Old 07-25-2002, 04:45 AM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Question I officially have no memory! Does water kill O2 sensors??
I've been out of the automotive world for one week and already I can't remember if injesting water kills O2 sensors. WTH is wrong with me?? (Don;t answer that! )
Anyway, a couple weeks ago I posted another thread about injesting a serious amount of water and I am now getting some weird hesitation problems (intermitent) but it could just be in my mind.
So, to make a long story short, does water kill an O2 sensor? Thanks
Eric
Eric SS is offline   Reply With Quote
Old 07-25-2002, 02:06 PM   #2
Julian
Member#: 1182
MY00 RS
BRP
H20 is a by-product of combustion. Water is already and always in the exhaust.
Julian is offline   Reply With Quote
Old 07-25-2002, 02:43 PM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
nope, but coolant does, so does any kind of solvent that ends up in the air vent holes.
Jeremy
p.s.: there's a list of things wrong with you
Old 07-25-2002, 05:31 PM   #4
Section 8
Member#: 821
Water might hurt it if it was hot, then the tail pipe was flooded with water. Rapid contraction can hurt alot of things. Bearings have a problem with heat and water as well, but it is not directly related to the bearings themselves.
I don't think that you submerged your exhaust, if I remember correctly anyway....
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 07-26-2002, 04:26 AM   #5
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
That's what I thought but I wanted to make sure a large amount of water won't harm it.
Eric
Old 07-27-2002, 12:42 AM   #6
bartalbee001
Member#: 20915
1996 Legacy Wgn.
taupe
What kind of hesitation problems do you have? If its a suttle hesitation you can try a single piont ground set-up. Ive read that that helps some hesitation probelms. Or if your hesitation problem is like mine, really bad so you didn't accelerate, It won't help. Im still tring to figure out how to fix it.
bartalbee001 is offline   Reply With Quote
Old 07-27-2002, 01:37 AM   #7
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I reset the ECU and it pretty much took care of the problem. Thanks
Eric
Old 07-27-2002, 05:31 AM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
your's is prolly a dead cylinder, most likely a blown head gasket...phase 1 blocks seem to be famous for the head gasket issue.
eric-is it as you come on boost?? have you looked at the MAP values??
jeremy
Old 07-28-2002, 02:03 AM   #9
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
jeremy
Map values are fine. Zenier diode is still working. Like my previous post says (read it you little bitch ) , I reset the ECU and it fixed everything. Car runs better than ever now! I think all the water I took in freaked the computer out and all it needed was a reset.
Eric
Old 07-28-2002, 09:29 PM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Eric
thats just a band-aid you hack
Old 07-29-2002, 12:21 PM   #11
m750
Member#: 2278
8Sti | 07 allez
White | Comp
cheeRS,
Greg
Are you saying there is something wrong w/ his muffler bearings? heh
AO
m750 is offline   Reply With Quote
Old 07-30-2002, 02:56 PM   #12
phucvtec
Member#: 16261
2000 Impreza 2.5RS
Blue Ridge Pearl
yeah... chrome plated muffler baring seem to work the best, especially considering their robust character...
anyway, on the original topic, let me run with this, and then please correct me if im wrong...
Combustion of fuel (primarily octane)
C8H18 + 12.5O2 ---> 8CO2 + 9H2O
therefore, water is a biproduct of combustion, as previously stated. Now, based solely on Lachattlier's (spelling?) principle, adding water to the intake gas mixture will inhibit this reaction, and ultimately limit power. Right? So it is likely that the best air is dry air for maximizing your power.
This said, why do some people use a water spray setup?! Obviously, there are more factors than general level chemistry dictating the efficiencly of this whole process. Can someone shed some light please?
phucvtec is offline   Reply With Quote
Old 07-31-2002, 01:27 AM   #13
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Water spray is not for power, it's for protection. It deters detonation
Eric
Old 07-31-2002, 01:38 AM   #14
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Re: I officially have no memory! Does water kill O2 sensors??
I've been out of the automotive world for one week and already I can't remember if injesting water kills O2 sensors. WTH is wrong with me?? (Don;t answer that! )....
Eric
Are you considering water injection into your exhaust manifold? I heard that's a good way to bring your exhaust temperatures down. J/K
Kevin Thomas is offline   Reply With Quote
Old 07-31-2002, 03:20 AM   #15
Section 8
Member#: 821
Bearings, when hot, then quickly cooled in water will contract. I don't know exactly what happens, weather that squeezes out grease or what, but water will get into the bearings. Of course bearings with water in them instead of grease have lots of suck.
THis is a problem with boat trailers that have been towed for a few hours and have become hot, and people with little patients back their boat into the water right when they get where they were going. Then on the way home (maybe after a few trips) they have a bearing failure. This is the reason for the majority of vehicles on the side of the road with a boat attatched to them, or boats left unatteneded on the side of the road. Of course flats as well, most people don't have a spare for their trailers. ***
cheeRS,
Greg
where does the rear o2 sensor plug into? BlowDro Newbies & FAQs 1 03-24-2007 08:27 PM
Does anyone have a o2 Sensor they would give away? jonnysubby North West Impreza Club Forum -- NWIC 0 02-02-2005 05:22 PM
What does the rear o2 sensor fix consist of? phasedlife Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-10-2003 01:54 PM
does anyone have pictures of the o2 sensor connector NITROS General Community 0 08-28-2003 01:25 AM
how much is it to have muffler shop install a third o2 sensor? huey Normally Aspirated Powertrain 1 02-09-2001 03:47 AM
