Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Motorsports Specific Items
Old 06-26-2011, 10:35 PM   #1
masti04
Member#: 117304
Default 04' STI Part Out
UPDATED 8/12/11
Below is the revised list of what I have to offer:
http://i1238.photobucket.com/albums/ff484/masti04/100_2537.jpghttp://i1238.photobucket.com/albums/ff484/masti04/100_2536.jpg
• Fully Built Motor (SOLD)
• STI 6-speed transmission; JDM 5th and 6th gears (transmission rebuilt at Rallispec in NJ) (SOLD)
• Full-Race Borg Warner (S300) twin-scroll turbo kit (SOLD)
• Racecomp Engineering Tarmac II coilovers w/ Cusco plates (500lbs./400lbs.) (SOLD)
• Perrin front mount intercooler with 3" custom intercooler piping (reversed intake manifold, A/C deleted) (SOLD)
• Turbo XS UTEC engine management with map selector (SOLD)
• 255l/h Walbro fuel pump (SOLD)
• Aeromotive fuel pressure regulator (SOLD)
• Group N engine mounts (SOLD)
• Group N transmission mounts (SOLD)
• Group N pitch stop mount (SOLD)
• Technafit clutch cable (SOLD)
• 6-gun 04' to 05' front hubs with new wheel bearings (SOLD)
• Drive Shaft Shop front axles (SOLD)
• Stock STI front axles (SOLD)
• Whiteline sub-frame bushing kit (SOLD)
• Perrin rear sway bar with mounts (SOLD)
• Perrin front sway bar end links (SOLD)
• Perrin rear sway bar end links (SOLD)
• Whiteline front 28mm front sway bar (SOLD)
• Whiteline camber bolt kit (SOLD)
• Whiteline urethane anti-lift kit (SOLD)
• Whiteline roll center kit (SOLD)
• Whiteline urethane inner control arm bushings (with STI aluminum control arms) (SOLD)
• Whiteline urethane lateral link bushings (with STI lateral links) (SOLD)
• Autometer gauges with A-pillar, center mount housings and sending units (SOLD)
• AEM UGEO wideband O2 sensor (SOLD)
• Apex'I AVC-R boost controller (SOLD)
• Safecraft halon fire suppression system (SOLD)
• RCE and RCI 5-point harnesses (SOLD)
• Autopower 4-point roll bar (SOLD)
• Technafit stainless steel front brake lines (SOLD)
• Turn in Concepts titanium brake and wheel bearing shims (SOLD)
• Netami driver’s seat (with Sparco mounts) (SOLD)
• Whiteline steering rack bushings (SOLD)
• Perrin O2 sensor simulator (SOLD)
• Crawford air/oil separator (SOLD)
• Canton Racing oil cooler thermostat (SOLD)
• Mishimoto aluminum radiator (SOLD)
• Crucial Racing thermostat (SOLD)
• Stock front Brembo calipers (SOLD)
• CL RC6 Racing front brake pads (for stock Brembos) (SOLD)
• Stock rear Brembo calipers (SOLD)
• CL RC 5+ Racing rear brake pads (for stock Brembos) (SOLD)
• Megan Racing front strut bar (SOLD)
• Megan Racing rear strut bar (SOLD)
• 14" tall aluminum wing (SOLD)
• Custom power steering reservoir with fluid cooler and stainless lines (SOLD)
• Drag 17" x 9" wheels with 275/40R17 Kumho Ecsta XS tires (~5000 miles) (SOLD)
• XXR 17" x 9" wheels with 275/40R17 Kumho V710 tires (~ 5 Auto-X’s, 2 Track Days) (SOLD)
• StopTech ST-40 (black) calipers (SOLD)
• CL RC 6 Racing front brake pads (for StopTech ST-40 calipers, brand new) (SOLD)
• StopTech street front brake pads (brand new) (SOLD)
• Hawk HPS front and rear pads for stock Brembos (brand new) (SOLD)
• Hawk HP+ front and rear brake pads for stock Brembos (~5000 miles) (SOLD)
• Spare wheel bearing assembly (05’) (SOLD)
• Sti stock front and rear springs (SOLD)
• Stock sub-woofer (under passenger seat) (SOLD)
• Rear diff (SOLD)
• Drive shaft (SOLD)
• DCCD controller (SOLD)
• Rear hubs (SOLD)
• Steering wheel (SOLD)
• Hood scoop vent (SOLD)
• Steering rack (SOLD)
• Instrument cluster (SOLD)
• Stock STI muffler (SOLD)
• Engine wiring harness (SOLD)
• Body wiring harness (SOLD)
• Fenders (SOLD)
• Bumper cover (SOLD)
• Shifter (SOLD)
• Steering linkage coupler (SOLD)
