Old 07-25-2002, 06:52 PM   #1
Dylan
Member#: 16537
96 Acura RL
Question what to do
hhhuuuummmm,
I currently have ver 5, w/ eibach's, Mostly it's bouncy, i'm fine when i drive along, dosen't bother me really. But when i have a passenger they have the bobble head thing goin (haha) it's even worse in the back. Plus a smoother ride will be nice, and I don't think I could go anything less than what I have now, would miss it to much.
Alright i've read every post about ver 5 struts, agx's, and springs.
I've ruled out the agx's cause I want the lowered ride and there not technically made for a legacy, but they work and i have great struts already. So where i'm stuck is do i need different springs, and or new strut top mounts or something else..... oh whats the dif between h&r and Eibach, cause i read good things about the h&r w/ ver5 struts. Can I better my ride is the question?????
and here is a pic for the hell of it.
Dylan is offline   Reply With Quote
Old 07-25-2002, 08:01 PM   #2
snowone
Member#: 6035
05 92-X Saabaru
87 VW Westfalia
I'm hesitent to suggest anything, as I do not have any direct experience with this setup. But from what I've read and considered, I would say you're correct in hooking up some STI (or other) topmounts, and/or a different set of springs w/ diff. rates? The GC Ver5 setup that was up for sale a week or two ago looked real good... especially if you got real specific on what rates you wanted with 8, 9, or 10" springs.
Good luck... I'm interested in hearing more about this too. I really want to get a stiffer setup, but don't want to bounce, or loose too much ground clearance for winter/mtn driving. Considering AGX w/ stock springs.
snowone is offline   Reply With Quote
Old 07-25-2002, 09:37 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
why are you discounting the AGX's right off the bat?
Unless you have lowered the car more the 1.5" they should work.....assuming they do make an application for your car.
They are a good strut.
Another thing.....the Eibach's have a very harsh ride! I would look into some other springs, H&R, whiteline, MRT, or even sti.
The bouncy is caused by not having enough damping to control the high spring rates of the eibach's.
I'm not sure what would have a higher damping ratio then the V5 struts?
You could try sti top mounts first to see if they help. I have heard of them helping a little.
Legacy777 is offline   Reply With Quote
Old 07-26-2002, 10:01 AM   #4
Dylan
Member#: 16537
96 Acura RL
Thumbs up
legacy777 my car is lowered probably 1.25 +-, and i was thinking of the H&R springs, correct me if i'm wrong but they lower the car a bit more than the Eibach's, so the thats why i'm staying with the ver 5's, just need to figure out what springs and possibly top mounts to go with. I heard the best about the H&R's so far.
Thanks,
Dylan
Old 07-26-2002, 10:13 AM   #5
Legacy777
Member#: 4800
dylan,
Not sure about the lowering height with the H&R's. But yeah....if they lower more....prob best to stay with what you got.
good luck with whatever you choose.
Josh
mismatched turbo, what to do 07 sti manjambles AccessPort 12 06-10-2010 10:04 PM
What to do what to do what to do... kicking1012003 Interior & Exterior Modification 5 08-09-2007 12:19 PM
What to do, What to do?? beobe99 Normally Aspirated with bolt-on Forced Induction Powertrain 4 01-13-2002 12:26 AM
What to do....what to do wolf8314 Mid Atlantic Impreza Club -- MAIC 11 08-27-2001 08:50 AM
what to do, what to do.... Matt Monson General Forum Archive 8 06-30-2000 12:58 AM
