Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC > SCIC Vendor Classifieds
Old 06-22-2011, 12:37 PM   #1
PhatBotti Tuning TKR
Vendor Sales Rating: (72)
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Default PhatBotti Tuning - Dyno Tuning Info & Pricing
please use my [email protected] email. My other one is not receiving emails and I can't get a hold of yahoo support.
If you are inquiring about an e-tune, please see this thread PhatBotti E-Tuning (click me)
Here is our dyno facility
Please just PM your questions to my personal account so my partner mike doesnt have to sift through all the PM's. Or just post your question here.
Phatrons PM (click me)
Email/Paypal: [email protected]
Facebook: Ron Watson (PhatBottiTuning)
Facebook: PhatBotti (PhatbottiTuning1)
Im very busy and its hard to stop and talk on the phone all the time so text is good. That way i can take a break and answer all of them at once. Just put NASIOC your name then tune questions (Nasioc Joe tune questions) and i'll call/text you back.
AP, Power Pulls, OTS and AP+Tune Pricing:
APv3: $650
3 Power Pulls (hp,tq,boost,afr)(no tuning): $125
Apv3 + 3x OTS Map Dyno Pulls (no tuning): $725 ($50 savings)
APv3 + Stock turbo/injector Tune: $1000 ($100 savings)
APv3 + Bigger turbo or bigger injector Tune: $1100 ($100 savings)
AP and OS Tunes
Stock Turbo, stock injector Tunes: $500 credit / $450 cash
Upgraded Turbo, upgraded injectors Tunes & Swaps: $600 credit / $550 cash
Speed Density Tunes: $700 credit / $650 cash
Secondary Fuel Map (e85/race gas): $300 credit / $250 cash
Dyno Tuning Days
Thursday evening thru Sunday evening every other week (9/11-9/14, 9/25-9/28, 10/9-10/12, etc)
Friday evening thru Sunday evening every other week (9/5-9/7, 9/19-9/21, 10/3-10/5, etc)
Warranty & Liability Release - You will be required to sign this form at the shop
- We simply can NOT warranty tunes/motors. It would be impractical to do 10 tunes and make $2500 and be liable for $40,000 worth of motors. There are way too many variables ranging from leaks, maintenance, bad plugs, coil packs, bad fuel pumps, weakness of stock pistons/rings, all the way to machining and tolerance variables on built motors. The best way to take care of your car is to monitor its health via a wideband, EGT gauge, oil pressure gauge, coolant temps, and take periodic logs to check for knock and AF learnings that are greater than +-8%. We're not heartless and we completely understand the financial burden a blown motor puts on people. We will do everything we can to help out from parts at cost to highly discounted and possibly free tunes. Paying for a tune constitutes signature of the following waiver/release (this is a pretty standard form you must sign at most shops when getting dyno tuned):
I hereby authorize the road dyno tests and/or service work to be done along with the necessary materials, parts and labor and hereby grant you and your employees permission to operate the above vehicle and/or combustion engine on public roads, streets, highways or elsewhere for the purpose of testing, diagnostics, logging, road tuning, and any other work deemed necessary by Team Konquest Racing, INC (DBA PhatBotti Tuning TKR).
I hereby acknowledge and voluntarily release and forever discharge Team Konquest Racing, INC (DBA PhatBotti Tuning TKR), their employees, directors and officers from any and every claim, demand, action or right of action of whatever kind of nature, either in law or equity, arising from or by reason of any bodily or personal injury, death or property damage, known or unknown, resulting to or resulting from the aforementioned testing.
This release also includes, but is not limited to, any claim against Team Konquest Racing, INC (DBA PhatBotti Tuning TKR) for first aid, medical treatment or services rendered during participation in the test, tune, or operation of this vehicle.
PhatBotti Tuning TKR is offline   Reply With Quote
Old 06-22-2011, 01:06 PM   #2
Phatron
Member Sales Rating: (50)
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
PhatBotti Tuning - Tuning FAQ & Misc Info (click me)
HOW SHOULD I DRIVE DURING THE DATALOG?
The first 3-4 revisions will be for MAF scaling. No wide open throttle. You will be collecting data at idle and then collecting data all the way up to cruising at 75mph....small throttle changes and all under 4000rpm.
The next couple revisions will be partial WOT pulls from 2000-5500rpm in 2nd gear to get the wgdc and boost set.
The rest of the revisions will be 3rd/4th gear pulls from 2000-redline.
PARAMETER ABREVIATIONS
IAT = intake air temp
FBKC = feedback knock correction
FLKC = fine learning knock correction
IAM = ignition advance multiplier
DAM = dynamics advance multiplier
MAF = mass air flow
MRP = manifold relative pressure (boost)
IGN = igntion total timing
IDC = injector duty cycle
WGDC = wastegate duty cycle
WHAT SHOULD I DATALOG?
Romraider Datalog List for WOT
Parameters to Log – remember some of these may not be visible until hooked up to the vehicle
• Engine load (g/rev)
• Engine Speed (RPM )
• FeedBack Knock Correction (fbkc)
• Fine Learning Knock Correction (flkc)
• Ignition total timing
• Injector Duty Cycle (IDC)
• Intake Air Temperature (IAT)
• Manifold Relative Pressure (MRP) (4 byte)(or direct if 4byte not there)
• Mass Air Flow Voltage (MAFv)
• Primary Wastegate Duty Cycle (WGDC)
• TARGET Boost
• Throttle Position
• Wideband (LC-1/Uego)
• Requested Torque
AccessPort MAF Scale Logging
Load up the map and Datalog the following parameters for ~20 minutes.
