Welcome to the North American Subaru Impreza Owners Club Wednesday August 20, 2014
Old 07-01-2011, 12:05 AM   #1
Ghost Rider
Member#: 70346
2011 WRX
Lightning Red
Default Odd problems after stage 2 on 08 sti
2008 Sti
29k
Invidia fatted dp
AVO TMIC
SPT CBE
FORGE BPV
So I got my ap today and flashed the car to the stage 2 93 oct map v.300. After following all directions I went to start the car and had a problem doing so; it took forever to turn over. After it started I put it in gear and began to drive away. It stalled out when I tried to take off from a stop sign. The car also feels less powerful after the flash. It has given me problems started and stalling several times tonight (but not every time). Any ideas? I am going to data log (what should I look for?) and then revert back to stock flash.
Ghost Rider is offline   Reply With Quote
Old 07-01-2011, 11:00 AM   #2
Ghost Rider
Member#: 70346
2011 WRX
Lightning Red
Looks like I'm hitting the target boost and it is running much better today. Anyone can tell me what I should log?
Old 07-01-2011, 01:58 PM   #3
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
Originally Posted by Ghost Rider View Post
FORGE BPV
VTA or Recirc back into the airstream?
Old 07-01-2011, 06:57 PM   #4
Ghost Rider
Member#: 70346
2011 WRX
Lightning Red
recirc on the forge
Old 07-02-2011, 09:41 AM   #5
Cobb Tuning
Member#: 4803
The AccessPORT has a default set of logging parameters. I would start there.
When you reflash a map, reset the ECU, or disconnect the battery, all the ECU's learned values are cleared. This can make the car's performance feel a little "soft" until learning commences. There are even learned idle parameters that could potentially prevent stalling issues once learned (and the issues return when those values are cleared). I would try to diagnose the stalling issue - it may be a mechanical problem. Try taking a peek at the A/F Learning #1 A, B, C, D values (you don't have to log them) and report back the values.
Bill
Cobb Tuning is online now   Reply With Quote
Old 07-04-2011, 11:44 PM   #6
Ghost Rider
Member#: 70346
2011 WRX
Lightning Red
I am not sure what happened but the stalling has not happened since. I also am thinking the perception of power loss is due to the smoothness of the tune. I was probably getting boost spikes before. Car seems to be running like a champ now
Car Problems after stage 2 burnrubber Factory 2.0L Turbo Powertrain 12 03-23-2010 11:04 PM
Cobb Stage 2 on 08+ STi PSUbaru_guy AccessPort 5 05-11-2009 01:36 PM
Perrin Stage 2 or Harman Motive Stage 2 for 08 STI? shupp81 Newbies & FAQs 5 10-10-2008 01:39 PM
problems after stage 2 installation? scooterman Newbies & FAQs 8 07-10-2007 05:34 PM
Cobb AP Stage 2 on 2005 STi questions. twotacosfor99cents Engine Management & Tuning 9 01-06-2005 10:00 AM
