Welcome to the North American Subaru Impreza Owners Club Sunday July 13, 2014
Old 02-22-2012, 05:42 PM   #26
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
this thread is awesome. intructions and links for parts. op put in some good work
achavez is offline   Reply With Quote
Old 02-24-2012, 06:37 PM   #27
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
This is my engine bay. Where to stick the boost leak tester into? Sorry for such a noob question. I'm assuming after the intake? I just want to double check since I have a EJ20G with a 90 degree inlet turbo.
sizzflair is offline   Reply With Quote
Old 02-24-2012, 07:30 PM   #28
68Cadillac
Member#: 95901
Find the MAF sensor. Take out that section of piping. Couple the boost leak checker to the section of intake where the MAF just connected up to.
Get soapy water in a spray bottle. 20 parts water to 1 part dish soap. Start spraying.
68Cadillac is offline   Reply With Quote
Old 02-25-2012, 10:28 AM   #29
sizzflair
Member#: 94268
2010 Exige S240
I don't have a MAF. But basically you're telling me to remove the intake and stick it into my blue 90 degree elbow. Thanks!
Old 04-12-2012, 01:11 AM   #30
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
Update: I sold my tester to someone in another country who could not acquire the parts. Therefore, I had to build another. In the process, I realized I had the wrong 1/8" to 1/4" adapter listed. The one I had listed was a female 1/8" to male 1/4", when it should have been this female 1/8" to female 1/4": http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
I updated the spreadsheet.
D0nets is offline   Reply With Quote
Old 05-01-2012, 08:41 PM   #31
V8 BAIT
Member#: 279592
04 LSx Mustang
Seeing these inspired me to spend the 10 bucks and make one, glad I did, found a small leak, didnt notice anything different after, but peace of mind is always nice
V8 BAIT is offline   Reply With Quote
Old 06-02-2012, 09:53 PM   #32
ukranianization
Member#: 238506
2003 wrx
Psm
can the intercooler be off while I'm doing the leak test or no?
ukranianization is offline   Reply With Quote
Old 06-04-2012, 01:33 PM   #33
V3rtigo
Member#: 262020
2013 STi-Limited
PBP
It can't
V3rtigo is offline   Reply With Quote
Old 06-04-2012, 05:19 PM   #34
jack klompus
Member#: 152885
2014 Malibu LTZ
It can, if you just want to test past the throttle body. If I'm chasing down a leak thats pissing me off, I'll hook up the tester right to the throttle body and check there. Sometimes it's easier to break it into smaller sections.
jack klompus is offline   Reply With Quote
Old 06-08-2012, 09:16 PM   #35
WV_scooby
Member#: 322421
2005 Impreza WRX
World Rally Blue
I tried to do the test, but wasn't able to maintain any pressure. Can anyone confirm if I've identified the right hoses to plug off?
Evap Purge Solenoid?
PCV Breather hoses?
Are either of these the crankcase breather?
WV_scooby is offline   Reply With Quote
Old 06-09-2012, 12:14 AM   #36
20wrx09
Member#: 207417
2009 WRX
td06sl2-20gtx 413/423
the last two are the throttle body coolant hoses.
20wrx09 is offline   Reply With Quote
Old 06-09-2012, 04:52 PM   #37
WV_scooby
Member#: 322421
2005 Impreza WRX
World Rally Blue
Thanks, so the other hose are correct?
How do I identify the crankcase breather?
Old 06-16-2012, 12:14 AM   #38
sol_tegra
Member#: 259406
02 WRB WRX
D0nets,
thanks bro i received it already.
got a question, i just thought about how can i adjust the pressure i want into the system without letting in too much pressure and just blowing pass all the seals. Something like a pressure regulator or do you just open the valve a little til u get it to the psi you want?
sol_tegra is offline   Reply With Quote
Old 06-16-2012, 05:20 PM   #39
cablegorilla
Member#: 288942
2011 wrx premium sed
Subscribed. I am going to do this soon. My 2011 WRX pro tuned is acting all sorts of weird and this is in order. Great write up man
cablegorilla is offline   Reply With Quote
Old 06-17-2012, 01:52 AM   #40
sol_tegra
Member#: 259406
02 WRB WRX
if you live in CA or NV you may not be able to find some of the parts as they dont carry it!
