Old 07-25-2002, 03:52 PM   #1
rharder
Member#: 20795
2004 STi
Default When does boost kick in? At RPM? At WOT?
I thought I knew...and then some threads threw me off.
Does the turbo boost kick in (you know, with 14-ish psi) automatically past 3000RPM, or is it only when you floor the gas pedal?
-Rob
rharder is offline   Reply With Quote
Old 07-25-2002, 04:09 PM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Usually boost won't build up too far when below 3k rpm due to the engine not pushing enough exhaust to spool it up. However, the factory boost controller will limit to .5 bar below a certain % throttle position.
-Jon
www.nothingserious.net
Old 07-25-2002, 07:07 PM   #3
japriljr
Member#: 12521
2003 silver gtp
03 yellow srt-4
only when the throttle is past a certain point. www.summitracing.com and $50 = a nice new vdo boost gauge
japriljr is offline   Reply With Quote
Old 07-25-2002, 09:27 PM   #4
jamz
Member#: 8725
2013 Black Company
Annalist
Boost builds as a result of the turbo turbine spinning faster, which is a result of exhaust gasses spinning it. You don;t get enough exhaust gas speed below 3K RPM or so, so the turbo is not spinning fast enough to generate boost.
Past 3K however, there is enough gas to really spin the turbo hard, which in turn created the big boost you refer to. Electonicaly it is controlled (with a solenoid) to limit the boost in various situations (gearing, rpm, etc.)
jamz is offline   Reply With Quote
Boost kicking in late problem aug Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-27-2008 02:00 AM
When Stock Turbo/Boost Kicks In... Red Rexx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-31-2004 12:01 AM
PE1818 others who have it; when does your boost kick in? djdorazio Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-28-2004 05:40 PM
My Clutch Is Slipping when the turbo kicks in hard Scopeywithascooby Mid West Subaru Owners Club Forum -- MWSOC 3 10-14-2003 04:28 PM
When your Abs kicks in what does it Sound or feel like? SubaruImpreza_power Newbies & FAQs 17 10-02-2003 11:10 PM
