Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Old 07-04-2011, 04:41 PM   #1
markreda
Member#: 89560
Unhappy I park under a tree
So, my wife parks her black Jetta on our driveway, which happens to be under a very large (long needle) pine tree.
There's no globs of sap on the car but the tree does weep considerably.
We've been parking the car under the tree for 2 years now, you can feel the residue on the paint.
Any suggestions to get the clean up the paint?
Would it be a good idea to use a paint thinner to get the sap/wax off the car?
markreda is offline   Reply With Quote
Old 07-04-2011, 04:47 PM   #2
Tiller35
Member#: 217006
My family uses tar-off or rain-x actually works pretty well on the body, Just if you use rain-x wax it after because it leaves a small mark
Tiller35 is offline   Reply With Quote
Old 07-04-2011, 04:50 PM   #3
markreda
Member#: 89560
The whole car is covered with a light layer of sap. You can feel it if you run your fingers on the paint. Otherwise it just looks a bit dirty.
Old 07-04-2011, 04:55 PM   #4
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
Simple.... use a clay bar git. Meguiars is my fav, you just apply a quick detailing spray, run the bar of clay over the surface back and forth and it will pick up the sap. It takes time but really works wonders.
Alex
binjoau is offline   Reply With Quote
Old 07-04-2011, 06:03 PM   #5
Amazing Asian
Member#: 259589
05 Saabaru 9-2X
Deep Blue Metallic
Alex
+1 try this out
Amazing Asian is online now   Reply With Quote
Old 07-04-2011, 06:20 PM   #6
Bill in Mtl
Member#: 188357
2007 WRX
I feel you pain - we have three cars, all parked under a 40ft maple. Add to that my neighbor has about 15 bird feeders on his property......
My black Subie is the worst, a clean car wash lasts about 10 minutes at best
I have yet to clay bar anything - but that is my next adventure
Good luck
Bill in Mtl is offline   Reply With Quote
Old 07-04-2011, 07:14 PM   #7
Chaz2.5
Member#: 168181
1999 EJ205 RS coupe
When I bought my 02 it had sap all over it. Tried clay bar and it didn't do anything. what I found that worked awesome was hand sanitizer. The bottles of purell. I little blob and a rag took everything right off.
Chaz2.5 is offline   Reply With Quote
Old 07-05-2011, 12:30 AM   #8
n2oiroc
Member#: 141952
03 11 wrx/13 brz
clay is useless against tar and sap. you need a solvent based cleaner like this http://www.detailersdomain.com/3M-Ge...983_p_272.html or this
Amazon.com: Honda Spray Cleaner & Polish: AutomotiveAmazon.com: Honda Spray Cleaner & Polish: Automotive
i use the honda polish and its amazing! takes off nearly anything you throw at it.
n2oiroc is offline   Reply With Quote
Old 07-05-2011, 01:58 PM   #9
bushman95
Member#: 248738
2004 wrx
red
I just use denatured alcohol on a rag to get rid of small spots. Hand sanitizer works very well, gets it off quick and easy but that would only work well for small spots. If your whole car is covered though maybe denatured alcohol on a rag would do the trick. You have to work it though, takes time. It really depends on how thick the sap is.
bushman95 is offline   Reply With Quote
Old 07-05-2011, 02:09 PM   #10
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
if you don't get it fast enough it will actually eat the clear on the paint...as the previous owner of the car how I know.
krauser2 is offline   Reply With Quote
Old 07-05-2011, 02:44 PM   #11
climbhigh09
Member#: 254163
2011 WRX 20GXTR
Kill the tree.
climbhigh09 is offline   Reply With Quote
Old 07-05-2011, 03:42 PM   #12
atvsmurf
Member#: 285747
2011 Impreza OBS
never had this problem(knock on wood), but i use wd-40 on for tar removal...it may(or may not) work...the alcohol sounds good too...whatever you do....wax it afterwards...
atvsmurf is offline   Reply With Quote
Old 07-07-2011, 03:23 AM   #13
GhostSenshi
Member#: 279449
2004 8.78 E/T WRX
Platinum Silver
Well, at least when you do get it cleaned up you are now the wiser and know to stay away from trees, especially during summer when they drop the most sap. Not only that but the chances of bird droppings increases by 100% lol.
No more trees and you'll be happy =]
GhostSenshi is offline   Reply With Quote
Old 07-10-2011, 02:10 AM   #14
wrxfinally
Member#: 284126
2006 Impreza WRX STi
CGM
cut down the tree?
wrxfinally is offline   Reply With Quote
Old 07-10-2011, 02:26 AM   #15
ryan562
Member#: 285982
2008 WRX Hatchback
satin pearl white
had the same exact problem. i just bought a car cover and just got used to putting it every night or every time i get home from work or play.
ryan562 is offline   Reply With Quote
Old 07-10-2011, 12:55 PM   #16
Jaren1
Member#: 195061
1997 \_(ツ)
Green
I use fast reducer from a body shop store to take sap off. Yes it might make the clear a little soft and scratch some in the process but its fast and works good. Plus I figure if your car is covered in that much sap, then scratches are the least of your worries.
Jaren1 is offline   Reply With Quote
Old 07-10-2011, 01:44 PM   #17
zombor
Member#: 246220
2004 WRX
San Remo Red!
My drive way has the neighbor's tree right above it, and any time it rains, i can just hear the wax getting stripped off my car
zombor is offline   Reply With Quote
Old 07-10-2011, 02:12 PM   #18
2011WRXMT
Member#: 270426
2011 WRX Premium
Satin Pearl White
Clay bar it or use other cleaners waxes etc to get the sap sn **** off. Make it all shiny then buy a goddammed car cover and your prob should be solved as sap bird poop etc will be on the cover not the car.
2011WRXMT is offline   Reply With Quote
Old 07-10-2011, 03:18 PM   #19
pelonis
Member#: 288013
use bug and tar remover, should clean up great
pelonis is offline   Reply With Quote
Old 07-10-2011, 04:21 PM   #20
Res1n705
Member#: 288022
2003 Subaru wrx
I say solve the problem. Cut the tree down.
Res1n705 is offline   Reply With Quote
Old 07-10-2011, 11:47 PM   #21
djinn
Member#: 212818
2010 Impreza 2.5i
Satin White Pearl
Hopefully if you cut down the tree you don't have your car parked anywhere near it.
djinn is offline   Reply With Quote
Wait...Lets run under a tree to get away from the lightning! I25 Off-Topic 48 06-28-2007 12:39 PM
Christmas presents you want to find under your tree. Invidia|Helix|COBB and More.... DCH Motorsports Engine/Power/Exhaust 27 02-13-2006 06:07 PM
What present should be under the tree? Nappins New England Impreza Club Forum -- NESIC 25 12-09-2004 10:58 AM
@ work, parked on street, tree branch fell on... joostin420 New England Impreza Club Forum -- NESIC 6 10-17-2002 09:52 AM
How bad is it to park under pine Trees xtheviperx General Community 7 07-03-2002 09:45 AM
