Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 06-28-2011, 11:12 PM   #1
Member#: 286527
2011 2.5i
Default Egg Damage
my hood has been seriously damaged by a sitting egg. its worse cause i wanted to spend the money id been saving on my suspension. anyway, is there any type of reasonable solution to corroded clear coat that wont drain my bank account? ill post pics asap. any help is appreciated.
timtam666 is offline   Reply With Quote
Old 06-28-2011, 11:39 PM   #2
Member#: 282965
If its not completely through the clear coat, you may be able to get a lot of it out with a DA buffer with some foam pads and some professional grade compounds.
Wildman113 is offline   Reply With Quote
Old 06-29-2011, 03:15 AM   #3
Member#: 201661
2013 STI
2002 Forester
pics? it's hard to assess since this type of hing could be an easy buff out to a complete repaint depending on a slew of variables.
kickniteasy is offline   Reply With Quote
Old 06-29-2011, 12:58 PM   #4
Member#: 286793
compound wax
and then try to get as much wax on it to help preserve whats left for now
bnoll is offline   Reply With Quote
Old 07-01-2011, 12:19 PM   #5
Member#: 151683
you won't get rid of it at all. Eggs actually destroy the ***** outta paint.. my car got hit and its crazy how small the paint chips are, perfectly rounded impact with tons of little chips..
smokey07 is offline   Reply With Quote
Old 07-01-2011, 03:04 PM   #6
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
There are typically two types of damage that can result from being "egged". Tiny chips (typically in a radial pattern at the impact point) from the shell breaking upon impact and chemical etching/hazing/staining of the finish from contents.
You can try using an OTC product like Meguiars Ultimate Compound and/or Swirl-X to see if you can remove (if not improve) the appearance of the affected area. Start with the Swirl-X first and then move up to the UC if needed (following up with the Swirl-X again to remove any of the fine marring left by the UC). How correctable your problem is will really depend on the extent of damage though.
Kean is offline   Reply With Quote
I want an Easter egg, I want an Easter egg! Brad Pittiful Off-Topic 28 03-31-2013 02:51 PM
will insurance cover cost of old damage + new damage vaznlyfe Off-Topic 16 09-09-2006 02:15 AM
Ford CEO hard to damage. hard to damage Briman2021 Off-Topic 8 05-13-2005 10:01 PM
Hard to damage "Memory Metal" is harder to damage eclone Off-Topic 6 03-31-2005 06:04 PM
This laptop must be hard to damage hard to damage. gongzero Off-Topic 4 09-10-2004 09:59 AM
