Old 06-28-2011, 04:17 PM   #1
Entaille
Member#: 217875
2011 WRX
WRBP
Default 2011 wrx - usb port / thumb drive, re: 255 song max issue
hey guys - a while back, I posted in another thread about an issue with my usb drive / usb port combo only going up to 255 songs, then goes back to song 1 etc. there is a TSB for this problem .. or so I thought.
the dealership also thought the TSB was for this specific issue. hell, they contacted SOA who also told them that was the fix. they went to run a software update and discovered that I already had the newest on my car. they flashed it a couple of times anyways, and the problem persists.
if you hook up an ipod to it - it works fine, goes beyond 255 (had to borrow one to learn that). they are equally confused and more or less telling me sorry, I guess that's just how it works.
at this point, I just want to know if others can use a usb stick and play beyond 255 songs. I am a bit annoyed with the functionality and would prefer it be fixed if there is an issue that can be fixed. your input is appreciated
Entaille is offline   Reply With Quote
Old 06-28-2011, 04:21 PM   #2
paliknight
Member#: 285480
2011 WRX Limited
Sedan WRB
interesting. do you have the navi or not? i have the navi and will try it on my flash drive and will let you know.
paliknight is offline   Reply With Quote
Old 06-28-2011, 04:23 PM   #3
Entaille
Member#: 217875
2011 WRX
WRBP
i appreciate it. i don't have navi, so it won't be apples to apples.
Old 06-28-2011, 04:46 PM   #4
jlogic
Member#: 158630
2011 WRX ltd. Sedan
I have 16GB stick and I have noticed that it doesn't play many songs when set to random. I kept seeing the same songs over again. It seems to be able to access them when playing in direct mode, but I havent done any thorough testing to confirm.
jlogic is offline   Reply With Quote
Old 06-28-2011, 04:53 PM   #5
SamXp
Member#: 275355
2011 WRX
Interesting, I've also noticed that I have a few albums on my USB drive that never seem to get played. How would you test this to prove it?
SamXp is offline   Reply With Quote
Old 06-28-2011, 04:56 PM   #6
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Who the hell still uses 8 bit intergers these days? Programmer fail.
NITROS is offline   Reply With Quote
Old 06-28-2011, 04:58 PM   #7
Entaille
Member#: 217875
2011 WRX
WRBP
to confirm the issue I removed all of my folders (not really necessary) and took it off of random, and skipped to 255 and let the song play all the way through. I thought it was odd that I wasn't hearing some of my music, it took a while to notice that it never played a song beyond #255.
Old 06-28-2011, 08:52 PM   #8
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
This is the same issue that many Clarion aftermarket HUs have as well. No shock that the Clarion-made OEM unit also has the 255-song limit.
Clarion customer service says no fix on the aftermarket units. Same deal on the iPod being fully compatible. That was their "solution" when I called customer care. Crutchfield (where I bought my HU) gave the same weak answer about the USB file limit.
phenryiv1 is offline   Reply With Quote
Old 06-28-2011, 09:27 PM   #9
AcquaCow
Member#: 36838
2000 RS Sedan
2004 STi w/RS body swap
Weird...
I would have thought having stuff in folders would have eliminated that kind of problem...
AcquaCow is offline   Reply With Quote
Old 06-28-2011, 09:29 PM   #10
Entaille
Member#: 217875
2011 WRX
WRBP
nope - I originally had all of my albums in folders. I thought that the folders may be posing a limitation, so I removed them and saw the same results.
I don't want to raise a big stink about it but that was one of the most attractive features of the audio system, being able to pop in a usb stick. I doubt subaru is going to buy me an ipod for the inconvenience since there is apparently no fix. :[
Old 06-28-2011, 10:44 PM   #11
paliknight
Member#: 285480
2011 WRX Limited
Sedan WRB
mine doesnt even detect my USB drive
Old 06-29-2011, 09:46 AM   #12
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
This is just one more example of how most audio enthusiasts (even casual ones) overpaid for their WRX. Had Subaru made the HU just slightly better, many of us could have lived with the bleh design in trade for the long list of favorable features- BTA, BT phone, integrated SWCs, hideaway USB integration, aux-in...
Instead, we all had to rush out and yank the stock HU because between the native EQ curve in the radio, poor amplifier section, file limit on USB, etc., the OEM HU was a weak spot in the audio chain.
I STILL don't understand why car manufacturers don't just add RCA outputs. Even 1 set of 2V RCA outs would satisfy most people ("I just want to add a subwoofer.") and woudl make expandability in stages much easier.
With all of the other useless crap that the masses pay for in a car, the extra couple of bucks would be a joke. People pay for lots of user interface technology that they don't want/need...how about some output upgrades?!?
Old 06-29-2011, 12:40 PM   #13
Kanchou
Member#: 46936
2004 WRX
When engineering these head units, they use the dumbest and cheapest file handling engines available.
Most only use an 8 bit address space for the files, thus 255 limit.
There is generally never a fix for this because it usually is a hardware implementation of the cheapest level.
Instead, they trust that their market mostly owns IPODs which take over the job of indexing, controlling, and playing datastreams.
Its alot easier as a manufacturer to just have their hardware "play stream from X source" indefinitely using Apple's publsihed API than it is to implement a playback control scheme from scratch, a stream manager, file handler/parser etc etc etc.
The earliest manufacturer i know that didn't have this problem is Kenwood. And since JVC now have Kenwood guts, they too don't have this problem. (both known from personal xperience.)
Kanchou is offline   Reply With Quote
Old 06-29-2011, 06:02 PM   #14
DRTiraPiedra
Member#: 265912
Completely agree. Car enthusiasts are a very low percentage of the overall buyers market in todays market. Subaru is just trying to give buyers what they want. Musically the radio is crap, however for those who listen to talk radio station it is more then enough to keep them happy.
DRTiraPiedra is offline   Reply With Quote
2011 WRX - Stage 2 + E85 Tune - Dyno Results xluben Proven Power Bragging 65 01-11-2012 12:00 AM
Ap Log for 2011 WRX - Stage 1, 93 - CYLINDER KNOCK - PLEASE HELP.......... thegarius AccessPort 3 04-09-2011 08:03 PM
UOA - 2011 WRX - 4,700 Miles on GC jddssc121 Service & Maintenance 7 04-07-2011 05:47 PM
2011 WRX - Stage 2 - COBB Downpipe and SPT Exhaust (VIDEO) xluben General Community 47 01-19-2011 01:32 AM
2011 WRX - Boost Taper - Stage 1 vs Stage 2 xluben AccessPort 8 01-18-2011 04:24 PM
Message Board Statistics All times are GMT -4. The time now is 01:41 PM.
