Old 06-24-2011, 08:07 AM   #1
Rokkit
Member#: 84181
NASA #530 GTS2
Default Hyperfest Videos
I don't ususally post stuff about my own lap times here but for those who are interested here is the small bore (PTC-PTF, Honda Challange, Spec Miatta, etc.) race at Summit Point last weekend.
- Hyperfest Sat Race
- Hyperfest Sun Race (Started on Pole! woot)
Rokkit is offline   Reply With Quote
Old 06-24-2011, 08:24 AM   #2
blacktrail
Member#: 154841
2002 white
johnny tran
Are you the coupe or the sedan. I remember seeing you both but don't remember which races each of you participated in.
blacktrail is offline   Reply With Quote
Old 06-24-2011, 09:09 AM   #3
Rokkit
Member#: 84181
NASA #530 GTS2
There's only one subaru in PTC (well, in small bore for that matter lol)
I'm the coupe... This one:
Old 06-24-2011, 11:22 AM   #4
nickrice20
Member#: 95153
2016 BMW F48 X1
Mineral White
Nice driving dude!!!!!
Got some questions for you. Do you have a build thread or details on your car? Also it is obvious you carry the a lot more exit speed out of 10 than anyone else. The AWD drivetrain screw you in the long straights I know the feeling. So why is it that you aren't trying to use some of the draft off the Honda's ahead of you? I imagine that it is either for better cooling or just trying to stay in their blind spot. I was pretty amazed at your brakes as well you would think a Honda would out brake you with the weight differential.
Oh one more thing what kind of engine was in that Ford Probe? It sounded like a rotary never seemed to stop revving, pretty mean sounding.
Nick
nickrice20 is offline   Reply With Quote
Old 06-24-2011, 11:48 AM   #5
Rokkit
Member#: 84181
NASA #530 GTS2
Nick
1) yes, i do. http://buildingasubarutrackcar.blogspot.com/ would be the best spot to start
2) Exit speed is lower than I wanted actually, I can get a bit more. The AWD doesn't hurt the strait really, i'm down on power . I should be making like 185 on a mustang dyno for the class, but i'm making 160ish.
3) Why not draft? well i was doing it a little, but I ended up over-heating the brakes (or so i thought) but it turned out to just be pad knock back from wheel bearing failures... replacing them this weekend.
4) Brakes are actually stock - well with Hawk HT-10 Pads... but stock rotors/calipers.
5) probe has a stock motor in it. but he's a much better driver than I with a bit more power too.
thanks for lookin'
Old 06-24-2011, 01:34 PM   #6
nickrice20
Member#: 95153
2016 BMW F48 X1
Mineral White
Cool I will read your build I am planning on possibly doing an enduro car out of n/a impreza for fun in the future.
Yeah I imagine the wheel bearing failure isn't being helped by you being all over the curbing . Still running 5x100?
You packing the bearings with Neo greases or anything of that nature? The pad knock back is a pain I started my novice license in my buddies 04 STI and it scared the crap out of me a few times. Have you thought about doing some anti knock back springs the next time you rebuild the caliper?
It is hard to believe that is a stock Probe motor kind of crazy.
Old 06-24-2011, 01:38 PM   #7
Rokkit
Member#: 84181
NASA #530 GTS2
Well the probe motor is modified heavily, but it's in stock form internally.
as for the bearings - I've got a season and a half out of them... prob close to 15-20 events so their life is up. I use Amsoil synthetic high temp grease when I pack them.
Spring rates are still pretty low on the car - gata use any advantage I have... the car likes a lot of curb
Old 06-24-2011, 01:55 PM   #8
nickrice20
Member#: 95153
2016 BMW F48 X1
Mineral White
Yeah my race car is on T2's as well running 500lb rear 600lb front. I may be switching it up a little after they are rebuilt this winter to see what I like.
Have you had any problems with your camber coming out of adjustment on your rear end? I am not sure I like the way the coil overs are slotted for adjustments. At the end of last race my right rear was sitting at 0 degrees started at -2.5. It explained the car becoming more and more loose as the race continued. I thought I had just overcooked my tires. The bolts were torqued as tight as I could get them with a 1/2" breaker bar.
