Old 06-29-2011, 06:27 AM   #1
brandonk_5
Member#: 268700
Default Need help on setup of sound system
Hey everyone,
Some of you may remember that I made a thread awhile back on whether I should pursue the basslink or go with the two 12' mtx thunders that I had laying around. After a lot of thinking, I've decided to go the mtx route since I already have them.
Now my question is simply this (for the system gurus here). I was referred to the alpine mrp-500 amp (that's off the top of my head. Will update with link soon). With my current head unit (pioneer avh-p3300bt), stock speakers, and the former listed subwoofers, what kind of wiring am I looking at getting? Any other amp around 200 I should be looking for?
The reason I decided to go this route is because it seems I will be spending around 300 minimum anyways to buy a basslink and then set it up. If I don't end up liking this setup, I could sell it for a little more than 400 and then look into other alternatives although I believe I will be more than content with this route even if they aren't the best quality subs.
Lastly, if anyone knows any stores or places in Massachusetts you would recommend for buying audio equipment or getting this all installed, please feel free to speak up (I'll ask in regional later).
brandonk_5 is offline   Reply With Quote
Old 06-29-2011, 12:44 PM   #2
Kanchou
Member#: 46936
2004 WRX
well, from the headunit, you have: remote power, rca
from the amp you have: speaker cable, power cable, ground cable
the only thing you wouldn't need with a Basslink is speaker cable; you'd still need everything else in cabling...
Kanchou is offline   Reply With Quote
Old 06-29-2011, 02:51 PM   #3
CuratorXAngelus
Member#: 215403
2002 Impreza WRX
Ultra White/Fuschia Flake
you prob should run at least 4awg wiring. The MRP-500 is an awesome amp for its price. Alpine makes great efficient amplifiers. My friend used both an MPR-500 and an M-2000 for his woofer setups. also may want to look into a battery upgrade or a capacitor...personally I would say get a better battery
CuratorXAngelus is offline   Reply With Quote
Old 06-29-2011, 02:55 PM   #4
brandonk_5
Member#: 268700
Thanks for the help so far guys.
To the second post, I was talking about running the 2 12's. Sorry if that wasn't clear .
Old 06-29-2011, 03:14 PM   #5
burtont62
Member#: 148211
04 sti
black
Originally Posted by CuratorXAngelus View Post
capacitor...
capicator = no no.
burtont62 is offline   Reply With Quote
Old 06-29-2011, 03:37 PM   #6
Kanchou
Member#: 46936
2004 WRX
Reject any notion of a capacitor. Its an expensive and ultimately useless bandaid to an inadequate electrical system.
The fattest cable needs to be the power to the amp, and the ground to the amp.
The speaker cables can be 16 gauge or heavier; its such a short run, you not be losing anything, and just buy what you can afford.
Old 06-29-2011, 04:04 PM   #7
achilles224
Member#: 286465
'08 WRX SSM
'02 WRX WRB
Sound in Motion in Boston is great - but super expensive ($95/hour) if you don't buy from them, $80/hour if you buy the amp/wiring from them.
I'd say get a single amp wiring amp from crutchfield and do it yourself. There are plenty of threads for amp installs.
achilles224 is offline   Reply With Quote
Old 06-29-2011, 04:13 PM   #8
brandonk_5
Member#: 268700
That's also an option although not 100% comfortable with it, but good to learn.
Money isn't a huge concern (on the wiring part) as long as it's safe and effective.
Just looking to run that setup without taxing the electrical system .
need help on location of pcv valve on my 04 subaru awdguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 11-10-2005 03:46 PM
need help on install of NX intercooler sprayer! trbowrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-07-2004 04:24 PM
need Help on choices of ecu! wang Engine Management & Tuning 3 02-15-2004 08:18 PM
need help on installation of recaro seat Hojai Interior & Exterior Modification 6 05-23-2002 10:20 PM
('93-'01) Need help on model of Subaru LL Impreza Forum 5 06-10-2001 05:18 PM