• Stock O2 sensors (SOLD)
• Starter bolts, bell housing bolts (SOLD)
• Rear deck (SOLD)
• Stock Airbox and MAF sensor (SOLD)
• Shifter bezel (SOLD)
• Shell (SOLD)
• DTEC MAP sensor ($25)
• SMC water injection ($75)
• Whiteline urethane front and rear trailing arm bushings (with STI trailing arms) ($50)
• Sparco Speed passenger seat (no mounts) ($60)
• Stock STI radiator ($75)
• Tire-Tail ($30)
• Cool Shirt 3" fans for brake ducts ($50)
• (x2) 8" extractor fans mounted under the hood to extract hot air ($20)
• Rear STI seats ($100)
• Stock 6-disk CD changer ($100)
• A/C compressor ($50)
• A/C condenser with all lines ($50)
• 3" Turbo XS RMA muffler ($250)
• Lower engine bay cover ($25)
• Windshield washer reservoir and pump ($25)
• Windshield wipers ($25)
• Windshield wiper motor assembly ($50)
• E-brake cables ($20)
• Fuse/relay box and cover ($30)
• Starter ($50)
• Rear seat belts ($40)
• Rear seat supports ($10)
• Grill ($20)
• Rear diff. support ($20)
• ECU ($200)
• Front speaker tweeters ($10)
• Stock front brake dust shields with custom brake duct mounts (5X100) ($30)
• Kaminari brake duct kit (no ducting, just hub brackets and hardware) ($50)
• U-shaped sub-frame brace ($30)
• Turbo XS uppipe ($25)
• Stock pitch stop mount ($15)
• Stock engine mounts ($25)
• Pedal assembly ($75)
• Stock oil pick-up ($15)
• Stock exhaust hangars ($10)
• Primitive Racing 3/16” thk. Aluminum rear diff cover (Non-STI) ($35)
• Primitive Racing 1/8” thk. Aluminum skid plate (does fit STI) ($50)
• Stock hood support rod ($10)
• ABS sensors ($50)
• Dome light ($10)
• Map lights ($10)
• Interior roof handles ($20)
• Roof liner ($50)
• Front and rear door interior door inserts ($150)
• Trunk inserts ($25)
• Door latches ($25)
• Hood release cable ($15)
• Front lower dash (under steering column) ($30)
• Center console (shifter and storage box) ($60)
• Center dash console (houses radio) ($25)
• Climate control and radio bezel ($10)
• Glove box ($25)
• Steering column ($50)
• Sun visors ($15)
• Center dash pod (clock) ($10)
• Center dash pod (gauges) ($10)
• ABS hydraulic control block ($50)
• Brake master cylinder ($30)
• Dash vent (center) ($15)
• Dash support beam ($75)
• Stock radiator fans ($50)
• Climate control blower (within dash for A/C and heat) ($100)
• Head lights ($100)
• Tail lights ($100)
• Spare donut tire ($50)
• Cowl cover ($20)
• Dead pedal ($10)
• Lower radiator hoses ($10)
• Horn ($5)
• AVCS solenoids ($40)
• Stock oil pump ($30)
• Oil cooler ($20)
• OEM shifter shaft ($10)
• OEM blow off valve with hose ($25)
• Cosworth size 1 rod bearings (brand new, in box) ($50)
• Brake booster ($40)
• Clutch master cylinder ($30)
• OEM clutch, and pressure plate ($50)
• Whiteline subframe spacer kit (brand new) ($30)
• Oil filter relocation housing ($25)
• A/C lines ($20)
• Stock bumper beam ($50)
• Stock catted down pipe ($30)
• Stock uppipe ($25)
• Stock exhaust manifold assembly with heat shields ($50)
• Hood scoop splitter ($25)
• Denso sensor under dash (98221FE110) ($25)
• Subaru side airbag sensors ($25)
• Subaru keyless entry system ($25)
• Denso left and right bumper sensors ($25)
• Denso DCCD yaw sensor ($25)
Please PM me with questions.
masti04 is offline   Reply With Quote
Old 06-27-2011, 12:07 AM   #2
RSTimpreza
Member#: 144808
2003 WRX
Sonic Yellow
pm'ed
RSTimpreza is offline   Reply With Quote
Old 06-27-2011, 12:39 AM   #3
IWantSubie
Member#: 212737
2003 WRX Spec R1
Sonic Yellow
pm'd you sir!
IWantSubie is offline   Reply With Quote
Old 06-27-2011, 09:42 AM   #4
SpamMansXe
Member#: 15920
1999 White Mock 22B
2014 Plasma Blue GR STi
I would like the Drag's. Where are you located?
