Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 07-25-2002, 01:23 PM   #1
potenzaus
Member#: 5278
Default Do I need to lubricate all the ...
... the bolts' threads of the swaybar and strut tower upon installation? Would grease be okay or something else is better?
Would 215/55/16 and 225/50/16 tires fit perfectly with the OEM wheels of a 2000 Legacy GT?
Thanks.
potenzaus is offline   Reply With Quote
Old 07-25-2002, 01:26 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
You dont have to lubricate the bolts, just where the rubber comes into contact with metal, so that would be the mounting bushings and one side of the drop links possibly.
You could get away without lubing any of it, but you may get alot of squeeking.
Old 07-25-2002, 05:42 PM   #3
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
Use a white lithium grease.
HIHO is offline   Reply With Quote
Old 07-25-2002, 05:46 PM   #4
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
You don't want to use a petroleum lubricant on rubber bushings - it'll disolve em. Poly bushings are fine, though.
gavin is offline   Reply With Quote
Old 07-25-2002, 05:49 PM   #5
tora
Member#: 5851
09 Forester XT
+ NA Miata
As said you don't need to lubricate all the bolts but should use never-seez. You can't go wrong using it and should never have siezed bolts if used. As for tires you can fit both those sizes, but the 225 will be a little pinched on that narrow a wheel. It works much better on a 7 inch wheel.
tora is offline   Reply With Quote
Do I need to replace all 4 tires? (Sort of urgent I guess) formula91 Tire & Wheel 9 12-17-2007 05:11 AM
in the process of priming turbo. do i need to unplug all 4 coil pack? VajraTLR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-30-2005 09:05 PM
1 blown tire, do I need to replace all 4? Capt Crunch Tire & Wheel 17 06-06-2004 05:23 PM
Do you need to buy from the dealer who will do service on your car? RhinoRex Newbies & FAQs 2 03-23-2003 05:41 AM
Help! Need to change all the Locks! Yebisu69 Tri-State Area Forum 4 11-22-2001 09:31 AM