Old 06-24-2011, 01:58 PM   #9
Rokkit
Member#: 84181
NASA #530 GTS2
Have you had any problems with your camber coming out of adjustment on your rear end? I am not sure I like the way the coil overs are slotted for adjustments. At the end of last race my right rear was sitting at 0 degrees started at -2.5. It explained the car becoming more and more loose as the race continued. I thought I had just overcooked my tires. The bolts were torqued as tight as I could get them with a 1/4" breaker bar.
Nope, Spec is 128 Ft/lbs and that's what I torque them too.
What I did is tack washers to the strut assembly where I want the camber to sit and then make adjustments on the top hat.
No problems thus far.
Old 06-24-2011, 02:20 PM   #10
nickrice20
Member#: 95153
2016 BMW F48 X1
Mineral White
Yep that was my next move was to do a little welding on the ears themselves. Glad to know that you did something similar great build blog so far, reminds me of mine.
Old 06-24-2011, 08:01 PM   #11
grippgoat
Member#: 62182
2005 STI
1/4" breaker bar?
Have you tried new strut bolts? I've had my suspension on and off a ton of times, and one time at Portland, I went two-off on the exit of 12, hitting the back of the curbing pretty hard, and the camber slipped really badly. Turns out the strut bolt was stretched from just being old, and wasn't really clamping well. Threw new bolts in and no problems.
-Mike
grippgoat is offline   Reply With Quote
Old 06-24-2011, 08:05 PM   #12
nickrice20
Member#: 95153
2016 BMW F48 X1
Mineral White
Originally Posted by grippgoat View Post
1/4" breaker bar?
-Mike
I will have to give that a try. The camber slipped out at Pacific Raceways which is pretty darn rough on suspension coming through 3b and 7 as you probably already know. Oh and I meant to say 1/2" breaker bar my brain isn't firing on all cylinders today
Old 06-24-2011, 09:51 PM   #13
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Cool car! Good to see more RS's out there racing.
I will be doing something similar to this starting later this year. My RS will no longer be a street car. I am going to build it for SCCA Improved Touring S. All of the work to engine and drivetrain are already done. Just need to strip the car and pull all the suspension to go through it do what I can within the rules. Probably hold off on a fuel cell till I get it in working order.
BTW, what do you have your weight down too with driver? Do you have a minimum?
Patrick L is offline   Reply With Quote
Old 06-24-2011, 10:03 PM   #14
Rokkit
Member#: 84181
NASA #530 GTS2
I need to check out that series, maybe I can run there too...
Old 06-25-2011, 12:54 AM   #15
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Not with those flares, plus you have to run a stock size wheel. You can swap for any diff except the center. You can run any final drive you want. (3.90, 4.11 or 4.44)
BTW, I have had good luck with the DTC-60's. Awsome bite, not as much heat but realy hard on rotors. There was someone that did some testing, by putting a thin aluminum shim between the rotor and hub. You can cut down on some of the heat gettng too the bearings. Plus brake ducks don't hurt either.
Min weight in ITS for the RS is 2660 with driver right now. They only list GC,98-01 right now in the rules.
Old 06-25-2011, 05:57 PM   #16
Rokkit
Member#: 84181
NASA #530 GTS2
Ah just saw that about the flares... ah well - I'll research it and engineer around it if I think I'd benefit from racing with SCCA.
Ya this car is 2640 now. And I have brake ducts and shims..lol
I think ill go with a raybestos st-43 next.
Old 06-25-2011, 06:17 PM   #17
nickrice20
Member#: 95153
2016 BMW F48 X1
Mineral White
St-43's are exceptionally tough on rotors at least on my 3140lb car.
Old 06-25-2011, 07:58 PM   #18
Rokkit
Member#: 84181
NASA #530 GTS2
yeah but i hear they are much more predictable throughout the pad material and don't change characteristics much... plus they wear like iron which is cool.
Rotors for the RS are only 35 bucks :P
Hyperfest race video, for your consumption wallyman424 Off-Topic 14 06-29-2007 01:35 AM
Video from Hyperfest @ Summit Point boost junkie Motorsports 6 06-27-2007 09:27 PM
Video of Cobreth at Hyperfest mav1c Mid Atlantic Impreza Club -- MAIC 20 07-10-2003 09:39 AM
Battle Of the Imports Here @ MIR in MD. Also Hyperfest this weekend imprezawd Mid Atlantic Impreza Club -- MAIC 2 06-27-2002 09:55 PM
Time Trial at Hyperfest 6/29 - 6/30? mav1c Mid Atlantic Impreza Club -- MAIC 18 06-07-2002 06:14 PM
