Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 06-27-2016, 10:36 AM   #1
Kirkathon
Member#: 354232
2004 Impreza WRX
Java Black Pearl
Default Northeast Ohio Subaru Tunes?
Hello, i have recently rebuilt my 04 Subaru WRX 2.0l and now is the challenge of getting it to pass E-Check.
I put a header back stainless exhaust with a cold air intake and now the car is throwing codes P0171 for the engine running lean, too much air flow it seems.
I was under the impression that the engine would run at peak efficiency with an intake and exhaust but it seems the computer is confused.
Also, would it be possible with tuning to eliminate an emissions code (P1400) and the catalytic converter code (P0420)?
Is there anyone in the Northeast Ohio area that does Subaru tuning? Or will i have to yank my ecu and send it out to get tuned somewhere? Just looking to get this accomplished ASAP since my temp tags expire in 3 weeks and i need the CEL off to pass E-Check.
Thank you for your help.
Kirkathon is offline   Reply With Quote
Old 06-27-2016, 11:37 AM   #2
Creel
Member#: 341772
2003 Impreza WRX
Plastidip White
If don't mind driving it down to the Cincinnati area Turn In Concepts can do it on their dyno.
Creel is offline   Reply With Quote
Old 06-27-2016, 01:21 PM   #3
seroki
Member#: 395675
16 WRX (RIP)
Pure Red
Buy a Cobb Access Port, get etune for your mods. BrenTuning can do it, and I imagine TiC can do it as well. Don't drive it without a tune that accommodates for the mods that are installed.
Also, Ohio got rid of E-Check years ago. If your county requires it, go get your tags outside of the county, no e-Check required.
seroki is offline   Reply With Quote
Old 06-27-2016, 02:43 PM   #4
Kirkathon
Member#: 354232
2004 Impreza WRX
Java Black Pearl
So you're saying that even though i live in a county that still requires E-Check, that i can go outside of this county to register the car at a different license bureau?
I really didn't think an intake and exhaust would cause so many problems on a 12 year old car. It's not like i tooled around with bigger cams or a turbo or injectors or anything.
I understand why it is causing problems, just didn't think it would.
Old 06-28-2016, 09:58 AM   #5
Creel
Member#: 341772
2003 Impreza WRX
Plastidip White
I was at TiC the other day and someone called asking the same thing. They said that sometimes it can do that on these cars. I remember when I did an intake on mine I ended up going back to stock pretty quickly. Could try giving them a call and see what's up, unless it was you who was calling them on Friday .
Old 06-29-2016, 10:28 AM   #6
Kirkathon
Member#: 354232
2004 Impreza WRX
Java Black Pearl
Yep that was me lol they were less than impressed with my choice of intake but apparently it works pretty well if the engine is running lean.
I can put the stock one on and maybe get rid of the P0171 code but i still have that P0420 catalytic converter code and the ridiculous P1400 code so i might need a tune regardless.
I have learned my lesson about these mods on subies: don't touch anything unless you are willing to compensate for it in the ECM.
Old 07-12-2016, 01:46 PM   #7
carse
Member#: 237993
75 MGB
Redline Tuning - Columbia Station, OH
or
TPG Tuning - Blairsville, PA
carse is offline   Reply With Quote
Old 07-13-2016, 07:51 AM   #8
WillDenham
Member#: 76687
2017 WRX STI
World Rally Blue
Anything power related really needs to be included in your tune, or you're asking for trouble as you said. I'd recommend avoiding intakes on most WRXs and STIs until you're well past the threshold and actually need some more airflow to make the power. A lot of tuners don't even recommend them until you're in the high 300HP range.
They can make some cool noises, but they're extremely limited on performance gains.
WillDenham is offline   Reply With Quote
Old 07-28-2016, 02:10 PM   #9
Kirkathon
Member#: 354232
2004 Impreza WRX
Java Black Pearl
Ok, so i have gotten rid of the P0571 and P0420 codes by putting my stock intake and tricking my cat 02 sensor with spark plug defoulers, respectively.
Now i am completely stuck on the P1400 code and i can't pass e check with it on.
First i would clear the code and start the car and the code would come immediately back on.
So i found a couple loose hoses next to the charcoal canister and put hose clamps on them.
Now, when i clear the code, it will stay off as long as the car is running but will reappear when the car is restarted.
This is a problem as stick shift cars have to be restarted in the e check facility and there is no way around that.
Any help would be greatly appreciated, i am about to go get another gas cap but i think if it was the gas cap it would throw the P0457 code, which it is not.
There has to be some part of this emissions system that malfunctions without leaking and i need to know what it is lol
O and the charcoal canister has 12V running to it no problem and the wiring looks in good shape.
