Old 06-24-2011, 03:04 AM   #1
pookothebear
Member#: 275771
2011 WRX
Satin White Pearl
Unhappy Scratched car while debadging :(
Hey guys!!
I did a search around and couldn't really find an answer.
Heres a bit of background. I decided to finally debadge my car today while giving it a wash.
Things were going well, just prying it off and rolling off the glue, but the problem is, I wasn't paying attention to the direction that I was prying off the letters. What happened was, with some of the letters, the corners dug into the trunk and caused some scratches. I think they broke the clearcoat layer because the scratches catch my fingernail as I ran them over it, but I'm sure it didn't breach the paint layer.
I wasn't sure if the scratches were bad enough to get the trunk repainted (which I want to avoid). So for now, I put a couple layers of wax over the scratches and am hoping that'll hold for now.
What do you guys think? Is there a way to fix this?
pookothebear is offline   Reply With Quote
Old 06-24-2011, 03:12 AM   #2
vinxH
Member#: 159796
2006 WRX
pics? if you're lucky you can take it out with a polish, or if that doesnt work then maybe wet sand and then polish... but it really depends on how bad it is. worse case scenario you can probably still make it not so noticeable.
vinxH is offline   Reply With Quote
Old 06-24-2011, 03:32 AM   #3
pookothebear
Member#: 275771
2011 WRX
Satin White Pearl
I'll try and post up pics tomorrow.. but to be honest, I would say its me freaking about something small, since its something that only I will find.. haha
But the main thing I'm worried about are stuff that happen if the scratch is left alone. Perhaps not taking care of the scratch would lead to rust? or clearcoat degradation?
Old 06-24-2011, 04:18 AM   #4
everdying55
Member#: 112651
2011 Corn Fed WRX
DGM Hatch
Wtf were you using to "pry" the letters off??????
A crowbar?!
everdying55 is offline   Reply With Quote
Old 06-24-2011, 07:19 AM   #5
ChrisTahoe
Member#: 244749
13 BRZ
14 690 Thumper
Next time, use heat and fishing line to avoid this issue...
ChrisTahoe is offline   Reply With Quote
Old 06-25-2011, 02:30 PM   #6
SwordVan
Member#: 260540
2011 STI 5-Door
If you were debadgeing your WRX badges on a '11 I feel no sympathy for you. Other wise wet sandpaper and some wax and polish.
SwordVan is offline   Reply With Quote
Old 06-25-2011, 03:24 PM   #7
alvlee01
Member#: 240252
I would try a buffer with a good wax with good abrasive compound...if no go...then ^this...wet sand usually helps if you haven't breached the paint
alvlee01 is offline   Reply With Quote
Old 06-25-2011, 04:50 PM   #8
Ce10
Member#: 231031
07 STI
My question is how come you couldnt find an answer on here? There are over a million threads asking this exact same question. In fact there was one last week in the Newbies section asking this... sorry about the scratches but you should know better?
Ce10 is offline   Reply With Quote
Old 06-25-2011, 07:05 PM   #9
everdying55
Member#: 112651
2011 Corn Fed WRX
DGM Hatch
I also don't understand why you didn't look up how to do it properly.
Old 06-25-2011, 09:21 PM   #10
sars101
Member#: 280420
2005 2.5 rs
silver ish
if you hit the paint put the letters back on
sars101 is offline   Reply With Quote
Old 06-26-2011, 09:26 PM   #11
boltfansmith
Member#: 286743
2003 Wrx
Originally Posted by pookothebear View Post
Hey guys!!
Did the same thing on my bug eye and had my friend at a body shop buff and water sand the scratches out.. Hope its not to deep or other measures might have to be taken... Good luck
boltfansmith is offline   Reply With Quote
Old 06-26-2011, 11:21 PM   #12
paliknight
Member#: 285480
2016 F82
MWM
put the badges back on?
paliknight is offline   Reply With Quote
Old 06-26-2011, 11:23 PM   #13
owdschool
Member#: 191222
That's why I havnt done this on my 2011
owdschool is offline   Reply With Quote
Old 06-27-2011, 01:03 AM   #14
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....well, if you do it the right way, there is nothing to worry about.
Kean is offline   Reply With Quote
Old 06-27-2011, 01:22 AM   #15
pookothebear
Member#: 275771
2011 WRX
Satin White Pearl
yeah I feel incredibly stupid about what happened
The reason why I couldn't quite find an answer is because everyone else's problems pertained to clearcoat scratches, which could be taken out with a good wax.
I wanted to avoid trying the wet sanding cause that seems a bit of an extreme method to use.
Anyways, I'm not sure how much it actually breached. All i know is the scratches are miniscule and can hardly be seen. But I would still want to do something about it. Would an abrasive polish do the trick? or should I find a buddy who knows about wetsanding?
Old 06-27-2011, 03:19 AM   #16
pookothebear
Member#: 275771
2011 WRX
Satin White Pearl
So to answer your question.. I did kinda read up on how to debadge. most posts said that with newer cars all you had to do was pull off the enblems one by one.. but I didn't take into account the sharp edges..
Old 06-28-2011, 03:12 AM   #17
hkp30
Member#: 253539
Don't jump straight into wet sanding!
Start off with a mild abrasive and progress from there. Find a buddy with a DA polisher and some cutting compound, such as meguiars M105 and a light cutting or polishing pad. If you don't know where to find a DA polisher and pads, look for pads you can use by hand.
There are other abrasive compounds available which range from removing light swirls to scratches, M105 would be considered a strong start in my opinion, and I’d start with something with less cutting power.
Something similar to this, then move to pads with more cutting power or a compound with more abrasives.
http://www.wolfgangcarcare.com/wolfg...mover-3-0.html
You want to level out the scratch to make it less visible depending on it's depth. Do this by slowing moving up to the amount of abrasion you need by matching a compound and pad.
Just my thoughts Hope this helps.
hkp30 is offline   Reply With Quote
Old 06-28-2011, 11:47 AM   #18
Kean
Member#: 25187
'08 Foz Prem TGM
....start mild and then move up from there as hkp mentioned. Meguiars Swirl-X and Meguiars Ultimate Compound are readily available OTC (the latter being the more aggressive of the two and likely requiring follow-up with the Swirl-X if used). These can be used by hand or DA, are easily/quickly acquired and are decent polishes.
I still need help after debadging :( SoareS Car Care & Detailing 44 12-02-2005 05:17 PM
dude calls 911 for stolen car.... while hanging onto bumper of speeding car in snow plunk10 Off-Topic 36 01-12-2005 03:49 PM
My car isn't fast.... :( ScreaminFast Engine Management & Tuning 13 08-26-2003 02:06 PM
I wrecked my car this morning :( sonicsuby Off-Topic 29 07-31-2003 04:06 PM
('93-'01) Help! I fogged my paint while debadging... newrxnj Impreza Forum 7 04-25-2001 07:52 PM
