Old 07-07-2011, 10:47 AM   #1
Sheltonmega
Member#: 265204
2009 WRXCobbProtuned
CattedAEMCAIPerrinTMIC93
Default Reflash? Realtime?
I have version 2. In the installation instruction, it says we should use reflash. But after the first install, I already see the map is flashed in tune->map->reflash.
Do I need to explicitly reflash, or by default it is already relashed after the first install?
Sheltonmega is offline   Reply With Quote
Old 07-07-2011, 11:21 AM   #2
Cobb Tuning
Member#: 4803
When you reflash a map, the real-time map becomes the same as the reflashed map. It is not necessary to ever flash via real-time.
A real-time flash only changes the 10 or so tables that are supported by real-time (as opposed to the potentially hundreds of tables available to tune in our software that would require a reflash). So, you always want to make sure that you reflash the correct map for your mods and gas.
The advantage of real-time is that it is very fast and also doesn't require connecting the test mode connectors under the dash for older vehicles. You would generally use it when you want to make a temporary change, such as valet, anti-theft, economy, etc. after you have alreay reflashed the correct map for your car. A reflash will remain on the ECU even if you removed the ECU from the car. A real-time map will be reset to the reflash values if you disconnect the car's battery, reflash another map or reset the ECU (via AP or TUNER software).
Bill
Realtime vs. Reflash 93V AccessPort 11 02-28-2011 02:00 PM
Realtime vs. Reflash justin24 Engine Management & Tuning 2 05-04-2010 06:55 PM
HELP. Realtime/reflash Q? stangen97 Open Source Reflashes 3 06-19-2008 12:24 PM
whats the difference and the reason for realtime and reflash? wrb2006sti AccessPort 2 05-26-2007 09:38 PM
Ever want true mobile entertainment, realtime GPS, realtime ECU logging, in your car? wrk king Private 'For Sale' Classifieds 20 03-08-2004 08:03 PM
