Welcome to the North American Subaru Impreza Owners Club Saturday November 22, 2014
Old 06-23-2011, 06:59 PM   #1
tmann05
Member#: 178773
2004 Subaru WRX STI
Default Detailing Questions
I've got some yellow discoloration above the rear bumper where the trunk lid covers. Anyone know what will take that off? Also I am using this blue clay on the plastic bumpers/sideskirts and the small spots don't seem to want to come off. Is there a better color clay or something that will help speed up the process?
Also shown here I have some paint chips on one of my rear strakes. Is this something I can just touch up with white paint or would sanding be involved?
One more thing - last year a radiator hose blew and I got a replacement for the hose and put this orange auto zone coolant in since most of the old green stuff leaked out. I don't think this is what I should be using because after fillling the reservoir tank to the correct line, the next time I checked it, the level has dropped. What should I do in this situation? Thanks for any help or ideas!
tmann05 is offline   Reply With Quote
Old 06-23-2011, 07:58 PM   #2
beij0
Member#: 248975
2003 WRX/B4 Blitzen
PSM/Red
To begin, that coolant is for GM vehicles, I don't know how responds with a Subaru, I've have always used the Subaru coolant. I've also heard bad stuff about Dex-cool too.
For your exhaust, some metal polish will fix that right up for you. My exhaust is like that after every winter.
For the chips, there are a few different ways of fixing that, just depends on how much work you are wanting to put into it. ex Dr. Color Chip is pretty fast and easy.
Those small spots are more that likely contaminates that have gotten below the surface where your clay bar can not reach. Iron Cut may be of use here, but since there are no pictures of what you are talking about, hard to tell.
As for the discoloration, sorry but I can not help you there. But my best guess would be a rubbing compound of some sort, but I would wait to hear what others have to say.
beij0 is offline   Reply With Quote
Old 06-23-2011, 08:39 PM   #3
tmann05
Member#: 178773
2004 Subaru WRX STI
Thanks for the reply, I have found a coolant thread and may be purchasing the correct subaru coolant. Say I do get a new coolant type, can I just drain and refill or is a flush required?
I also found an exhaust cleaning thread thanks for your input!
Well I get these contaminent spots every year it seems and using the gray clay from walmart I can get off all the spots on the metal, though it is time consuming (about an hour per door). The plastic is a bword to clay and the gray clay will barely touch it so thats why I am trying blue. I will look up the iron cut.
Old 06-24-2011, 02:26 AM   #4
Flynlow151
Member#: 77870
2004 Subaru STI
TheBoostCreep Stage II
Rubbing compound or polish will fix your paint. A clay bar will only remove surface contaminents such as sap, pollen, etc. Hit it with some rubbing compound and then a few coats of wax to either prevent it in the future or atleast help protect against it.
Flynlow151 is offline   Reply With Quote
Old 06-24-2011, 04:49 AM   #5
beij0
Member#: 248975
2003 WRX/B4 Blitzen
PSM/Red
Clay bars only come in two kinds of grade, medium and fine. Color doesn't determine the quality or grade of the clay, just what the manufacture wants. And as said above, it's only for surface cleaning.
Edit:
Usually radiator flushes are worthless to do and a waste of time and money. But if you feel the need to do so, to make sure none of that stuff left in there, there are a few DIY methods out there. I would also find a bottle of coolant conditioner also.
Old 06-24-2011, 04:27 PM   #6
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Actually, they come in more grades than that but most consumer offerings are what I might consider on the relative "medium" side. ....by comparison, something like Sonus UFC (green) is even more mild and something like Meguiars C2100 (red) clay is quite a bit more aggressive.
Kean is offline   Reply With Quote
Old 06-27-2011, 12:31 AM   #7
tmann05
Member#: 178773
2004 Subaru WRX STI
Yep I think I'll try the red next
Old 06-27-2011, 11:46 PM   #8
AutoAesthetica
Member#: 246785
We have in stock Meguiar's Red Aggressive and Clay Magic Medium(which is just about as aggressive as Megs). Both very effective in situations of stubborn contamination.
I always had the experience(with the exception of CM Blue) that many OTC clays were a bit too mild in my book.
But yes as stated, starting color means nothing in a clay situation.
AutoAesthetica is offline   Reply With Quote
Detailing Question... Black plastic/rubber trim Sephro Off-Topic 17 09-28-2005 01:30 PM
quick detailing question yardiewrx Car Care & Detailing 2 09-16-2002 02:50 PM
general interior detailing question trdn1 Newbies & FAQs 1 05-16-2002 03:05 AM
Glaze / Polsh / wax detail question rjones Interior & Exterior Modification 2 03-12-2001 07:29 AM
