Welcome to the North American Subaru Impreza Owners Club Monday June 29, 2015
Old 06-26-2011, 12:14 PM   #1
JordanM9
Member#: 273214
2013 WRX Limited
CBP
Default Low boost with Stage1+SF 93 map
I am consistently getting around 15.5psi since switching from the stock intake where I was hitting 16.5psi. Should I be running the HWG map or is 15.5 close enough? Thanks for any help.
JordanM9 is offline   Reply With Quote
Old 06-26-2011, 10:41 PM   #2
olazy
Member#: 263322
2011 WRX Limited
WRBP
Target boost with your setup & map is 17 psi +/-.8 psi
Does that sound close enough to you?
I have the same setup and had the same issue, give the HWG map a try, it fixed it for me.
olazy is offline   Reply With Quote
Old 06-27-2011, 08:47 AM   #3
Cobb Tuning
Member#: 4803
The boost target for the 2011 WRX will vary depending on whether it is a stage 1 or stage 2 map and whether it is a 91 ACN, 91, or 93 octane map.
Check out the map notes for the map you are running here:
http://www.cobbtuning.com/info/?ID=3061
Generally, if your peak boost is within about 1 psi of the stated target in the map notes, you are good to go (assuming you are near sea level). Keep in mind that you will not generally hit near your target in the lower gears (1st and 2nd) - this is normal. Do a 3rd gear run to determine if you are hitting your target (if you can do so safely).
Bill
Old 06-27-2011, 12:16 PM   #4
JordanM9
Member#: 273214
2013 WRX Limited
CBP
Tried the hwg map and it was 17.2 psi. Thanks now just need to do some logs.
Old 06-29-2011, 09:31 AM   #5
lickitysplitwrx
Member#: 276859
I was having the same problem as you so I tried the other map and met target boost but I was getting a lot of knock so I went back to the normal wastegate map.
lickitysplitwrx is offline   Reply With Quote
Old 07-06-2011, 01:27 AM   #6
SubaruWRX1843
Member#: 269130
2011 WRX
Default Same problem... worse...
Im only getting 13.7psi with the HWG map. Nobody knows whats going on.
https://spreadsheets.google.com/spre...9mWXc&hl=en_US
SubaruWRX1843 is offline   Reply With Quote
Old 07-06-2011, 10:02 AM   #7
Cobb Tuning
Member#: 4803
In order to make any kind of determination, we need to know the exact map you are running - 91, 91 ACN, or 93 octane? Stage 1 or Stage 2? Stock intake, SF intake or AEM intake? We also need an exact list of all mods.
Edit: Based on your post at cobb forums, can you confirm that you are running the stage 1 91 HWG SF intake map? What are you exact mods?
Bill
Old 07-06-2011, 12:10 PM   #8
SubaruWRX1843
Member#: 269130
2011 WRX
I am Continuing the conversation on Cobb forms. If we figure out what’s going on I’ll post it.
2011 wrx
stage 1 + sf 91 HWG map.
only mod is the SF intake and box.
Old 07-08-2011, 07:02 PM   #9
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
can you describe this? i feel like i'm going through the same situation. i think my ecu learned to pull timing since i don't downshift usually to pass on the highway. caught it while i was logging, went to the normal WG duty map and it doesn't knock anymore.
now, i'm only hitting 16psi on the stage 2 map.
Nimbus09 is offline   Reply With Quote
Old 02-19-2012, 03:55 PM   #10
jwongx27
Member#: 300323
first gear i hit 25.9 psi.... is that bad? im pretty new at this... im stage 1 ACN +SF intake
mods are SF intake cobb ap and nameless axle backs.
jwongx27 is offline   Reply With Quote
Old 02-19-2012, 05:02 PM   #11
JordanM9
Member#: 273214
2013 WRX Limited
CBP
ya something is wrong!!! should not be anywhere near that in any gear
Old 02-20-2012, 07:18 AM   #12
subiebosch
Member#: 155548
2015 2500 Dmax
2011 WRX TP STG2 COBB DP
@ jwongx27 - 25.9 is bad, are you running a 2011 WRX, where you located (altitude wise). I agree with JordanM9....something is very wrong if you are seeing that high boost.
subiebosch is offline   Reply With Quote
quick question: low boost on ap stage 2 map Aleman03wrx AccessPort 8 10-22-2010 06:18 PM
'07 STi low boost with AP stage 1 91oct map CheapShot AccessPort 1 10-09-2010 10:36 PM
slow/low boost with downpipe install 03WRX83 Engine Management & Tuning 4 08-10-2003 12:14 PM
low boost with unichip question wrxlr8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-30-2002 05:00 AM
Low boost with Legacy turbo? Diz Technical Forum Archive 7 09-07-2000 12:50 AM
