Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Complete Car Part-Out
Old 06-26-2011, 10:52 PM   #1
masti04
Member Sales Rating: (11)
Member#: 117304
Default (PA) 04' STI Part Out
UPDATE 8/22/11 NEED TO CLEAR MY GARAGE!! $1000 OBO takes everything that's left!!!
Ok, I FINALLY had a chance to update this list. Just about everything from the original list sold, but I added everything I have left with pics:
http://i1238.photobucket.com/albums/ff484/masti04/100_2460.jpghttp://i1238.photobucket.com/albums/ff484/masti04/100_2530.jpghttp://i1238.photobucket.com/albums/ff484/masti04/100_2537.jpg
• Fully Built Motor (SOLD)
• STI 6-speed transmission; JDM 5th and 6th gears (transmission rebuilt at Rallispec in NJ) (SOLD)
• Full-Race Borg Warner (S300) twin-scroll turbo kit (SOLD)
• Racecomp Engineering Tarmac II coilovers w/ Cusco plates (500lbs./400lbs.) (SOLD)
• Perrin front mount intercooler with 3" custom intercooler piping (reversed intake manifold, A/C deleted) (SOLD)
• Turbo XS UTEC engine management with map selector (SOLD)
• 255l/h Walbro fuel pump (SOLD)
• Aeromotive fuel pressure regulator (SOLD)
• Group N engine mounts (SOLD)
• Group N transmission mounts (SOLD)
• Group N pitch stop mount (SOLD)
• Technafit clutch cable (SOLD)
• 6-gun 04' to 05' front hubs with new wheel bearings (SOLD)
• Drive Shaft Shop front axles (SOLD)
• Stock STI front axles (SOLD)
• Whiteline sub-frame bushing kit (SOLD)
• Perrin rear sway bar with mounts (SOLD)
• Perrin front sway bar end links (SOLD)
• Perrin rear sway bar end links (SOLD)
• Whiteline front 28mm front sway bar (SOLD)
• Whiteline camber bolt kit (SOLD)
• Whiteline urethane anti-lift kit (SOLD)
• Whiteline roll center kit (SOLD)
• Whiteline urethane inner control arm bushings (with STI aluminum control arms) (SOLD)
• Whiteline urethane lateral link bushings (with STI lateral links) (SOLD)
• Autometer gauges with A-pillar, center mount housings and sending units (SOLD)
• AEM UGEO wideband O2 sensor (SOLD)
• Apex'I AVC-R boost controller (SOLD)
• Safecraft halon fire suppression system (SOLD)
• RCE and RCI 5-point harnesses (SOLD)
• Autopower 4-point roll bar (SOLD)
• Technafit stainless steel front brake lines (SOLD)
• Turn in Concepts titanium brake and wheel bearing shims (SOLD)
• Netami driver’s seat (with Sparco mounts) (SOLD)
• Whiteline steering rack bushings (SOLD)
• Perrin O2 sensor simulator (SOLD)
• Crawford air/oil separator (SOLD)
• Canton Racing oil cooler thermostat (SOLD)
• Mishimoto aluminum radiator (SOLD)
• Crucial Racing thermostat (SOLD)
• Stock front Brembo calipers (SOLD)
• CL RC6 Racing front brake pads (for stock Brembos) (SOLD)
• Stock rear Brembo calipers (SOLD)
• CL RC 5+ Racing rear brake pads (for stock Brembos) (SOLD)
• Megan Racing front strut bar (SOLD)
• Megan Racing rear strut bar (SOLD)
• 14" tall aluminum wing (SOLD)
• Custom power steering reservoir with fluid cooler and stainless lines (SOLD)
• Drag 17" x 9" wheels with 275/40R17 Kumho Ecsta XS tires (~5000 miles) (SOLD)
• XXR 17" x 9" wheels with 275/40R17 Kumho V710 tires (~ 5 Auto-X’s, 2 Track Days) (SOLD)
• StopTech ST-40 (black) calipers (SOLD)
• CL RC 6 Racing front brake pads (for StopTech ST-40 calipers, brand new) (SOLD)
• StopTech street front brake pads (brand new) (SOLD)
• Hawk HPS front and rear pads for stock Brembos (brand new) (SOLD)
• Hawk HP+ front and rear brake pads for stock Brembos (~5000 miles) (SOLD)
• Spare wheel bearing assembly (05’) (SOLD)
• Sti stock front and rear springs (SOLD)
• Stock sub-woofer (under passenger seat) (SOLD)
• Rear diff (SOLD)
• Drive shaft (SOLD)
• DCCD controller (SOLD)
• Rear hubs (SOLD)
• Steering wheel (SOLD)
• Hood scoop vent (SOLD)
• Steering rack (SOLD)
• Instrument cluster (SOLD)
• Stock STI muffler (SOLD)
• Engine wiring harness (SOLD)
• Body wiring harness (SOLD)
• Fenders (SOLD)
• Bumper cover (SOLD)
• Shifter (SOLD)
• Steering linkage coupler (SOLD)
• Stock O2 sensors (SOLD)
• Starter bolts, bell housing bolts (SOLD)
• Rear deck (SOLD)
