Old 02-14-2001, 05:13 AM   #1
Tony
Member#: 287
2005 9-2X Aero
Desert Silver
Question Hooking up an ALFA-Pro to a MY99 RS
[This is a crosspost from the STi-Mlist]
Has anyone here done this and wired the sender signal into the wiring harness on the ECU rather than mounting a separate sending unit to the wheel/tranny? If so which wire and where (I have the ECU pinout already)?
Tony
[This message has been edited by Tony (edited February 14, 2001).]
Tony is offline   Reply With Quote
Old 02-14-2001, 10:31 AM   #2
Ben
Member#: 423
2002 WRX wagon
Post
I was connected to both of the setting:1) Senser from Rolling wheels, 2)connect from the ecu's Speed signal.
in 1) you could make a "L" shape backet to hole the senser probe to the transmission and put the magnet to the cast of the inside CV boost.
2) you have to find which is the speed signal from the tranny to the ECU (in my 92 Subaru Legacy turbo 5sp, its a light green wire and I just found it under the glove box). BTW, you can't just connect to the Speed signal directly to the Alfa unit, since the pulse from the Speed senser is different to the Alfa unit, so you need to made a resister to correct the pulse to rally computer meter!! If not, you reading will total wrong!!
Ben is offline   Reply With Quote
How would I go about hooking up an amp+ capacitor to an Alpine CDA7894? neuspeed Car Audio, Video & Security 21 11-11-2006 03:14 AM
How to hook up an amp and sub to stock head unit?? maxpower_454 Car Audio, Video & Security 22 06-28-2005 02:06 PM
looking to hook up an xbox rnyce1 Car Audio, Video & Security 12 07-19-2002 12:51 PM
How difficult to hook up an alternate/back up power source for an alarm? ChosenWon Car Audio, Video & Security 5 10-23-2001 08:53 PM
Hooking up an amp to stock head, new possibility Section 8 Car Audio, Video & Security 13 07-01-2001 09:13 PM
