Old 01-17-2012, 05:43 PM   #26
AWDPWR12
Member#: 303314
Rubber ends where removed prior to installation. I believe you just need a better clamp than the stock worm clamp.. I will keep you all posted on my results. But over all happy with my stage 2 with stock catback 292whp/320lb-ft.... Loads of fun to drive...
Originally Posted by MTS View Post
if you guys leave the stock rubber ends on the stock throttle body coupler, you're asking for failure and impossible fitments. Perrin had the same issue back in 2005 (and now), and the answer was to remove the rubber ends of the throttle body coupler... the glue that keeps them on dries out, the rubber slips off and you get the "dying elephant" noise of air blowing by the rubber ring. The rubber ends are there to prevent cracking the stock plastic intercooler I assume and are useless when attempting to install this or any perrin-like tmic. Also, adjust the throttle body coupler. It may provide the correct angle required to get the tmic to fit. If it's way off, it's welded poorly and/or you need to clock the turbo (which will suck)
Just my 2 cents.
AWDPWR12 is offline   Reply With Quote
Old 01-20-2012, 08:25 PM   #27
AWDPWR12
Member#: 303314
Did your vacuum numbers change after you installed the larger TMIC? Should they remain unchanged? I was seeing 9.7-9.8 on my stock intercooler, today I'm seeing 9.5-9.6 with the Torque solution TMIC... Leak? This is using the Access port...
Old 01-26-2012, 03:17 PM   #28
AWDPWR12
Member#: 303314
So I just got the OK from IIR to send my Torque solutions TMIC intercooler back for store credit. I am very happy so far with IIR's customer service... Turns out the BOV flange is not machined right and i am not getting a proper seal all around... Meaning the BOV does not sit flush with the intercooler flange... The bolts are tight, but still have a leak... Hopefully they get me a good price on an AVO TMIC for all my troubles :-)... I will keep you all posted on the outcome of this...
Old 03-09-2012, 10:15 AM   #29
AWDPWR12
Member#: 303314
So after upping the boost and the timing, we ran into the same issue... Seems like the unit is less efficient that the stock unit. I can run the intercooler at no more than 18psi... What did you end up doing? This you end up buying the avo?
Originally Posted by Brakeman302 View Post
Just going by what my tuner has told me. No leaks but for some reason with the torque solutions tmic I am running lean and having major knock. He said he has seen this befor with torque solutions. He Swaped out the torqued solutions with a Perrin and all the knock went way. So if he can't tune my knock out I will be looking at going AVO tmic.
Old 02-02-2013, 11:56 PM   #30
JMlegacy
Member#: 341649
what did YOU end up doing?
JMlegacy is offline   Reply With Quote
anyone using an AVO fuel pump on their 08 STI/WRX? zmw Texas Impreza Club Forum -- TXIC 33 01-28-2009 12:56 AM
Anyone using or planning a TMIC on a 20G? deblas66 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 50 09-10-2007 03:56 PM
Anyone use Altiris Inventory Solution?? C-daleRidr Off-Topic 5 07-27-2006 01:17 PM
Anyone using Perrin EBCS w/ UTEC on WRX stock 2 litre? overdose Engine Management & Tuning 3 04-22-2005 01:33 PM
anyone use apex springs, 30mm drop on WRX wagon SWEETWRX Brakes, Steering & Suspension 1 07-18-2001 11:10 PM