• Stock Airbox and MAF sensor (SOLD)
• Shifter bezel (SOLD)
• Shell (SOLD)
DTEC MAP sensor ($25)
• SMC water injection ($75)
Whiteline urethane front and rear trailing arm bushings (with STI trailing arms) (SOLD)
• Sparco Speed passenger seat (no mounts) ($60)
Stock STI radiator (SOLD)
• Tire-Tail ($30)
• Cool Shirt 3" fans for brake ducts ($50)
• (x2) 8" extractor fans mounted under the hood to extract hot air ($20)
• Rear STI seats ($100)
• Stock 6-disk CD changer ($100)
• A/C compressor ($50)
• A/C condenser with all lines ($50)
• 3" Turbo XS RMA muffler ($250)
• Lower engine bay cover ($25)
• Windshield washer reservoir and pump ($25)
• Windshield wipers ($25)
• Windshield wiper motor assembly ($50)
• E-brake cables ($20)
• Fuse/relay box and cover ($30)
• Starter ($50)
• Rear seat belts ($40)
• Rear seat supports ($10)
• Grill ($20)
• Rear diff. support ($20)
• ECU ($200)
• Front speaker tweeters ($10)
• Stock front brake dust shields with custom brake duct mounts (5X100) ($30)
• Kaminari brake duct kit (no ducting, just hub brackets and hardware) ($50)
• U-shaped sub-frame brace ($30)
• Turbo XS uppipe ($25)
• Stock pitch stop mount ($15)
• Stock engine mounts ($25)
• Pedal assembly ($75)
• Stock oil pick-up ($15)
• Stock exhaust hangars ($10)
Primitive Racing 3/16” thk. Aluminum rear diff cover (Non-STI) (SOLD)
Primitive Racing 1/8” thk. Aluminum skid plate (does fit STI) (SOLD)
• Stock hood support rod ($10)
• ABS sensors ($50)
• Dome light ($10)
Map lights (SOLD)
• Interior roof handles ($20)
• Roof liner ($50)
• Front and rear door interior door inserts ($150)
• Trunk inserts ($25)
• Door latches ($25)
• Hood release cable ($15)
• Front lower dash (under steering column) ($30)
• Center console (shifter and storage box) ($60)
• Center dash console (houses radio) ($25)
• Climate control and radio bezel ($10)
• Glove box ($25)
• Steering column ($50)
• Sun visors ($15)
• Center dash pod (clock) ($10)
• Center dash pod (gauges) ($10)
• ABS hydraulic control block ($50)
• Brake master cylinder ($30)
• Dash vent (center) ($15)
• Dash support beam ($75)
• Stock radiator fans ($50)
• Climate control blower (within dash for A/C and heat) ($100)
Head lights (SOLD)
• Tail lights ($100)
• Spare donut tire ($50)
• Cowl cover ($20)
• Dead pedal ($10)
• Lower radiator hoses ($10)
• Horn ($5)
• AVCS solenoids ($40)
• Stock oil pump ($30)
• Oil cooler ($20)
• OEM shifter shaft ($10)
• OEM blow off valve with hose ($25)
• Cosworth size 1 rod bearings (brand new, in box) ($50)
• Brake booster ($40)
• Clutch master cylinder ($30)
• OEM clutch, and pressure plate ($50)
• Whiteline subframe spacer kit (brand new) ($30)
• Oil filter relocation housing ($25)
• A/C lines ($20)
• Stock bumper beam ($50)
• Stock catted down pipe ($30)
• Stock uppipe ($25)
• Stock exhaust manifold assembly with heat shields ($50)
Hood scoop splitter (SOLD)
• Denso sensor under dash (98221FE110) ($25)
• Subaru side airbag sensors ($25)
• Subaru keyless entry system ($25)
• Denso left and right bumper sensors ($25)
• Denso DCCD yaw sensor ($25)
PM me with questions.
masti04 is offline   Reply With Quote
Old 06-27-2011, 09:07 AM   #2
toflaherty
Member Sales Rating: (53)
Member#: 212765
2003 WRX
PM sent
toflaherty is offline   Reply With Quote
Old 06-27-2011, 12:35 PM   #3
boltfansmith
Member Sales Rating: (3)
Member#: 286743
2003 Wrx
Do you know if the A/C Compressor and condenser with lines will fit a 2002 wrx sedan??
boltfansmith is offline   Reply With Quote
Old 06-27-2011, 01:43 PM   #4
danstheman
Member#: 276914
2004 Forester
PM Sent
danstheman is offline   Reply With Quote
Old 06-27-2011, 04:44 PM   #5
Shylight
Member Sales Rating: (8)
Member#: 209812
2003 WRX
Platinum Silver Metalic
dibs on front brembo calipers
Shylight is offline   Reply With Quote
Old 06-27-2011, 06:00 PM   #6
haunt
Member Sales Rating: (37)
Member#: 132707
1998 White Coupe
2009 Silver WRX Hatch
looking for an sti catless upipe. please PM me price shipped to 98126 if you have it.