A/F Correction #1 (%)
A/F Learning #1 (%)
Calculated Load
Closed Loop / Open Loop Switch
Engine RPM
Feedback Knock
Fine Learning Knock
Intake Temperature
Mass Airflow Sensor Voltage (V)
AccessPort WOT Logging
make sure under options, display, the "show standard units" box is checked
Boost Target
Calculated Load
Engine Speed (RPM)
Feedback Knock Correction (FBKC)
Fine Knock Learning (FLKC)
Ignition Timing
Inj. Duty Cycle (IDC)
Intake Temp (IAT)
Manifold Rel. Pressure (boost)
Mass Airflow Voltage (MAFv)
Throttle Position
Wastegate Duty (WGDC)
AFR (Lc-1/Uego)
Old 06-22-2011, 05:24 PM   #3
Badler
Member Sales Rating: (21)
Member#: 133597
Congrats!
Badler is online now   Reply With Quote
Old 06-22-2011, 06:12 PM   #4
Phatron
Member#: 36033
CEO PhatBottiTuning
^ as soon as you get your fueling figured out i have a grimmspeed mbc i wanna test on your car....
Old 06-22-2011, 07:18 PM   #5
Badler
Member#: 133597
Sweet! I've been leak testing and ain't found **** yet. Going to try the fuel thing this weekend after I put the IC, etc... back on.
Old 06-23-2011, 03:21 PM   #6
wrxsubiemod
Member Sales Rating: (35)
Member#: 165104
E85 SoCalPorting
Owner
nice guy. very recommended
wrxsubiemod is offline   Reply With Quote
Old 06-26-2011, 03:43 PM   #7
Phatron
Member#: 36033
CEO PhatBottiTuning
thanks
Old 06-28-2011, 01:14 PM   #8
Phatron
Member#: 36033
CEO PhatBottiTuning
lets do this
Old 07-20-2011, 04:48 PM   #9
Phatron
Member#: 36033
CEO PhatBottiTuning
tippy toppy
Old 07-25-2011, 03:34 PM   #10
2point0
Member Sales Rating: (15)
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Wait a sec, 760...are you in my backyard now?
Are you working from a shop around here?
2point0 is offline   Reply With Quote
Old 07-25-2011, 03:42 PM   #11
Phatron
Member#: 36033
CEO PhatBottiTuning
I've been in California for the last 10 years lol. I live 2 hrs north of LA
Old 07-25-2011, 04:55 PM   #12
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Haha no kidding. When I was PMing you about tuning my 05 WRX (end of last year I think), I could have sworn you were out of state. My bad...
Well here's a belated "welcome to the area!" lol.
Old 07-25-2011, 06:23 PM   #13
Phatron
Member#: 36033
CEO PhatBottiTuning
if you were pm'ing our vendor account you could have been talking to mike (STi Mikey) he's my partner...he lives in connecticut.
Old 11-01-2011, 12:22 PM   #14
Phatron
Member#: 36033
CEO PhatBottiTuning
bumps
Old 11-02-2011, 12:56 PM   #15
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
we tune cars
Old 11-03-2011, 12:42 PM   #16
Phatron
Member#: 36033
CEO PhatBottiTuning
Bumps
Old 11-03-2011, 04:01 PM   #17
BlackBeautysti
Member Sales Rating: (1)
Member#: 299433
2008 Subaru STI
Black Paint Black Rims
Hi patron
I am with subaru sti 08. Can i get etune from you. I have accessport ...catback aem cai and after market tmic,colder spark plug.... Planning to get stage 1 and 2 w 93 octane.
Ben
BlackBeautysti is offline   Reply With Quote
Old 11-03-2011, 04:06 PM   #18
Phatron
Member#: 36033
CEO PhatBottiTuning
pm sent
Old 11-07-2011, 01:03 AM   #19
Phatron
Member#: 36033
CEO PhatBottiTuning
All pms replied to
Old 11-08-2011, 12:09 PM   #20
Phatron
Member#: 36033
CEO PhatBottiTuning
Bumps
Old 11-08-2011, 03:03 PM   #21
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Ouch..
Bump PhatBotti,
best tunes in the WORLD
Old 11-12-2011, 04:29 PM   #22
Phatron
Member#: 36033
CEO PhatBottiTuning
pms replied
Old 11-14-2011, 11:25 PM   #23
Phatron
Member#: 36033
CEO PhatBottiTuning
pms replied
Old 11-15-2011, 11:02 PM   #24
Phatron
Member#: 36033
CEO PhatBottiTuning
Bumps
Old 11-19-2011, 02:13 AM   #25
xsennaix
Member Sales Rating: (3)
Member#: 88585
07 30r Sti
obp
Nonstop is ridiculous. You into dubstep, Ron?
xsennaix is offline   Reply With Quote
The 2.0 vf34 that did, now a built 2.0/2.5? hta green on e85 karlknaupp Proven Power Bragging 684 06-30-2015 08:20 AM
***** PhatBotti Tuning Now Doing Cobb ProTunes ***** Phatron AccessPort 66 08-22-2011 02:29 AM
PhatBotti Tuning Now Doing Cobb ProTunes PhatBotti Tuning TKR Vendor Announcements 10 07-08-2011 06:59 PM
Surgeline Tuning Now Offers Tire Mounting & Balancing!! Cobb Tuning NWIC Vendor Classifieds 4 09-30-2009 05:32 PM
