Old 07-02-2011, 01:38 AM   #1
IvanFA20
Member#: 227738
16' WRX CVT
Default water spots on CF hood?
i have what appears to be water spots on my one year old carbon fiber hood.You can only see them in certain light. I'm not sure if its water spots or something else. I washed my car today and tried clay baring and waxing it. I also tried the vinegar method and that did nothing. I dont have a buffer so i wouldn't be able to try that. But is there anything else i can do? I attempted to take a picture of it but they didn't come out to good.
IvanFA20 is offline   Reply With Quote
Old 07-02-2011, 02:41 AM   #2
connie808
Member#: 251735
2004 IMPREZA
CGM
Did you try using MX7? Its a acidic solvent and I know that all the car detailers here use it to take out hard water spots. They have two types of MX7, one for the car body, and the other for glass. Dont use the MX7 that is purposely only used for the car body on windows as it will etch it. If you are not familiar with MX7, please do alittle research. When applying MX7 on the car body, like waxing, do alittle section at a time. Then after rubbing it with MX7, you nutrilize the acidic solvent with a wet towel to nutrilize the acidic solvent, then wipe with a microfiber. Hope that helps.
GL
connie808 is offline   Reply With Quote
Old 07-02-2011, 11:01 AM   #3
PLAGUEDD7
Member#: 286705
2015 Impreza WRX STi
I got most of the water spots out with rubbing compound
PLAGUEDD7 is offline   Reply With Quote
Old 07-02-2011, 03:20 PM   #4
IvanFA20
Member#: 227738
16' WRX CVT
GL
Thanks! I guess this is my last option. The only way to get that stuff is to order it right?
Hood Pin install on CF hood. ScoobyDudeRPM Interior & Exterior Modification 1 04-11-2008 07:45 PM
Where to mount hood pins on cf hood krystek Newbies & FAQs 3 11-07-2006 01:44 AM
water spots on my seibon carbon fiber hood wrxunit8 Interior & Exterior Modification 4 06-19-2006 01:26 PM
installing hood pins on cf hood ohHello Tri-State Area Forum 1 07-14-2005 05:33 PM
best spot for CF hood ? 4wheelflyer Vancouver Impreza Club Forum -- VIC 3 06-08-2003 11:13 PM
