Old 11-21-2012, 11:51 AM   #51
Crazyspeedfreakz
Member#: 338497
pics added .....
Crazyspeedfreakz is offline   Reply With Quote
Old 11-21-2012, 12:15 PM   #52
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Originally Posted by Crazyspeedfreakz View Post
pics added .....
If it was my car - I'd disconnect the lines at the catch can. I'd also take off the oil cap. This will prevent the crankcase from pressurizing. If excessive pressure builds in there (bad), it can blow a cam seal.
I would then fill it up with about 10psi of air and check for leaks.
Acejam2k is offline   Reply With Quote
Old 11-21-2012, 12:38 PM   #53
Crazyspeedfreakz
Member#: 338497
Thanks for the info acejam
Ok so just disconnect the catch can & remove oil cap. So that will allow heads and crank to breath .. What about the take off on the top front of the Turbo intake that goes to boost solenoid is that safe to leave on ? I thought I had to cap some points off to allow the system to pressurise
Also I keep reading about disconnecting the purge valve, is this only on later Newage impreza's
Is there anything I have to do when finished or is it just a case of putting everything back together
Many thanks for your replies acejam ... It's dark here in the uk now cannot do the test till tomoro
Old 11-21-2012, 12:54 PM   #54
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
The newer STI's have multiple hoses coming off the turbo inlet. Typically you remove them and plug the holes. However as the first post states, the boost control solenoid return line stays plugged in. Since that is the only line you have coming off the turbo inlet, I don't think you have to disconnect/plug anything. (On the inlet)
Does that make sense?
Old 11-21-2012, 01:11 PM   #55
Crazyspeedfreakz
Member#: 338497
Perfect sense .. Thanks buddy, this pesky boost leak has been bugging me for a few weeks now
So will be glad hopefully to sort it... Will report back and let u no how I get on
Thanks again
Old 11-22-2012, 01:10 PM   #56
Crazyspeedfreakz
Member#: 338497
. Unfortunatly I only had a spare hour this evening to see if I could find the leak, done everything as above but it would not pressurise ... I have a good few hours tomoro to see if I can find this leak and why it's not pressurising .... But any thoughts from you guys & girls why it might not be pressurising would be great ..
I'm using a electric pump just wounding how long it generally take to pressurise the system ?
Thanks
Old 11-22-2012, 03:25 PM   #57
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Thanks
Don't even bother with a pump at first. Depending on your hose/valve setup, try blowing into it with your mouth. I had a big leak on my car and was able to find it that way without even needing a pump. Of course I hooked up the pump after the leak was fixed to test again.
Old 11-23-2012, 06:49 AM   #58
Crazyspeedfreakz
Member#: 338497
There is no way I can blow into it as there is not enough room lol..right i have most of the day to sort this so fingers crossed ...
The turbo intake pipe I have has 2 takes offs 1 for the recirc valve which is already closed off as I have a dump valve and the other is for the boost solenoid return pipe which I have left on.
Apart from this I have no takes as I have a catch can fitted my set up a line from crank breather to catch can and then the head breathers t peiced to 1 line and that going to the other port of the catch can hopfully that all makes sense..
I removed the air intake pipe so I can fit the leak tester, then left the pump running for about 10 mins and it will not pressurise the gauge dose not move and I can feel that the pipe work is still soft so no pressure
I have disconnected the catch tank pipes from the catch tank (these are not bunged) and also removed the oil cap
I'm at a loss for now but will keep on it see if I can figure it out
Old 01-29-2013, 10:51 PM   #59
badams118
Member#: 187209
2011 WRX Sedan
Which inlet hoses need to be blocked off?
badams118 is offline   Reply With Quote
Old 02-03-2013, 03:21 PM   #60
curtisboes
Member#: 280395
04 WRX (STI Swap)
Thanks for the great DIY
Here's how mine came out!
curtisboes is offline   Reply With Quote
Old 02-03-2013, 07:27 PM   #61
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Where did you get that hose and what size is it? Also, how about those end connectors? I couldn't find the hose in the OP parts list, so I ghetto rigged mine with some clear hose. However my hose goes into the end connectors, not outside with clamps like yours.
Old 02-03-2013, 07:38 PM   #62
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
All those fittings can be had easily at Home Depot. And the picture says its 3/8" Hose.
Old 02-03-2013, 08:04 PM   #63
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Is that 3/8" ID or OD? I bought all of the fittings in the parts list, but I have a hard time believing the hose could fit "inside" them.
Old 02-03-2013, 08:08 PM   #64
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Hose size is usually OD.
Old 02-10-2013, 09:21 PM   #65
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
If you guys want an even cheaper and dirtier method, try this out.
1: Take used fuel filter
2: Thread compressor hose coupling into old filter
3: Attach to inlet
4: ???
