Old 07-25-2002, 12:45 AM   #1
StankFootZ
Member#: 3316
Default MRT Full Exhuast... Check Engine Light
I am curious if anyone out there with a 2000-01 2.5RS has the MRT full exhaust and had any check engine lights. I installed this today and the car drove for probably 3 combined hours before the Check Engine light came on. Anyone know if I reset my ECU will the CE light go away? I had this problem when I installed my old exhuast and intake. I just reset the ECU and haven't had a problem since... is it that easy in this situation?
My setup is 2000 2.5RS Manual with Cobb CAI, MTR Header/Midpipe, and Stroming SS Dual Tip Mufler. The header and midpipe were both painted with flat black 1200 paint.
Thanks in advance for any info,
Scott French
Edit: I tried deleting this post, but no dice....
StankFootZ is offline   Reply With Quote
Old 07-25-2002, 09:33 AM   #2
kickin_81
Member#: 16679
2004 Forester XT
Why would you delete it? I personally don't have a CEL with my MRT system. It's been about a month and no CEL. I heard people say that the 'cat. efficiency code' CEL issue happens to the second half of MY00 and earlier. FWIW, my MY00 RS was bought in Feb. 2000.
kickin_81 is offline   Reply With Quote
Old 07-25-2002, 11:46 AM   #3
Robmat
Member#: 2173
2000 2.5 RS
BRP
Where did you guys get your setups? I've been trying to find one with no luck!
Robmat is offline   Reply With Quote
Old 07-25-2002, 12:14 PM   #4
StankFootZ
Member#: 3316
I got my Cobb and Stromung from Cobb a long time ago and I just bought the MRT used locally.
I was going to delete it because this problem is listen in the FAQ...
I got my Car December 1999.
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 12:47 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-14-2003 09:04 PM
Engine coolant temp sensor check engine light? rhdude Mid Atlantic Impreza Club -- MAIC 2 11-09-2002 02:42 AM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 07:50 AM