SpamMansXe is offline   Reply With Quote
Old 06-27-2011, 10:53 PM   #5
Pudge
Member#: 264114
2001 2.5 rs
if the engine mounts fit my RS i'll take it
Pudge is offline   Reply With Quote
Old 06-28-2011, 01:53 AM   #6
CrazyLilPunk
Member#: 234155
05 STI
interested in the wheels, pictures and location?
thanks, Joe
CrazyLilPunk is offline   Reply With Quote
Old 06-29-2011, 01:37 PM   #7
BPax
Member#: 148621
2008 STi
Red
PM'd you.
BPax is offline   Reply With Quote
Old 06-29-2011, 02:03 PM   #8
ATVmxracer
Member#: 251114
05 wrx
wrb
What color is the car? If wrb, I'd be interested in the hood scoop. If its stock and oem paint in good shape.. Thanks
ATVmxracer is offline   Reply With Quote
Old 06-29-2011, 02:10 PM   #9
PSMetallic04
Member#: 269509
2004 WRX
PM sent about both sets of wheels and other small items...
PSMetallic04 is offline   Reply With Quote
Old 06-29-2011, 02:19 PM   #10
mase33
Member#: 214374
2009 WRX
Pm'd about the stock Brembos
mase33 is offline   Reply With Quote
Old 06-30-2011, 11:19 AM   #11
Brocku
Member#: 218852
'04 STI
PM'd you about rear Brembos and other stuff.
Brocku is offline   Reply With Quote
Old 06-30-2011, 04:41 PM   #12
johntr76
Member#: 283755
2006 Sti
Crystal Grey
do you have to stock boost gauge?
johntr76 is offline   Reply With Quote
Old 06-30-2011, 09:42 PM   #13
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Bump for amazing deals.
sackytar is offline   Reply With Quote
Old 07-01-2011, 02:58 PM   #14
T-dub
Member#: 244480
'07 WRX TR
CGM
• Whiteline roll center kit ($50)
• Whiteline urethane inner control arm bushings (with STI aluminum control arms) ($150)
I'll take both of these, if you please. Shipped to 77388.
T-dub is offline   Reply With Quote
Old 07-03-2011, 02:32 AM   #15
ice.xiv
Member#: 222298
Location?
Edit: Allentown, PA.
ice.xiv is offline   Reply With Quote
Old 07-06-2011, 12:47 PM   #16
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
whiteline front swaybar wanted shipped to 44035 bushing on bar go with it right??
EROCS04SBRUSTI is offline   Reply With Quote
Old 07-09-2011, 05:15 PM   #18
STi Hunter
Member#: 58131
05 STi 6,879 miles
04 Forester XT
Default Bump
Has the seller responded to anyone? Some of these prices are pretty amazing and I'd like to pick up a few of these things?
Hope some of these things work out!
STi Hunter is offline   Reply With Quote
Old 07-09-2011, 06:50 PM   #19
sackytar
Member#: 149262
PrimerGrey
pmed you!!!
Old 07-10-2011, 12:34 PM   #20
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
Free bump for a great seller! Everything was recieved in awesome condition and very quickly!
axelthrasher is offline   Reply With Quote
Old 07-10-2011, 03:35 PM   #21
justiceman
Member#: 268591
2004 wrx sti
wrb
bump for an awesome guy!!! got rims from him today. *****best seller****
justiceman is offline   Reply With Quote
Old 07-10-2011, 03:53 PM   #22
turbonerdz
Member#: 236816
1993 civic
pm'd.
turbonerdz is offline   Reply With Quote
Old 07-10-2011, 08:26 PM   #23
WRX2EVOX
Member#: 203011
04 WRX
Pm'd you about the following:
• Whiteline urethane lateral link bushings (with STI lateral links) ($75)
Thanks
WRX2EVOX is offline   Reply With Quote
Old 07-12-2011, 09:30 PM   #24
adamkob32
Member#: 194598
Seen the car is PSM, just wonder if you had the PSM sti hoodscoop laying around still. I'd take that off yours hands if so.
adamkob32 is offline   Reply With Quote
Old 07-13-2011, 03:15 AM   #25
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
pm'd, in for the bargains!
maxpowr is offline   Reply With Quote
FS: Huge 04' STi Part Out... VF34, PSM Bumper Cover, Full Steering Wheel, Injectors.. dmedak33 NWIC Private Classifieds 71 11-16-2009 12:41 AM
04' WRX Part Out! 18*8.5Fno1rc - Greddy Evo2 - HKS SSQV - GtSpec - Kenwood LeeWrx04 SCIC Private Classifieds 20 10-05-2007 07:31 AM
PA: Some 04' STi parts crookid7 Engine/Power/Exhaust 1 04-11-2007 11:07 PM
Stock 04' Sti parts for sale Pimp_my_Sti Engine/Power/Exhaust 6 12-20-2006 04:18 PM
