Old 06-30-2011, 12:33 AM   #1
horrorbiz
Member#: 77290
15 VW GTI / FiST
Default Unmarrying an AP that I just removed the maps from...
Earlier today I bought an AccessPORT (originally purchased for and used on a 2009 WRX) for my 2011 WRX. The original owner returned his car to stock and then sold it. He assured me that he had unmarried the AP.
When I got home I hooked the AP up to my computer and updated the firmware. Then I deleted the old maps and installed the new ones for my car. After finishing I noticed the status said, "installed" and listed the car as a "2009 USDM WRX MT."
I contacted the guy I bought it from and he again claimed that he was almost certain he had unmarried the car. He then stated that he sold the car to his friend and that I could meet up with him to unmarry the AP.
My question is, will I still be able to unmarry the AP after deleting the stored maps off it?
I have to drive a couple hours to end this marriage—what do I need to do to make sure it is fully unmarried?
I apologize for the length! Thanks!
horrorbiz is offline   Reply With Quote
Old 06-30-2011, 10:47 AM   #2
Sheltonmega
Member#: 265204
2009 WRXCobbProtuned
CattedAEMCAIPerrinTMIC93
I have tried Uninstall (unmarry or divore)and I saw the AP returned to the original state which in the menu you only see install help and troubleshoot. I assume if you try install again, it will try to detect the new car.
Sheltonmega is offline   Reply With Quote
Old 06-30-2011, 11:12 AM   #3
horrorbiz
Member#: 77290
15 VW GTI / FiST
Since it's still married to the old car when I plug it into my car it doesn't try to recognize my car.
I just want to be sure that I will be able to unmarry it from the original car even after I deleted the maps that were stored on it.
Old 06-30-2011, 01:34 PM   #4
Sheltonmega
Member#: 265204
I don't think the marriage certificate is stored in the maps Hopefully you are ok there. But I am not an expert on this, you have to unmarry it anyways so you have to try.
Old 06-30-2011, 01:37 PM   #5
horrorbiz
Member#: 77290
15 VW GTI / FiST
Thanks—that's what I am hoping. I just don't want to mess up the other person's car if I deleted something important.
Old 06-30-2011, 01:46 PM   #6
MSMStannyl
Member#: 267225
2011 WRX Limited 4DR
Satin White Pearl
I don't know for sure but I thought that when you first hook up an AP to marry it, doesn't it download your factory ECU programming to itself? Not sure if you can delete it through the AP manager. Hopefully not because it will need that map to actually unmarry (I would think).
I bought my AP used as well. It's always a risk. Luckily mine worked out ok and I had no problem installing it on my 2011. I wonder if yours still said it was a 2009 because that was the last car it was installed in. Then again, you said you tried installing it and it wouldn't let you so there's definitely an issue. Worst case, I believe Cobb can re-format them (for a charge I believe) but you'll probably have to prove it's not stolen...
MSMStannyl is offline   Reply With Quote
Old 06-30-2011, 02:19 PM   #7
horrorbiz
Member#: 77290
15 VW GTI / FiST
I posted this question on the Cobb Forums and got an asnwer: "The short answer is, yes, that will not be a problem at all. The maps not being on the Accessport will not inhibit uninstallation. There is information already stored on the AccessPORT that will allow the unit to be completely uninstalled. Just make sure you select the "uninstall" selection on the main menu and follow the prompts, this will uninstall the AccessPORT!"
Unmarrying an AP Americanrebel21 AccessPort 4 08-14-2008 03:42 PM
Unmarrying an AP TheBlacKnight AccessPort 2 09-14-2006 09:57 PM
Just got unmarried 04 AP, can i just use it? o2sys AccessPort 5 04-23-2006 10:31 AM
For people that have removed the turbo from the Sti TheMadScientist Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 91 02-12-2006 11:10 AM
Will removing the wing from an STI change its autox classing? celer Motorsports 69 07-19-2005 03:40 PM
