Old 06-29-2011, 01:41 PM   #1
jdubbs_wrx
Member#: 267341
2004 WRX
Default HORRIBLE knock with Cobb Stage 1 Map!!!
I've been experiencing some terrible knocking on a Cobb Stage 1 91 Oct map. Running Shell 91 (no ethanol). Car runs fine, but heard VERY audible pinging at 5k-6.5k rpm so I decided to log it.
2004 WRX, Cobb Stage 1 91 octane tune. Only mods are a 3" Cobb catback and a K&N panel filter.
3rd gear
https://spreadsheets.google.com/spre...=0&output=html
I have some more logs but they're the same or worse.
Running scary lean.
- Changed K&N filter to regular panel filter, cleaned MAF (No change in logs)
- Ran 94 octane on 91 tune still (Some minor improvements in logs)
- Changed fuel filter (HUGE improvements, NO feedback knock, IAM (DAM) stays at 15 instead of dropping to 4, but still have lots of fine learning knock)
Logs after ALL of the above changes...
https://spreadsheets.google.com/spre...thkey=CIS4tc8C
https://spreadsheets.google.com/spre...thkey=CPSC958G
https://spreadsheets.google.com/spre...thkey=CNyE3L4B
Still running very lean, with lots of fine learning knock!!
150km (not miles) on the car. Plugs changed at 96km scheduled maintenance. Stock up-pipe, downpipe.
It's looking like it's the Cobb OTS map at this point. I've sent my Accessport in for warranty repair so I can't even flash back to stock to find out for sure until I get it back.
Help!
jdubbs_wrx is offline   Reply With Quote
Old 06-29-2011, 02:12 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Go to a different gas station...
wrxdrvr is offline   Reply With Quote
Old 06-29-2011, 02:19 PM   #3
jdubbs_wrx
Member#: 267341
2004 WRX
I thought it was quite clear from my post that I did that.
Just to clarify, I used Shell 91 always.
Since then, I'm on Petro Canada Ultra 94. We don't have another source of 94. Once this tank is dry, I will try Petro 91.
Old 06-29-2011, 03:29 PM   #4
b1aze
Member#: 284003
2010 Alpine 135i
Originally Posted by jdubbs_wrx View Post
Canada
Theres your problem
b1aze is offline   Reply With Quote
Old 06-29-2011, 03:30 PM   #5
sanguines
Member#: 156128
2011 WRX
da ba dee da ba dye
Originally Posted by b1aze
Theres your problem
Blame Canada!
sanguines is offline   Reply With Quote
Old 06-29-2011, 10:33 PM   #6
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Have you checked for air leaks in the system?
project_skyline is offline   Reply With Quote
Old 06-29-2011, 11:18 PM   #7
jdubbs_wrx
Member#: 267341
2004 WRX
Yes but I'll check again everywhere. I pulled off the intercooler and checked the turbo inlet as best I could without taking it off. I'll check all vacuum lines again
Old 06-29-2011, 11:24 PM   #8
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
How are you checking for leaks? pressure test or just visual?
Old 06-30-2011, 08:16 AM   #9
Cobb Tuning
Member#: 4803
Hi there. Sorry for the troubles you've been having.
Your MAF readings look low. Unless you are at high altitude, I would start there. The MAF sensor could just be bad. I would start by swapping it out as a test from another WRX, if you can. The MAF sensor is how the ECU determines airflow and if it is underreporting airflow, you will run lean.
The OTS map itself will not cause you to run lean. The map is very deterministic about fueling. If one person were to run lean due to the map, every person using that map would run lean.
Also log A/F Learning #1 A, B, C, D. We need to see what your fuel trims look like after a bit of driving.
Bill
Old 06-30-2011, 01:27 PM   #10
jdubbs_wrx
Member#: 267341
2004 WRX
Just visual at this point.
Bill
No I'm not at high altitude. I cleaned the MAF the other day but I will swap MAF's with a friend today and report back here with new logs. That makes sense about the OTS map causing everyone to have the same scenario, but it's only my car.
Thanks for your help Bill
Old 06-30-2011, 02:13 PM   #11
JBmeth007
Member#: 281216
Any mods recently? Did this just start happening or occur over a bit of time?
Stock bypass valve? Plunger type? Diaphragm? Atmospheric
How long have you been running the map for? DAM=?
JBmeth007 is offline   Reply With Quote
Old 06-30-2011, 03:08 PM   #12
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
this cracks me up when people tell me this.
Old 06-30-2011, 04:18 PM   #13
jdubbs_wrx
Member#: 267341
2004 WRX
I'm glad it does, "CEO". If I took my car to your shop I would've wasted time and money for no reason checking for leaks. I guess you have to make money somehow.
CAR IS NOW FIXED!!!
Anyways, for the people that actually helped out (Bill and others). I swapped my MAF today with a buddy's WRX, car ran better than ever. NO knock, IAM stayed at 16, not pulling timing. Cleaned my old MAF, still knocked horribly. Went to a JDM place to buy a MAF for $100 (not about to spend $400 at Subaru unless I absolutely have to). He let me log the car with the new MAF before I bought it. IAM at 16, not pulling timing, no knock whatsoever. Feedback knock and fine learning all 0's.
Thanks again to the people that actually helped out.
FYI Canada sends most of our gas from the oil sands to the States anyways
Old 06-30-2011, 04:26 PM   #14
Phatron
Member#: 36033
CEO PhatBottiTuning
I didnt mean for that comment to come off like it did. Sorry.
The fact is you can only see about 25% of possible leak areas. The only type of leaks you can really find without pressurizing the system are leaks from loose hose clamps.
Glad you got it all sorted.
Old 07-09-2011, 11:55 PM   #15
ricky0418
Member#: 236866
2013 Charger SRT8
white
octane booster!
ricky0418 is offline   Reply With Quote
Old 07-10-2011, 07:55 AM   #16
ms6ftw
Member#: 286274
you should, go back to stock map, until you upgrade your dp, then run stage 2
ms6ftw is offline   Reply With Quote
Knock issues w/Cobb Stage 1 map. Please advise. sc00ter AccessPort 28 02-13-2012 11:53 AM
Knock issues w/Cobb Stage 1 map. Please advise. sc00ter Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 02-01-2011 03:49 PM
Knocking with gabedude's stage 1 map? Thunderbird28 Open Source Reflashes 4 08-19-2010 02:11 AM
have boost problem with cobb stage 2 map or PDX maps alvinli217 AccessPort 23 12-04-2008 02:59 PM
Help, Knock with Cobb Stage 1!!! 748eric Engine Management & Tuning 19 09-01-2004 01:47 PM