5: Profit!
p951951951t is offline   Reply With Quote
Old 02-17-2013, 02:36 AM   #66
scooby717
Member#: 308687
2004 wrx
rally blue!!!
fun fact here, and im just trying to help by saying this, but with compression fittings like the op's ""2) put a "Watts 3/8 in. x 1/4 in. Brass Compression x MIP Adapter with Insert" at each end of both hoses"", you do NOT use Teflon or thread tape to secure the compression fittings. anything that has a crush washer on it you simply tighten until they do not leak, or replace. putting tape on the threads just hinder the ability for the fitting to tighten, thus preventing leaks. so if anyone has tried to check their tester and been like "wtf.... my leak tester is leaking?!?", this is why. I hope that helps someone
also it is very important for any fitting to leave the last two threads of the fitting unwrapped of thread tape/teflon tape. otherwise under pressure there is a chance for particles of the Teflon tape to be sent downstream of the fitting.... and any debris downstream of your leak tester is bad, so its best to just be cautious.
Originally Posted by D0nets View Post
All of these parts can be purchased at Home Depot and Autozone. The parts list has color coded letter labels to match the diagram.
Parts List: https://spreadsheets.google.com/spre...EE&output=html
Basic Instructions:
1) cut the 2 foot of 3/8" vaccume line into 2 separate pieces
3) drill 2 x 3/8" holes in the 2" pvc plug and then screw each of the hoses into the 2" pvc plug
4) insert the 2" pvc plug into the silicone coupling and tighten it
5) unscrew the stem cover from the tire pressure gauge to reveal a 1/8" threaded fitting
6) screw the 1/4" to 1/8" adapter fitting onto the 1/8" threaded fitting on the tire gauge
7) screw the tire gauge onto the other end of one of the hoses
8) screw the 1/4" male compressor npt fitting into one of the sides of the 1/4" on/off ball valve
9) screw the other end of the ball valve onto the remaining end of one of the air hoses
Note: be sure to use thread tape on everything
Diagram:
Performing the Boost Leak Test:
1) Disconnect and plug the bottom hose on the purge control solenoid, the PCV, the crankcase breather hose, and remove the oil cap
2) Remove the aftermaf and connect the tester to the turbo inlet
4) Make sure the tester's on/off ball valve is in the off position
3) Connect your compressor to the tester's 1/4" npt fitting and set the compressor's regulator to a little over what you want to fill the system with
4) Turn the the tester's on/off ball valve to the on position and fill to your desired psi and then turn it off
5) Listen for hissing and use soapy water to help locate leaks
6) Fix leaks
7) Drink Beer
Let me know if you have any questions. I hope this helps.
Ryan
scooby717 is offline   Reply With Quote
Old 03-24-2013, 10:22 PM   #67
icemanftr
Member#: 320444
2012 WRX
Gonna make me one up this week!
icemanftr is offline   Reply With Quote
Old 04-24-2013, 05:28 PM   #68
Dr. octagon
Member#: 171127
GDA Cyborg T4
Not waving back
Bump for a useful tool, pics, and where to find everything at a cheap cost. Built mine exactly as op directed.
Thanks
Dr. octagon is offline   Reply With Quote
Old 05-18-2013, 04:25 PM   #69
rg3indc
Member#: 356736
What to do use to cap off the necessary parts of the turbo inlet? Rubber caps? What size?
rg3indc is offline   Reply With Quote
Old 05-21-2013, 06:06 PM   #70
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
^Get a kit of assorted rubber plugs at any autoparts store.
Anybody tried the leak testers on Ebay?
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 05-23-2013, 12:20 AM   #71
bobssecrtsn
Member#: 303920
2015 Sedan
CWP
i made this this week,
i have a 2012 wrx and i cannot find the evap purge ( looks like a circle and 2 nipples coming out?)
i also cant find any of the hoses to cap off on the intake side. someone help !!
bobssecrtsn is offline   Reply With Quote
Old 07-08-2013, 02:04 PM   #72
soobie799
Member#: 272961
03 wrx
black
Quoted because I want to know too
Is it just the three red?
soobie799 is offline   Reply With Quote
Old 07-11-2013, 09:56 PM   #73
rg3indc
Member#: 356736
I tried this but I was NOT able to build any pressure in the system. I hooked up my boost leak tester which I bought pre-assembled from a vendor. I plugged the three holes of the turbo inlet. No matter how hard I pump I cannot get the pressure gauge to bump up even the smallest bit.
What am I doing wrong? Car is a 2002 WRX MT with basic boltons.
Old 08-01-2013, 08:43 PM   #74
Galager
Member#: 95198
Good post OP. You motivated me to do it. An FYI - they had a different part number for that valve at my store. Here's link:
http://www.homedepot.com/p/Mueller-G...6#.UfrxD5J9Dng
Galager is offline   Reply With Quote
Old 08-02-2013, 12:33 AM   #75
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
Yea I noticed that last time I had to build one. I couldnt find the smaller ball valve. They seem to only have larger sized ones. They are still 1/4, but the handle and the housing are just larger.
D0nets is offline   Reply With Quote
Boost Leak Tester DIY - Precautions V8 GTFO Lesbic WGN Newbies & FAQs 10 08-24-2009 11:23 PM
Great Catch cans and boost leak testers Chrisgst99 Car Part Reviews 1 07-02-2009 04:07 PM
DIY boost leak tester habitatxskate Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 04-06-2009 02:56 PM
anyone got a boost leak tester i can borrow? kenny08 Southern California Impreza Club Forum -- SCIC 2 02-01-2007 08:39 PM
Home-made boost leak tester? 03MBP Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-23-2005 06:52 PM