haunt is offline   Reply With Quote
Old 06-28-2011, 03:51 PM   #7
BigShoes
Member Sales Rating: (10)
Member#: 265534
2008 Spec B
paypal sent
BigShoes is offline   Reply With Quote
Old 06-28-2011, 04:47 PM   #8
05lgt
Member Sales Rating: (4)
Member#: 183415
2005 LGT
Int in motor mounts. How long were they on the car? Shipping to 74604
05lgt is offline   Reply With Quote
Old 06-28-2011, 06:50 PM   #9
Biggard09
Member Sales Rating: (6)
Member#: 285269
2004 WRX STI
Interested in trans mount, pitch mount and driveshaft. I'm in NJ so I could probably pick everything up. Thanks Nick
Biggard09 is offline   Reply With Quote
Old 06-28-2011, 08:01 PM   #10
rawboy
Member#: 276355
2012 Subaru
what kind of drag wheels and would you sell wheels alone and how much if so you can pm me if u want to
rawboy is offline   Reply With Quote
Old 06-28-2011, 08:46 PM   #11
icanfly
Member#: 176929
2005 STI Powered Dub
Carbon Black
Hey-
Wondering if you have interest in cutting out and selling the section of firewall that the pedals bolt to on the drivers side? I only need this section but the full section that contains the mounts for the pedal set.
Please advise as to interest, cost + shipping to 02169.
icanfly is offline   Reply With Quote
Old 06-29-2011, 03:48 PM   #12
TrunkMonkey24
Member Sales Rating: (1)
Member#: 253562
04 sti
headlights??
front bumper (and color?)
pics please!
TrunkMonkey24 is offline   Reply With Quote
Old 06-29-2011, 05:29 PM   #13
JRizzy24
Member#: 215468
2013 STi
Crystal Black Silica
Condition of rear seats and your location?
JRizzy24 is offline   Reply With Quote
Old 06-29-2011, 06:48 PM   #14
ATVmxracer
Member#: 251114
05 wrx
wrb
color of exterior? if wrb, i would be interested in the hood scoop. as long as its in good shape and oem paint is still on it. thanks
ATVmxracer is offline   Reply With Quote
Old 06-29-2011, 07:35 PM   #15
jakewrx
Member#: 217945
02 wrx hybrid 35r
blue
pm'ed
jakewrx is offline   Reply With Quote
Old 06-30-2011, 02:22 AM   #16
AWDSubby
Member#: 220496
PMed.
AWDSubby is offline   Reply With Quote
Old 06-30-2011, 09:27 AM   #17
masti04
Member#: 117304
Default Updated status
BUMP and updated status
Old 07-01-2011, 11:51 AM   #18
corbett123
Member#: 215698
2008 WRX
SSM
You have a pm sir
corbett123 is offline   Reply With Quote
Old 07-01-2011, 02:31 PM   #19
sb04wrx
Member Sales Rating: (31)
Member#: 204541
2006 STI
World Rally Boo
interested in rear bench. where in pa are you located?
sb04wrx is offline   Reply With Quote
Old 07-02-2011, 01:28 AM   #20
jstepp5220
Member Sales Rating: (17)
Member#: 207098
STI :( Gone
'14XV Gone, '10 FXT
How is the trunk? Color? Sti spoiler?
jstepp5220 is offline   Reply With Quote
Old 07-02-2011, 01:06 PM   #21
Ceez3607
Member Sales Rating: (47)
Member#: 138243
07 WRX STI 3076
Hey do you have the power steering pump? If you do pm me a price shipped to 22031
Ceez3607 is offline   Reply With Quote
Old 07-02-2011, 02:55 PM   #22
Jeffc4384
Member Sales Rating: (71)
Member#: 282076
Pm sent
Jeffc4384 is offline   Reply With Quote
Old 07-03-2011, 12:15 AM   #23
emsbuff124
Member Sales Rating: (22)
Member#: 201972
07 WRX TR
crystral grey
pm you
emsbuff124 is offline   Reply With Quote
Old 07-05-2011, 01:07 AM   #24
epil0g
Member Sales Rating: (2)
Member#: 210911
1997 impreza coupe
black
Ecu and tmic avail?
epil0g is offline   Reply With Quote
Old 07-05-2011, 01:24 AM   #25
Jeffc4384
Member#: 282076
Pm sent
FS : 04' STI Part Out masti04 Motorsports Specific Items 44 08-28-2011 12:15 PM
FS : (PA) 04' STI Part Out: 6-Speed w/ JDM 5th & 6th masti04 Drivetrain 4 07-07-2011 08:38 AM
FS : (PA) 04' STI Part Out; RCE Tarmac II's masti04 Suspension/Brakes/Handling 6 06-30-2011 08:25 PM
FS: Huge 04' STi Part Out... VF34, PSM Bumper Cover, Full Steering Wheel, Injectors.. dmedak33 NWIC Private Classifieds 71 11-16-2009 12:41 AM
04' WRX Part Out! 18*8.5Fno1rc - Greddy Evo2 - HKS SSQV - GtSpec - Kenwood LeeWrx04 SCIC Private Classifieds 20 10-05-2007 07:31 AM