Old 07-25-2012, 10:13 PM   #41
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
Originally Posted by sol_tegra View Post
D0nets,
I usually set the psi on the compressor to about 30. It takes a few seconds to fill the system so I just open the ball valve until the gauge reads to target and then i shut the ball valve off.
Old 07-25-2012, 10:46 PM   #42
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
What cant you find?
Old 10-22-2012, 06:12 PM   #43
Acejam2k
Member#: 42645
2007 STI
Crystal Gray Metallic
Question:
I don't have a big air compressor for air tools. However, I do have a very powerful portable tire inflator, which can inflate 5-10lbs of air into a tire in less than 30 seconds. Any chance I could build one of these boost leak testers, and simply use it with my air pump?
I have this, which actually works very well and is incredibly fast:
Slime COMP06 Pro Power Heavy-Duty 12-Volt Tire Inflator : Amazon.com : AutomotiveSlime COMP06 Pro Power Heavy-Duty 12-Volt Tire Inflator : Amazon.com : Automotive
Acejam2k is offline   Reply With Quote
Old 10-22-2012, 06:16 PM   #44
vision.dynamix
Member#: 139955
2015 Subaru STI
Black, like my soul.
That should work fine.
vision.dynamix is online now   Reply With Quote
Old 10-22-2012, 06:18 PM   #45
Acejam2k
Member#: 42645
2007 STI
Awesome, thanks! Definitely going to try this out tomorrow.
Old 10-23-2012, 10:15 AM   #46
Acejam2k
Member#: 42645
2007 STI
I have a Crawford AOS, therefore my PCV is gone. Do I need to disconnect the crankcase breather in which the Crawford plugs into? Alternatively, I could just disconnect this line from my turbo inlet, and vent it to atmosphere. I just don't want to blow a cam seal.
Old 10-24-2012, 01:19 PM   #47
Acejam2k
Member#: 42645
2007 STI
Anyone? ^^
Old 11-01-2012, 01:14 AM   #48
Acejam2k
Member#: 42645
2007 STI
I decided to build this boost leak tester to check for leaks. However I don't have an air compressor - I only have a small but powerful tire pump. Therefore, I needed a schrader valve configuration. After lots and lots of research and phone calls, I finally tracked down the parts that are needed to connect this to a normal tire pump. The best part is, they can be found at any local NAPA. There are a total of 2 parts needed, in addition to the parts list found in the first post.
1/8" NPT Tire Valve / Schrader Valve
NAPA Part #: NTH 90294
http://www.napaonline.com/Catalog/Ca...294_0344221587
$2.29 / each
1/8" NPT to 1/4" NPT Adapter
NAPA Part #: WH 3220X4X2
http://www.napaonline.com/Catalog/Ca...4X2_0215604875
$1.49 / each
The result:
Old 11-21-2012, 09:35 AM   #49
Crazyspeedfreakz
Member#: 338497
Hi there ...
I'm in urgent need of help ... I current have a v5 (99) STI that has boost leak, I have made a boost leak tester but I am unsure of what I should be disconnecting / capping off to pressurise the system
I have a aftermarket turbo intake pipe with 1 take off that looks as if it goes to the boost solenoid... I also have a catch tank fitted
All the threads I can find see more towards Newage imprezas not the classic if any1 can help
I can get a pic up of engine bay if required
Thanks in advance
Crazyspeedfreakz is offline   Reply With Quote
Old 11-21-2012, 09:52 AM   #50
Acejam2k
Member#: 42645
2007 STI
Originally Posted by Crazyspeedfreakz View Post
Hi there ...
Thanks in advance
A picture might help.
Boost Leak Tester DIY - Precautions V8 GTFO Lesbic WGN Newbies & FAQs 10 08-24-2009 10:23 PM
Great Catch cans and boost leak testers Chrisgst99 Car Part Reviews 1 07-02-2009 03:07 PM
DIY boost leak tester habitatxskate Factory 2.5L Turbo Powertrain 13 04-06-2009 01:56 PM
anyone got a boost leak tester i can borrow? kenny08 Southern California Impreza Club Forum -- SCIC 2 02-01-2007 07:39 PM
Home-made boost leak tester? 03MBP Factory 2.0L Turbo Powertrain 1 11-23-2005 05:52 PM
