Old 06-28-2011, 03:01 AM   #1
ShredNW
Member#: 273912
07 wrx
Default Spray Painting techniques
can someone give me some tips on how to properly spray painting without putting too little or too much paint in a section?
also when i go for the first coat how should i go about doing this? do i spray across once then stop, then do the same a little in the next area?
ShredNW is offline   Reply With Quote
Old 06-28-2011, 03:25 AM   #2
amoore131
Member#: 222708
I'm no expert but your going to want to spray back and forth until you have an even coat without a lot of the paint building up because that causes runs. Let it dry and reapply several coats.
amoore131 is offline   Reply With Quote
Old 06-28-2011, 03:35 AM   #3
ShredNW
Member#: 273912
07 wrx
so pretty much the first coat doesnt have to completely cover the whole part im spraying? but then the additional coats should add on to completely fill the whole part? i think i tried adding too many coats the first time thats what caused paint buildups.
Old 06-28-2011, 06:54 AM   #4
04wrxhart
Member#: 204246
2004 Impreza WRX
WRBlue
Im no painter, but i heard that you dont want to let each coat dry completely before adding the next coat. I've heard that doing so will cause wrinkles, you could also probably try using Google.
04wrxhart is offline   Reply With Quote
tint spray/light spray paint for emblem? NMZ_WRX Interior & Exterior Modification 11 05-02-2011 03:59 PM
Painting WRB STi splitters SRR with paint code-matched spray paint? 05shagginwagon Interior & Exterior Modification 5 07-28-2010 03:09 PM
painting techniques tranjo Interior & Exterior Modification 4 06-25-2002 03:09 PM
paint code for pep boys look alike silver thorn metalic spray paint? ^jynx^ Interior & Exterior Modification 9 08-23-2001 11:46 AM
A touchup paint or spray paint? whtstr Interior & Exterior Modification 3 06-27-2001 09:42 PM
