South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 06-30-2011, 02:56 AM   #1
SUBAWRECK
Member#: 276955
1st White and 2nd Blue
Default My Fresh Start Build Thread
In this thread I am honestly not looking for people's negative opinions. I am looking for any tips or ideas on how to achieve the same concept cheaper, anyone who has the parts I need, connections to people who get quality parts cheaper, or anyone who wants to help.
Now starts the list.
This list is not in order of importance, just list of items I want to gather before I start my build.
The build is on a gc either version 5 or 6 and is a sedan.
Total build budget is set at 12k.
LIST:
Engine:
JDM EJ20g from an 89 to 91 legacy turbo (shortblock)
- Forged pistons and rods (500hp capable)
- Forged crank
(completely rebuilt)
Heads:
JDM V7 or newer STI (AVCS)
- hi rev kit
- slight oversized valve kit
- over port and polish intake (15% increase)
- 272 cosworth STI cams
INTAKE MANIFOLD & TGV'S:
-Top Secret
- whatever I use it will be polished too
- phinolic or finnolic spaced
Intercooler:
- USDM V8 STI
- full perimeter custom (top and bottom) CO2 spray
Turbo and Intake:
- TD05 20g
- relocate 8inches towards passenger side fender
- rotate 20 degrees clockwise
- custom 65mm cold air intake
(cutting restrictions)
Exhaust:
- ceramic coated everything
- Oversized unequal length header (2 - 3mm)
- custom oversized uppipe to match new turbo setup
- 4 inch custom down pipe
- straight 4 inch to axleback
- 1 12 inch resonator to 5 inch tip
Just stared thread more to come was
Thanks
SUBAWRECK is offline   Reply With Quote
Old 06-30-2011, 03:11 AM   #2
wadud
Member#: 258048
06 wrx
E.S.A.C
Pics!
wadud is offline   Reply With Quote
Old 06-30-2011, 03:29 AM   #3
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
Build thread, or more of a wish list? In for pics!
KP is offline   Reply With Quote
Old 06-30-2011, 04:02 AM   #4
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
If I had to do it all over again (for like the umpteenth time) I would buy a wrecked STI and swap EVERYTHING over, then worry about upgrading the stock STI setup (in a GC chassis of course).
Unfortunately wrecked USDM STI's didn't even exist back in the day and we didn't have the fraction of options that are available now.
Honestly, the strength of the drivetrain is not that big of a deal in a GC, it's the wiring. IF you swap an olderstyle rotated setup, you're not gonna be able to find parts for cheap. UP, DP, IC, turbos themselves and so on.
If you do a 01(JDM)-02(USDM) WRX/STI setup setup with a non-rotated mount, then you have a bajillion options as far as upgrade parts.
bobturismo is offline   Reply With Quote
Old 06-30-2011, 08:41 PM   #5
SUBAWRECK
Member#: 276955
Drivetrain:
- STI 6 speed
- Matching rear diff
- STI knuckles or hubs
- New cv axles
Suspension:
- STI stock struts
- Tien type r lowering springs
- Whiteline sway bars and strut tower bars
More ideas to come
Old 06-30-2011, 11:33 PM   #6
superblkwrx
Member#: 129395
2006 OBPWRX VF39 E85
333WHP 385WTQ 21PSI SD
I have a 25% discount on parts at subaru in Peoria so if you come accross any OEM parts you need i can help
superblkwrx is offline   Reply With Quote
Old 07-01-2011, 01:00 AM   #7
SUBAWRECK
Member#: 276955
Thanks so much I will def keep you as a connection point. Can u pm me ur contact info... thanks
Old 07-01-2011, 01:16 AM   #8
Momosaurus WRX
Member#: 214737
why an ej20g from a legacy turbo? If you're just using the shortblock, it doesn't matter what it came from. It can come from a number of jdm wrxs, stis, and even foresters I believe.
Momosaurus WRX is offline   Reply With Quote
Old 07-01-2011, 01:23 AM   #9
SUBAWRECK
Member#: 276955
They r super cheap and the internals can hang with some boost if I don't have money for all the forged stuff
Old 07-01-2011, 10:06 AM   #10
yman
Member#: 199051
04 sti
psm
I would say buy this and don't wreck it, or a turbo GC that is in running condition.
http://forums.nasioc.com/forums/show....php?t=2187968
Also this is very cool too and would go back to the roots of Subaru rally, would be a cool project to perfect
http://forums.nasioc.com/forums/show....php?t=2201226
If it was good enough for Colin then its good enough for me
yman is offline   Reply With Quote
Old 07-01-2011, 01:30 PM   #11
Momosaurus WRX
Member#: 214737
The ej20g is a great shortblock to start with (because it is a closed deck engine), but finding one from a jdm turbo legacy is a bit more difficult than just finding any ej20g from any jdm legacy, wrx, sti, forester, etc. And the issue with using an older block, is that they get "clapped out", meaning everything is supposed to have good tight tolerances and such, but the actual block is worn out and could potentially fail before anything else.
