Old 07-04-2013, 01:28 AM   #51
08imprezahatch
Member#: 247867
08 2.slow
This is (was) an awesome build! You guys realize this was last updated in 2011 though right?
08imprezahatch is offline   Reply With Quote
Old 07-04-2013, 10:50 PM   #52
Dori Ninja
Member#: 73974
04 RSTi
also looking for update...on the head comment...flow wise it is better flowing than STi heads (if ported the same as the 251) but also if the valve springs are the same as the 251 u will be floating valves over about 6psi and thats no bueno...hope they didnt do that and ruined there build
Dori Ninja is offline   Reply With Quote
Old 07-05-2013, 09:45 AM   #53
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
And that the OP's last activity on this website was in August 2012, right?
Old 07-07-2013, 10:22 PM   #54
Suby2.5i
Member#: 176032
2007 Impreza 2.5i-T
SGM
Just looking for help on my 2007 impreza 2.5i turbo. It has a built bottom end, 20g with ewg set at 8psi. Dw301 pump. With new rails, 1,000 cc injectors. And a return line with aeromotive FPR. Also have a 4 bar MAP sensor and stock MAF sensor. It runs great until it gets into boost and then breaks up like its not getting enough fuel and goes lean. Tuner says the car just wont add fuel when he try's to. Is the something I'm missing or anything to look for?
Suby2.5i is offline   Reply With Quote
Old 07-07-2013, 10:25 PM   #55
Suby2.5i
Member#: 176032
2007 Impreza 2.5i-T
SGM
I know the Ecu is not for boost. Tuner says it can read up to 12 psi even with 4 bar map. 12psi is ecu's max. But if it breaks up at 6-8psi there might be a mechanical fuel part stopping it. Im gunna check to see if the removed the intank FPR. Which is not rising rate.
What's the widest tire that can be put on the 2.5i? SubieSubie Impreza Forum 20 11-20-2015 09:27 AM
Will the STi Front and Rear Bumper will fit on the 2.5i? GD6Noob Interior & Exterior Modification 7 04-30-2012 08:33 PM
FS : OEM 06 WRX parts - LOTS AND LOTS of them ninefourteener RMIC Private Classifieds 15 09-17-2010 11:31 AM
Nice deal on track rubber, ebay...A032R's new, and lots of them... REX8 Motorsports 62 11-09-2008 11:58 AM
2 I-80 Sightings in Sac (One of them MUST be from the club!) Kostamojen Bay Area Impreza Club Forum -- BAIC 5 01-09-2002 10:14 PM
