Old 07-26-2002, 08:16 AM   #1
wrxxtc
Member#: 11556
2002 impreza wrx
blue
Default anybody install whiteline steering rack bushings?..worth it or not worth it
what are some differences you noticed...my wrx seems to have a lot of bump steer in the turns, trying to help eliminate some of that.
thanks for the help,
Brian
wrxxtc is offline   Reply With Quote
Old 07-26-2002, 12:27 PM   #2
PeterJ
Member#: 14727
2002 impreza RS
Default check my review
Hey, I've installed one of them...too lazy to do the other. I'm not sure either. They are so thin that I can't imagine that there would be much movement anyway. I did a review on then a while back.
I don't think that the bump-steer deal has anything to do with those bushings(although I could be wrong). I've noticed less bump-steer on my RS after installing WRX suspension and Sti strut mounts, then dailed in as much front camber as I could. I think that the bump steer is caused more so by changes in suspension geometry as it travels in the "bump" direction (up), than a bump in the road pushing back against the steering rack which has super thin bushings anyway. Its just a theory, anyway. But if you have the time, then $23 for the bushings is not too bad.
PeterJ is offline   Reply With Quote
Old 07-26-2002, 01:02 PM   #3
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
Default Re: check my review
I don't even know how to do the driver side one. It doesn't look like you can get the old bushing out unless you remove some power steering lines and loosen up the steering rack quite a bit. And honestly, I can't really tell much between turning left and right. The oem bushings IS still kind of new though.
bemani is offline   Reply With Quote
whiteline steering rack bushing install..? splitsec Brakes, Steering & Suspension 23 02-09-2006 12:27 AM
Help for installation of Whiteline Steering Rack Bushings! captainkirk44 Brakes, Steering & Suspension 2 04-14-2005 04:43 PM
Installing the Whiteline Steering Rack bushings on an STI BillyD Transmission (AT/MT) & Driveline 5 02-26-2005 10:06 AM
whiteline steering rack bushing install skoobywrx Brakes, Steering & Suspension 2 12-09-2002 08:02 PM
HELP: Question installating Whiteline Steering Rack Bushing kendo Brakes, Steering & Suspension 0 10-05-2002 11:11 PM
