Old 07-09-2011, 09:11 PM   #1
zamboniman87
Member#: 279437
2011 WRX 5-door
Default What should I use?
I'm moving to northwest Ohio and I will not be using my car much at all. It will be sitting outside in the elements, including all the snow. I am looking for something long lasting and not incredibly expensive to protect the paint from the elements and all the snow salt used in the winter. A couple months ago I had the local car wash place put sealtek (i believe) paint sealant on the car and it looked great. Just today I took some polishing compound to the front of the hood and front fenders and installed a clear bra. I of course used polishing compound on a larger area than the bra covers, and since I assume the polishing compound removed any sealant, I need something on those areas soon.
What would you all experienced with waxing, etc recommend for me? What about on the clear bra? I've heard that I should only use spray quick detailer on the clear bra. What about the rest of the car? BTW the car is only a couple months old.
Thanks!!
zamboniman87 is offline   Reply With Quote
Old 07-09-2011, 09:12 PM   #2
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
A car cover?
XanRules is offline   Reply With Quote
Old 07-09-2011, 09:17 PM   #3
zamboniman87
Member#: 279437
2011 WRX 5-door
Originally Posted by XanRules View Post
A car cover?
Hey, I meant to mention that too! I had read unabomber's faq though and he recommended against using a car cover outdoors, so I was mostly staying away from those. But maybe I should consider it? I still would like something on the paint though... at least where I used the polishing compound.
Old 07-09-2011, 09:35 PM   #4
derteracing
Member#: 287416
Good coat of wax, and put the car cover on. make sure you tie the cover tight to prevent rubbing in the wind
derteracing is offline   Reply With Quote
have you used this for STI seats? or what should i use? Speedster329 Car Care & Detailing 3 05-15-2010 11:26 AM
What should I use? Hojai Normally Aspirated with bolt-on Forced Induction Powertrain 13 04-22-2002 01:31 AM
I`m changing my Diff fluid what should i use Wheels Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-11-2001 07:45 AM
What should I use for a RS-T Tranny fluid Jimmy Normally Aspirated with bolt-on Forced Induction Powertrain 16 07-20-2001 03:39 PM
Boost Control!!! What should I use Jimmy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-14-2001 11:40 AM
