Old 07-26-2002, 01:20 AM   #1
Fred Zaplitny
Gone... But not forgotten
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Default Using a subwoofer port as a velocity stack
This is my intake setup right now.
I need to put a tube into the fender from the PRM inlet so it stays put.
I am going to use this (cut down of course)
I will have the flange in the fenderwell and the 3" tube going right to the PRM. What do you think? Minnimal gain, but better that a straight pipe IMO.
Fred
Fred Zaplitny is offline   Reply With Quote
Old 07-26-2002, 10:05 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I don't think you'll notice any gains.
The main use for the velocity stack is right in front of the MAF to help speed up the air as it enters the MAF.
But you can give it a shot
Legacy777 is offline   Reply With Quote
Old 07-26-2002, 11:08 AM   #3
Chris Popovich
Member#: 14328
2001 Black Legacy GT
Debadged, Eyeliners
The flaring on the port for the subwoofer is to reduce turbulence. While this is nice and all, the big thing to think of is that the subwoofer port is designed for AC fluid flow -i.e. air rushing both in and out. It'll still work fine for the application, but typically a good subwoofer designer will try to kep the air flow at peak velocity less than say, 12m/s, cetainly less than 20m/s, and a 3" or 4" port really won't do that for any driver capable of pushing a lot of air, much less your engine which sucks quite a bit of air.
Anyway, I don't think using the sub port will offer you any significant advantages, more likely you'll realize greater gains by minimizing bends in the pipe and using the largest diameter tube you can.
Chris
Chris Popovich is offline   Reply With Quote
Old 07-28-2002, 11:44 PM   #4
Fred Zaplitny
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Well like I said, I need a 3" tube at the inlet and I think this will be slightly better than a straight pipe. I do not think I'm on to any magical horsepower gainer here! Besides, I'm getting this pretty cheap.
legacy777,
As a general statement, velocity stacks are there to speed up air going into the intake system using the venturi effect. They have been used for years on carburated cars. They do not have to be right in front of the MAF to be effective.
Fred
Old 07-29-2002, 03:15 AM   #5
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Fred
very true...the rest of the intake tract after the MAF would pretty much negate any increased flow...the most effective velocity stacks tend to be as close as possible to the intake ports themselves.
-Milan
US2JDM is offline   Reply With Quote
Where do I get the air-box velocity stack from? Camperguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 09-17-2002 06:12 AM
I finally finished my subwoofer port velocy stack intake Fred Zaplitny Normally Aspirated Powertrain 11 09-06-2002 03:21 PM
velocity stack sochico Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-29-2002 03:03 PM
Well I just did the velocity stack/remove silencer mod and... Camperguy New England Impreza Club Forum -- NESIC 22 07-26-2002 07:42 PM
Homemade Velocity Stack Intake radrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 06-10-2002 02:35 PM
