Old 06-26-2011, 06:41 PM   #1
Hammad
Member#: 286733
2006 STi
Default "?" Cobb Ap
Sorry if this is a repost, I just joined today and still learning. So I just bought a COBB AP yesterday and was wondering what should I set it to for a completely stock STi to get the most out of it safely.
Hammad is offline   Reply With Quote
Old 06-26-2011, 07:23 PM   #2
Cobb Tuning
Member#: 4803
Hi there. Thank you for your purchase.
When you go to install the AccessPORT, you will need to select a map. A stage 1 map should be used for a completely stock car. The maps will also be designated either 91 or 93 octane. You should select the map with a listed octane that is equal to or less than the octane of the gas you are going to put in the car. For example, if you have 91 octane, you should use the 91 octane map, if you have 92 octane, you should use the 91 octane map, and if you have 93 octane, you can use either the 93 octane or 91 octane map (the latter has a little less performance, but is more conservative). Additionally, if you live in Arizona, California or Nevada, you should use the 91 octane ACN maps.
Hope that helps!
Bill
FS : Cobb Accessport V1 2004 WRX shsjr89 SCIC Private Classifieds 77 10-28-2011 12:07 PM
f/s Cobb Catback, Cobb Downpipe w/Cat, Cobb AP Scooby_Wong SCIC Private Classifieds 12 05-10-2007 03:51 AM
TBE w/ Cobb AP vs. TBE w/out Cobb AP? Kopid Newbies & FAQs 14 10-05-2006 10:56 PM
cobb ap - bad cable or bad ap? v8eaterWRX AccessPort 3 05-26-2006 10:40 AM
"Det " w/ the Cobb AP 91oct stage 2 lwg Map Mach5WRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-19-2004 10:03 PM
