Old 07-26-2002, 09:57 AM   #1
merlin8019
Member#: 416
1993 Impreza GF8
Steel Blue
Default radiator fan ?s
on the 93-96 imprezas there is three wires - blue, black, and green.....on the newer imprezas 97-01 there is only 2 wires - blue, black- on the fan motor itself. anyone with a wiring book out there could tell me which color is what? is the green just a regulator wire??? thanks
keith
merlin8019 is offline   Reply With Quote
Old 07-27-2002, 12:43 AM   #2
merlin8019
Member#: 416
1993 Impreza GF8
Steel Blue
anybody have wiring guides at all? please ??
Old 07-27-2002, 05:45 AM   #3
tonytiger
Member#: 3844
1993 Legacy 1.8
AT least at Legacys there are three wires.
If there is a connector on Imprezas which has got three wires, one wire is negative and two positive.
If you look at the connector like this:
Negative on the left, the nail in the connector is up. Hope you understand my lousy English.
The meaning of the two positive wires are simply the low and high speed settings of the fan - the voltage on the other is lower.
If you read the wires from the left the nail pointing up, the order is - + +, if it is the same as with the Legacys.
If you have an voltmeter it shouldn't be hard to check, just try to get the fan running. Drain radiator with engine running - ummh ... NOT no no
tony
tonytiger is offline   Reply With Quote
impreza 99-01 oem radiator fans and 98 oem fans jicc 1993 - 2001 Impreza Specific Parts 15 08-12-2009 12:38 AM
Radiator fans are dead, anyone used the Mishimoto fan shroud yet? steriodwrx Newbies & FAQs 3 12-16-2008 06:24 PM
sti radiator fans vs. wrx radiator fans GrimmSpeed Subaru Conversions 2 12-21-2007 01:23 PM
Anyone here built a FAN bypass switch for Radiator fans? Valhakar Electrical & Lighting 23 06-06-2005 09:25 AM
radiator fan / engine cooling fan vvk Normally Aspirated Powertrain 2 05-15-2002 10:05 AM