I know this is rarely discussed/covered in engine builds, but I have seen a few cars that used old engines and the actual engine casing broke just from use and abuse before anything else, and if the engine casing cracks/gets a hole blown out of it, alot of other things are going to get damaged.
Just something to keep in mind. I don't know much else about engine builds lol.
Old 07-01-2011, 05:22 PM   #12
SUBAWRECK
Member#: 276955
Very true... def something to keep in mind... I really want a 2.2 sleeved and stroked and throw 40 pounds at it with a meth system and 800cc injectors, but I have to think cheap and reliable
Old 07-01-2011, 05:22 PM   #13
SUBAWRECK
Member#: 276955
I have also seen pics of just plain wore out motors... it sucks
Old 07-01-2011, 07:56 PM   #14
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
800cc's... 40psi.. lol.
Old 07-01-2011, 08:15 PM   #15
yman
Member#: 199051
04 sti
psm
yikes, maybe 2000cc
Old 07-02-2011, 12:34 AM   #16
SUBAWRECK
Member#: 276955
Nah just 8 injectors... standalone controlled when I hit 10k rpms I was joking
Old 07-02-2011, 01:04 AM   #17
yman
Member#: 199051
04 sti
psm
With 12k I think its going to be impossible to have a 40 psi sleeved/stroked GC. Maybe with 20k? Have you put a price on each of those items, not to mention labor/tuning/odds and ends? Beer/pizza/long nights not to mention, all the new cuss words you'll invent.
Old 07-02-2011, 05:36 AM   #18
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
You'll spend 12k in a motor to rev high enough to make use of the power, a turbo that's efficient enough to make power up at 40psi on a 2.whatever liter motor, and a bottom end that's going to hold together.
Old 07-02-2011, 06:30 AM   #19
Momosaurus WRX
Member#: 214737
yman, the 20k won't hold up as well as the 20g to high boooooost
Old 07-02-2011, 09:04 AM   #20
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
^He meant price, not EJ20's lol
Old 07-02-2011, 12:46 PM   #21
madmax_087
Member#: 197077
1992 Dodge Ram W150
BAN CORINATOR
Exclamation
I like how in the first minute or so, he beats the ****ing piss out of that car, like he hates it and wants it to die, and ends up with all manner of broken ****, then gets 3rd. What a ****ing G.
1980's BMW engineers say "**** you"
madmax_087 is offline   Reply With Quote
Old 07-02-2011, 07:16 PM   #22
Momosaurus WRX
Member#: 214737
ah. :facepalm:
You can never trust them damn Nazi's.
Srsly though max, I've seen some old engines blow a hole in the casting, when nothing went wrong. Everything was fine, then boom goes the block.
Old 07-04-2011, 03:30 AM   #23
SUBAWRECK
Member#: 276955
So I'm peeling the old me off.... I apologize to everyone I attacked or offended... since my accident I've had terrible anxiety and can't sleep very well...I've been get tests done and found a bomb medication... I will not post before I think or let my anger get the best of me...
I do not like how hard ppl r to eachother.... specially elders to noobz... its seriously a pwnfest... for myself I sincerely apologize... I do not think my crash was at all cool or that I'm superhuman... as everyone states about ppl I attack, if u knew me u would think differently too... kplu... my bad... seriously....
what I mean is: I lend a hand to everyone subi or not and never charge a dime... I sell **** super cheap bcuz I kno we all have other things to do then loan out cash for something too overpriced....
I work at sprouts... barely enough to live off.. I earned my way in and out of my first subaru... sold 4 things to get one.. then insurance gave me the money for the second... that one blew up.. now I'm here... ready to start floorup...
can i be forgiven and move forward?....
I'm not a dumbass... and I never charge to wrench.... if n e one ever needs an extra tech... just get me a bus pass and I will be there...
thanks SWIC ... I look forward to more positive postings
Old 07-04-2011, 07:35 PM   #24
06AZREX
Member#: 132244
2006 OBP WRX
2006 BMW 325i
Well man, I think your off to a better start than before. People on here make stabs at each other and for the most part its in fun. John
06AZREX is offline   Reply With Quote
Old 07-04-2011, 08:20 PM   #25
05bluesti
Member#: 251804
05 WRB STi
I agree, much better start, and yes everyone takes jabs at everyone, especially me(thats what i get for being the youngest ) come out to a meet, most of us aren't ******** haha
05bluesti is offline   Reply With Quote
Cyclops' build thread part 2: reassembly. '00 coupe, fresh paint, 35r, tons of sti! Cyclops Member's Car Gallery 549 02-06-2015 12:55 PM
My 95 Impreza build thread terrynh Member's Car Gallery 28 11-06-2011 10:49 PM
My ____ mistress build thread! iheartwrxSTI Member's Car Gallery 22 03-17-2011 01:05 AM
My newest GC build thread*** NEW PICS*** sleepysubie Rocky Mountains Impreza Club Forum -- RMIC 69 10-03-2010 02:38 PM
My very slow build thread 05BluePearlGT South West Impreza Club Forum -- SWIC 17 08-14-2007 04:41 PM
