when CF became popular.
Also: If you plan on doing CF on your car, it's always good to make friends with a paintshop LOL
YourMother'sLover is offline   Reply With Quote
Old 06-29-2011, 03:44 PM   #18
YourMother'sLover
Member#: 76565
CLXX Stricta Parata
Neci!
Yes, take it to a reputable bodyshop and let them fine sand the cracks out and reapply a UV clear coat.
If you want the holes plugged, they could do it, but it would be very pricey and you may not have a matching weave.
Old 07-02-2011, 07:50 PM   #19
mpressive36
Member#: 157347
02 Impreza WRX
You just can't beat OEM body parts.
mpressive36 is offline   Reply With Quote
Old 07-03-2011, 12:15 AM   #20
Timallen
Member#: 287262
2007 Subaru
plus 1
Timallen is offline   Reply With Quote
Old 07-03-2011, 02:58 AM   #21
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
Rub peanut butter into it. No, I'm not kidding.
Smurftastic is offline   Reply With Quote
Old 07-03-2011, 03:48 AM   #22
jlugo05
Member#: 123891
2002 wrx psm hawkeye
02 wrx AW*secret project*
the issues started like in 08 i have seibon products that are older and still look great but the newer products will start oxidizing in about a year . vis in the other is coming out a little better
jlugo05 is offline   Reply With Quote
Old 07-03-2011, 10:44 PM   #23
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
I've heard this as well. I'm just curious on the results.
Old 07-03-2011, 11:47 PM   #24
PSI_XTC
Member#: 123386
'12 IS-F
'08 Saab 9-3 TurboX
my Seibon trunk did the same thing after 4 years or so. I would wax it a few times per year and I parked in the garage at home. My Mine's replica CF lip did the same thing, so a friend and I two toned both pieces. Top painted (where the resin oxidized) and rear recleared.
here are the parts before spraying the clear.
PSI_XTC is offline   Reply With Quote
Old 07-04-2011, 02:34 AM   #25
mustachebandit
Member#: 280183
unpainted carbon parts are pretty played out anyhow. its not like they save you much weight. nothing says dudebro street racer more then carbon trunks and hoods.
mustachebandit is offline   Reply With Quote
F/S Mines cf trunk spoiler with seibon cf trunk vLncecast Tri-State Area Private Classifieds 4 02-16-2008 03:55 PM
WTB Seibon CF trunk for 06 WRX (maybe CF WRX wing also) ChrisCJ99 Private 'Wanted' Classifieds 2 10-06-2006 08:26 AM
Is Seibon Cf trunk light enough to have no torsion springs? rsracer2005 Interior & Exterior Modification 5 07-20-2005 10:42 PM
FS Seibon CF trunk for 02 to 05 Impreza roybfr Mid West Subaru Owners Club Forum -- MWSOC 0 06-24-2005 01:56 AM
FS Seibon CF trunk for 02 to 05 Impreza roybfr Mid West Subaru Owners Club Forum -- MWSOC 5 06-04-2005 09:46 PM
